Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
How do you adjust the valves on a 18.5 briggs &stration ohv intec
SOURCE: Briggs and Stratton OHV V-Twin 24hp repetitive valve adjustment
Try pulling out the choke a little, if it stops backfiring the mixture is too lean, check the intake
pipes at the cyl head and also the plastic runners to the carb for leaks.
Dennis in Chicago
Posted on May 15, 2009
SOURCE: I have a Briggs & stratton 18hp ohv riding
I also have this same engine and am also looking for the owners/workshop manual . Also went to Briggs & Stratton with no satisfaction. If you find anything please drop me an email aswell. Thank you. harmsen2@bigpond.com
Posted on Jul 18, 2010
  • 395 Answers
SOURCE: 16 hp briggs ohv v
You could first try resetting the valve clearances. The B & S Website should provide the settings as well as a manual.
Posted on Sep 17, 2010
HansPP
  • 2510 Answers
SOURCE: I have a Craftsman lawn
That sounds like a fuel supply problem, anywhere from the tank into the carb. Check that the tank is clean and that all the fuel lines and passages are clear. You can confirm this by spraying quick start into the intake and seeing if the engine will continue running while the quick start is sprayed into the engine.
Posted on Jun 25, 2011
xclubcar98x
  • 111 Answers
SOURCE: Briggs & Stratton Vertical OHV Engine 18 hp
Check your oil.
If it is overfilled, milky, or smells like gas. Your going to need to change that ASAP. It sounds like the float has stuck in the past or is still sticking, and it has flooded the crankcase with gas, which has mixed with the oil. And because it is overfilled it comes through the breather hose into the carb. This also explains the smoke most probably because the oil is spewing in the carb through the breather and being burned.
Posted on Jul 05, 2011
Have briggs stration 16hp ohv and while running smoke come out of carbuator until it finaly shuts down
You mean the 'carburetor'?
If smoke is coming out of there it means that your inlet valve is sticking open a bit or not sealing properly, or is not operating at all.
Apr 01, 2018 | Briggs Measuring Tools & Sensors
What's the valve gap set on a yard machine 139 ohv mtd push mower
3 to 5 thousandths of an inch on a cold engine.
Search Results
Lawn Mower Repair Valve Adjustment - YouTube
? 4:44
https://www.youtube.com/watch?v=NjzX-PUjKmo Mar 7, 2008 - Uploaded by IFIXIT4U
In this video I will show you how to adjust the valves on a Briggs OHV engine. The valves need to be ...
? 5:06
https://www.youtube.com/watch?v=j77Y5iwXTzg Mar 6, 2008 - Uploaded by IFIXIT4U
In this video I will show you how to adjust the valves on an overhead valve lawn mower engine. The valves ...
How to Adjust The Valves On An OHV Lawn Mower Engine ' Hunker
https://www.hunker.com > Home Hacks & Answers > Garden & Lawn > Lawn Mowers Sep 19, 2009 - How to Adjust The Valves On An OHV Lawn Mower Engine. By Lisa ... Many lawn mower engines use overhead valves. This means, the ... Turn the screwdriver to either increase or reduce the clearance between the setscrew and the top of the valve. Tighten ... Will Mothballs Keep Snakes Out of the Yard?
valve gap set on yard machine 139 ohv mtd push mower Google Search
Aug 14, 2017 | Mtd Garden
I have a briggs & strat 17 hp ohv intec model 311707 on my craftsman lawn m. it was running then with a large puff of smoke it quit. now the starter runs it with no compresion, removed the s p (oi
does the engine when it is turning over sound normal? does the engine have any compression at all or is it just not as much? sounds like a burnt valve
Sep 07, 2012 | Measuring Tools & Sensors
How do I know if its on the power stroke?
just turn the engine till one valve opens and adjust the other one and repeat with the other valve
May 25, 2012 | Briggs & Stratton Briggs Stratton...
What is the valve setting for 2004 18.5 HP briggs & stration intek ohv engine?
31C700 engine? (model number)
This is pretty generac for all of their engines as a general rule 0.004 - 0.006
From the service manual for the 31C700 engine:
ADJUST VALVES
1. Set No. 1 cylinder at 1/4" (6.4mm) past TDC, compression
stroke.
a. Adjust valves and check, Fig. 17.
Valve Clearance (cold) IN and EX .005" (0.13 mm)
b. Torque adjusting screws and jam nuts to 60 in. lbs.
(7.0 Nm).
2. Set No. 2 cylinder at TDC, compression stroke.
a. Repeat for No. 2 cylinder.
Thanks for choosing FixYa,
Kelly
Aug 24, 2011 | Craftsman Garden
Briggs straton ohv on tiller , govener will not work, runs at high speed all the time, starter rope has become extremely hard to pull, will not spin engine.
The hard to pull, will not spin the engine issue could be because you need a valve adjustment. A valve adjustment is critical because it enables the built-in compression release on the Briggs OHV engine to function correctly and enable an easy start; plus of course, smoother running. Remove the valve cover and adjust those valves at 1/4" down past TDC on the power stroke. You WILL see a difference in the engine once you do the adjustment.. Here is a Briggs spec chart which has those values for their engines. Yours should be listed in the OHV engine section.
http://www.briggsandstratton.com/engines/support/frequently-asked-questions/~/media/71BB9DA0BD4D4C19A0DA611923A0B80A.ashx
Here is the Briggs recommended tutorial on HOW to adjust those valves. Scroll down this page to "Adjusting Overhead Valves"
http://www.briggsandstratton.com/engines/support/frequently-asked-questions/Servicing%20the%20valves/
May 22, 2011 | Garden
18 Hp V-Twin quits after warm up - will restart but only runs with choke fully engaged
i have the same issue and trying to figure it out so I appreciate being part of this conversation,
May 05, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
133 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
