SOURCE: Jenn-Air stove making clicking sounds
not concernig, but itll drive you batty. check your outlet that the oven is plugged into for proper polarity. theres a plug in tool availabel at the home depot about 5 bucks. itll tell you if you have any problems with outlet. other then that you con ck the electrodes themselves for foriegn matter stuck to them try cleaning them off with an emory cloth( womans nailfile will work)
def not dangerous, but will eventually drive you nuts
SOURCE: Jenn-air gas electric grill range
any power to unit at all?? clear, start, clean ,button?? what happens when you push them??? clock on?what happens when you try to set to clean again??? it should activate hte door lock latch at which point cancel and it should reset itself. with any luck! what happened thankgiving how was it fixed
SOURCE: I am having a hard
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=svd48600
click this link, then choose your model, then on the left side under select diagram scroll down to # 7 oven, and presto.
SOURCE: gas range igniters won't shut off
The problem that you're describing is commonly associated with the spark modulator. It usually occurs after a spill or when the ignitor electrodes have remained wet after a cleaning. If after a day or two it continues to spark intermittently on its own, then the only recourse would be to replace the module. Hope this helps,,,, Bill
SOURCE: With the Jenn-Air PRG4810NP (Natural Gas), is
Conversion is usually accomplished by flipping the regulator cap around. Nat side is hollow and LP is solid to hold the regulator open. The oven orifices are adjustable and the surface burnres can be either adjustable or have LP replacements.
Eric
