Re: Sanyo TV Model #: HT27547 Will I have to get a converter box to watch tv stations?? In a few days I will disconnect my satellite service. Thank you!
  • 552 Answers
This link will verify that yours is digital ready.
If not click able go here.
http://reviews.walmart.com/1336/5652233/reviews.htm
to see reviews for your Sanyo flat screen model ht27547
You may have to purchase a new antenna to do that search for one that is specifically for digital reception and good for the distance from station to home. (Range rating)
re: Sanyo TV Model #: - uhf_digital_outdoor_tv_antenna.jpg
Posted on Apr 25, 2008
I am moving tomorrow and won't be able to afford cable or satellite for awhile. I have a newer model Sanyo tv. Will I need a converter box or can I hook an antenna directly into the tv to pick u
If your TV has the screw-on coaxial cable connection on the back, then you will not need a converter box. You can attach an internal or external antenna and have your TV scan for digital channels. The converter boxes are mostly for old CRT TVs with analog tuners or newer home theater "monitor" TVs which are being produced without built in tuners.
Dec 21, 2012 | Sanyo DP32746 32 in. LCD Television
Can not tune tv since change over
The KV-32FS100 only has an analog tuner (NTSC). Unless there is a low-power analog station still broadcasting in your area, you will not be able to watch OTA stations. (I've got one in my area that barely comes in.) If your local cable still sends an analog signal, you won't need a set top box to watch that subscribed service.
Otherwise, you need a set top box to watch TV. A digital to analog converter (the boxes that were available with the government coupon before the switch over) will give you over the air stations. The basic models only provide SD output; there are a few HD models available. Otherwise, you can use a satellite reciever, cable box (for digital cable service), or something like the Boxee or Sling with tuner. (There are a few different models of the Boxee; one added a tuner with a USB dongle. The newest model of the Boxee has the ATSC tuner built in.)
Note: OTA digital signal quality is either a strong enough signal for the tuner or no signal will be present. You need to point the antenna in the correct direction to receive the signal from your local transmitters. The type of antenna and its placement will also change the number of watchable channels. You can use antennaweb.org or tvfool.com to get more information. Antennaweb assumes an outdoor antenna but gives a conservative list of stations. If the signal is split to several devices, you may need an amplifier to get a watchable signal. (Sometimes amplifiers fail and you won't receive any stations, so test without the splitter or amplifier by using a direct cable to one TV.)
I hope this helps.
Oct 26, 2012 | Sony FD Trinitron WEGA KV-32FS100 32" TV
So you are telling me I need a digital converter for this TV to g
Who was not watching the months of public service announcements? You need a Digital-to-Analog (ATSC-to-NTSC) converter box to receive over-the-air (OTA) signals in most parts of the country. You do not need one for most cable and satellite box outputs--they are NTSC or HDMI. Some low-power, typically religious, stations are still analog. Note OTA may be high definition (HD) or standard resolution (SD) but will be digital.
To get HD on your HD set you must have OTA (HD TV tuner, not converter), cable (QAM TV receiver), satellite (HDMI or 5-wire RCA),or Blu-Ray with HDMI or RCA.
-Ken
Aug 18, 2009 | Hitachi 46F510 46" Projection HDTV
Sanyo model HT27547 installed to Dishnetwork satellite.
the model you listed will receive digital rf signals without the need for a converter box. the link below is a link to the owners manual for your set, in it you will see what to do to get your local station once the television signals switch to all digital broadcasts.
http://www.sanyotv.com/HT27547%20(E)%200255A-.pdf
Please take the time to rate this solution.
Dec 26, 2008 | Sanyo HT27546 TV
Sanyo DS31590 31'' TV DO I NEED CONVERTER BOX?
If you do not have cable or satellite YES you will need converter box anyone and everyone that uses antenna to watch tv needs converter Box.
Nov 21, 2008 | Sanyo DS31590 31" TV
Sanyo HT27547 tv - lightening came in on coax line
Ther is probably a fuse and a diode that got hit by the lighting. If you want to try to fix it yourself unplug it check the fuse and change it if it is bad. Then turn it on again. If it blows that fuse then a diode is also out.
Mar 18, 2008 | Sanyo HT27546 TV
Sanyo DS31590 and converter box
I just checked the owners manual online. Looks like this model only has an NTSC analog tuner. No ATSC digital tuner built in.
If you use cable or satellite TV services, the digital converters won't help you. The coupon-eligible ones are strictly for use with a traditional antenna. If this is your situation, ignore the remainder of this message.
If you use a regular TV antenna with this TV, then, yes, you will need a converter box. FYI, the Insignia model at Best Buy and the Zenith at Circuit City, and elsewhere (radio shack) have gotten good reviews from early purchasers. More converter box models will be available in a few months time.
If your current reception with your antenna is poor (snowy), you may have problems receiving the new DTV signals. If not, you should be pleasantly surprised with the quality of the DTV signals - and the extra "virtual" channels. Try the converter box using the RCA video and audio inputs, for a slightly better picture than with the coaxial cable inputs.
Good Luck
Feb 29, 2008 | Sanyo DS31590 31" TV
Digital signal conversion
If you have cable TV, satellite TV, or FIOS, the coupon eligible converter boxes aren't needed and aren't useful with those services.
They gov't coupon converter boxes are only good for reception with a regular TV antenna or rabbit ears.
According to the specs on epinions.com, no, this TV does not have a digital tuner. So, if you use a rooftop TV antenna (not satellite dish) or an indoor TV antenna, you WILL need an ATSC to NTSC converter box. You need not wait until next year, however, as most U.S. TV stations are also broadcasting digital (ATSC) now.
Feb 23, 2008 | Sanyo DS27820 27" TV
No real problem yet
yes,,,ur TV is a digital one...
Jan 28, 2008 | Sanyo DS25390 TV
Need converter box
Not if you have cable TV, satellite TV, or FIOS. If so, a converter won't do anything for you. Not needed.
If, however, you only use a regular TV antenna or rabbit ears, you will need a converter box as this model TV only has an NTSC analog tuner built in.
Jan 04, 2008 | Sanyo DS24425 24" TV
Televison & Video Logo
223 people viewed this question
Top Televison & Video Experts
