Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Mfc 665 unable to print 20 - Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
  • 6,487 Answers
There must be some kind paper jam you had probably lifted the long, thin, plastic encoder strip out of its slot. It is making the printer think paper is still jammed. Try gently pushing the strip back into the slot. You might have to use a screwdriver or other thin instrument to get to the strip.
Posted on Aug 03, 2010
I am principal at the Petite Martinique R. C. School on the island of Petite Martinique in Grenada. We have a brother mfc-9450cdn printer. We are currently experiencing problems with the printer which...
The error "print unable 20" is normally caused by a Hardware/Electronic error: a 'printing' laser 'diode' is not working. I am afraid that you may need to get it fixed, hopefully under warranty: contact your local Brother Printer service centre for instructions.
May 03, 2011 | Brother MFC-9840CDW Laser Printer
My Brother Printer MFC 665-CW just came up with a message Unable to Print 4F
Hi there
Worth a go/
With some Brother printers you can try this.
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, and then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
Some times this happens because of using cheap compatible ink cartridges if this is the case change the ink cartridges.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Oct 12, 2009 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-665 CW with "unable to print 4F" error
My MFC 665CW popped this same "Unable To Print 4F" error recently making the machine fully useless. Just an annoying triple beep and repeat error message to screen when trying to do anything at all with it. I wrote Brother about it. They said to check all through the machine (with a light) for any paper torn off inside, or unwanted foreign objects. This is a good step to do anyway to help maintain the printer. If that is not it, they said it would be a mechanical malfunction. I tried "resetting" by unplugging it for a while as they suggested to no avail. Also while I did find a bit of paper torn off down in my MFC 665 removing it had no effect.
Jul 10, 2009 | Brother MFC 420CN All-In-One InkJet...
I have a brother mfc 665cw printer, had a printer jam, cleared the jam and now recieve unable to print 50 error, unable to copy or print. Have found some information about the encoder strip but I have no...
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 05, 2009 | Brother Multi-Function Center MFC-665CW...
Cyan ink won't print on Brother MFC-665
talked to Brother, cost to much to fix, replaced the printer.
Dec 24, 2008 | Brother MFC 210C All-In-One InkJet Printer
Error message on my mfc 420 mc
this has been written many times here in the forum.
plz search forum "unable to print"
Jun 22, 2008 | Brother MFC 420CN All-In-One InkJet...
Unable to print message on Printer LCD
please press menu then start bk-copy (blue-button) then fourtimes arrow-up quickly one after another. machine will be in maintnenace press start bk copy again. What two digit error code does the machine display? Post again here.
(There are more than 20 diffrent errors for unable to print behind ;-))
Mar 14, 2008 | Brother MFC-5840CN All-In-One InkJet...
Unable to delete print job
Switch off or unplug the printer and then delete it. make sure you have administration rights to delete print cue if your under active directory.
Dec 12, 2007 | Office Equipment & Supplies
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
23 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
