Question about Canon imageRUNNER 600 Printer
Cleaning belt I want to know how to replace the cleaning belt
I am not an expert but in my place, south of Haiti, no good canon IR 600 technician, I was oblige to try to do the job myself.
First, I imagine that the cleaning belt is located in the Transfer or the Primary Corona. Because I have another machine IR 550 which has exactly the same coronas. I replace the coronas and the machine is working. But till now, I don't know how to replace the cleaning belt. If I had only one machine; I would still have the same problem.
Thanks for your assistance.
Yours:
Nazaire
Posted on Apr 27, 2008
Erreur P21 konica C650
requires remove of the transfer belt and cleaning of the registration sensors located under the belt on the right side of the machine, with belt out requires knowing what lever to push to expose the sensor to clean them or the have them replaced.
Jun 08, 2014 | Konica Minolta Bizhub C451/c550/c650 Toner...
P7 p28 p5 c300
For P-7 replace the magenta image unit
for P-5 and P-28 unless you know your way around Konica Minolta Copiers you need to have the two sensor located below the transfer belt on the right side cleaned and or replaced, to clean them you must uncover them because when the belt assy. is remove the are covered.
Mar 21, 2014 | Konica Minolta Bizhub C300 All-In-One...
I have a 3500Cp Hewlett Packard and the band is wearing down that moves the printheads. Now it is giving me a 020011 001000da error
If the belt is worn out and you get this message then the belt is the most likely problem. You may need to clean the encoder strip but I would suspect the belt. Do not cut yourself if you clean the encoder strip. Unless you have replaced a belt before I suggest getting a tech that knows how.
Jul 14, 2011 | HP DesignJet 3500cp InkJet Printer
Have error code sc457 on copier, have received detailed instructions on how to fix it, but I need to know how to open it?
SC457 Position error for the image transfer belt’s cleaning unit
- Timing & Condition
• When the belt cleaning section touches the image transfer belt, but the belt cleaning sensor signal remains LOW.
• When the belt cleaning section releases from the image transfer belt, but the belt cleaning sensor remains HIGH.
• Dirty Sensor
• Defective sensor
• Defective belt cleaning shift clutch
• Defective drum peripheral component motor
• Defective I/O control board
• Defective main control board
1. Pull out and re-insert the image transfer belt unit.
2. Clean the image transfer belt cleaning H.P. sensor.
3. Replace the sensor. (Input Check: 5-803-012)
4. Replace the belt cleaning shift clutch.(Output Check: SP5-804-036)
5. Replace the drum peripheral component motor.
6. Replace the I/O control board.
7. Replace the main control board. [Signal Check]
• H.P.: CN219-B2 or TP108 on the I/O control board
The above information are taken from the service manual.
Good Luck!!!!!!!!!!!!!
Sep 20, 2009 | Office Equipment & Supplies
Error message 457 on my ricoh af4106 copier
Hi!
This information might help you.
• Dirty Sensor
• Defective sensor
belt unit.
3. Replace the sensor. (Input Check: 5-803- 012)
4. Replace the belt cleaning shift clutch. (Output Check: SP5-804-036)
control board
Sep 19, 2009 | Office Equipment & Supplies
I need to know how to replace...
The transfer belt cleanning blade is under the transfer belt.Remove 2 screw and change it.The bias transfer roller is mounted in two bushings,remove the bushings and 2 springs.The fuser unit : upper fuser roller,lower fuser roller and the cleaning rollers.
Aug 25, 2009 | Office Equipment & Supplies
Eror 471
"transfer belt error"
Turn machine off (unplug), reseat the transfer belt, and try again. If the problem persists, clean or replace sensors, replace the belt, or replace the motor. Check the contact and release mechanism on the transfer belt.
Apr 13, 2009 | Ricoh Aficio AP3800C Laser Printer
Colors not regestered on belt
when the belt was replaced were all the rollers that the belt is driven by thouroghly cleaned ??
Jan 13, 2009 | Canon imageRUNNER C5180 Color Copier
Replacing the cleaning belt
the belt is part of the fixing assy, the only part that gets hot. The fixing web (cleaning belt) is due to be replaced, an engineer must be called to change it, they are quite cheap, the web has a copy count counter attached in the siftware to it, this will get around it for a short time, but you will get an error code when the belt runs out.
Try this to reset the belt counter and stop the message, enter service mode BY PRESSING "additional functions" then 2 and 8 at the same time and additional functions, all fairly quickly if it doesnt enter service mode, press the yellow reset button after each failed try. Once your in follow this,
(COPIER>COUNTER>MISC>FIX-WEB) HIGHLIGHT AND PRESS C FOR CLEAR ON THE CONTROL PANEL. This will reset the counter and stop the messages for now, until the belt run out anyway (which wont be long)
Hope this helps
Apr 24, 2008 | Canon imageRUNNER 600 Printer
Ricoh color aficio 6513
The following is taken from the service manual I hope it helps Thanks J
the image
transfer belt’s
cleaning unit
section touches the
signal remains LOW.
remains HIGH.
• Dirty Sensor
• Defective sensor
shift clutch
• Defective drum
motor
board
board
belt unit.
H.P. sensor.
012)
motor.
[Signal Check]
control board
Jan 06, 2008 | Ricoh Aficio 2022 All-In-One Laser Printer
Canon imageRUNNER 600 Printer Logo
151 people viewed this question
old marine
old marine
