Question about Garden
Murray 42inch, 18hp, riding mower(about 7 yrs old) quits when I engage the blade. Also lately will quit running mid stream through cutting. I cleaned the air filter, changed the oil, have yet to check the spark plug. Has plenty of fresh gasoline. Starts up cold just fine. Once it shuts down I have to let it cool before I can start it again. That's when I try to engage the blade w/out any success.
  • Barney_ro353 Aug 04, 2010
    Sounds like 2 problems here. First, if its runnin gthen just shuts down, may need to replace the coil. (Thats whats at the end of the sparkplug) To set it after replacing, use a business card to put inbetween the coil & the flywheel for the gap setting. ALso, check the safety switch for the blade engager. I have one & when I put it in reverse, the engine will kill
  • Garden Master
  • 708 Answers
Blade switch is bad or dust collection has made it inoperable, believe it is located beneath your left foot under floorboard, very hard to access. If you can get to it blow out thoroughly with compressed air. If that does not work u will have to replace.
Posted on Aug 09, 2017
SOURCE: spitting and sputtering
mine did the same, I found out that the high speed jet was clogged, I pulled the fuel line off the filtor(going to the carb), stuck the line into a mixture of half gas half carb cleaner, I fanned it up and in 2 or 3 minutes it started running well, hope this helps.
Posted on Jun 03, 2009
SOURCE: Riding mower having problems starting then runs roughly
I have a Scotts _ John Deere law mower tractor model S2048-S2554 Serial number 020-001, the engine runs but sounds like it is going to die or it needs air --- it runs unnevenly
Posted on Jul 20, 2009
  • 12 Answers
SOURCE: 17hp b/s intek OHV after 30 min mowing starts running rough
if gas is in the oil the needle and seat in the carb are bad or some thing in it. the gas will go in to the crank case and load the cylinder with gas. you can take the carb apart to see if something is in the seat. or replace the carb
Posted on Aug 09, 2009
  • 24 Answers
SOURCE: Craftsman riding mower starts rides a few minutes then stops
Make sure that when you check the oil that the mower has sat I say for at least 5mins. Your mower might have an oil sencer. If not I think it might be the coil gettin hot and shorting out.
Posted on Aug 23, 2009
SOURCE: I have a 15.5 HP Sears Craftsman 42
I'm betting that you need a new safety kill switch - probably the one underneath the seat (the spring-loaded plunger switch that won't let you use the machine without your *** in the seat). Could also be the one behind the "dash" that is associated with the blade engagement mechanism.
I know that the under-seat-switch cannot be bypassed or it will disable the machine in the exact way that you described. Why do I say this? Because I just tried to bypass my own "***-in-the-seat-safety-switch" on my very own 15.5 HP, 42" Sears tractor, and it responded by punishing me - the absense of the switch caused the motor to cut out when I tried to put the machine in gear AND/OR engage the blade. It seems to have some measured capacitance - the absense of same seeming to interrupt the ignition timing enough to shut the motor down when you attempt to get anywhere past neutral or engage the blade. These "safety" switches may be needed by a very few who prefer to be drunk while they mow lawns on steep slopes that their tractor mowers were not designed for, but I find these items to be troublesome and enfuriating. My trees shed a lot of sticks in high winds, and I can't stand shutting the machine down and restarting it EVERY SINGLE TIME I have to dismount to clear sticks or other obstructions out of my mowing path. This is an obnoxious, "nanny-design" feature that desparately needs to be discontinued. It also makes both jump-starting the tractor and electrical troubleshooting much more difficult than they should be. The tractor should let you dismount without shutting down, as long as you have disengaged the blade and shifted into neutral. It should also let you jump start with jumper cables - impossible to do with your rear end in the seat. By the way, call Manufacturer's Supply, Inc. at 1-800-826-8563. They may have a replacement - their item number 31-9664 might do it, but talk to them first. I'm calling them tomorrow. Good luck.
Posted on May 17, 2010
Testimonial: "VERY THOROUGH - THANKS"
I have a 91Murray 42inch riding mower need proper size belt to run blade,a blade belt
Contact a local auto parts store, a full service one, bring in the old belt and they can match it.
Jun 23, 2016 | Murray Garden
Where can I download a repair manual for a 46 cut 18hp murray riding mower?
http://lawnandgarden.manualsonline.com/manuals/mfg/murray/murray_lawn_mower_product_list.html
Nov 28, 2015 | Murray Garden
Murray Select 16.5 hp OHV 42
is one of the blades bent?is one of the bearing s seized or binding
Apr 16, 2012 | Briggs & Stratton Garden
Craftsman 18hp riding mower runs & stalls when engage the blades
motor off= deck engaed turn blade should turn motor and belt fairly easy, NO remove the belt from the motor pulley with deck engaged blades should turn freely.
most decks have breaks on the pullies so if the deck is not engaged the break will be on
May 27, 2017 | Craftsman Garden
Murray riding lawmnmower won't cut grass
sounds like your belts are dry rotten try replacing belts that should take care of it
Jun 07, 2010 | Garden
I have an 18hp 42inch cut Sears Craftsman, it will
You might want to checked your fuel line coming from the tank,sometime it will collaspe inside the line and not allow enough gas to get to the engine.
May 15, 2010 | Garden
I need a belt for a older murray riding mower 46'' deck
I think that's easy to find online. Very common mower. Here's a link to Amazon and Murray belts
Amazon com lawn mower belts murray 46
Jan 03, 2018 | Garden
I have an 18hp 42inch cut Sears Craftsman, it will crank, run a few minutes then cut off. Will crank back up just will not keep running. Dranied old gas, and changed spark plug, still doing the same thing.
check the gas cap vent little hole on top of cap clean with a pin-check and or replace air filter -check and or replace inline fuel filter if still not running correctly need to clean and repair carb
Mar 29, 2010 | Craftsman Garden
Garden Logo
77 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
