Question about Dell Dimension 4500 PC Desktop
After reformatting my dell dimension pc 4500 and the networking ethernet doesnt show in the manager. how can i solve this? i do not have the startup cds that came with the computer
    President:
  • 2,571 Answers
    Scholar:
  • 104 Answers
Hey hi dude. Tell us your motherboard brand name and its model number. Because with tht only we can able to get you with the driver cds with which you can get your network connections, audio and in some systems USB connectivity also... So kindly let us know with the above details of your motherboard asap
Posted on Aug 03, 2010
3 Suggested Answers
bsrjth
  • 270 Answers
SOURCE: ethernet controller
put ur driver cd in drive right click on yellow questioned device and click update driver and select search automatically
Posted on Dec 08, 2007
lalaro_me
  • 135 Answers
SOURCE: the network adapter in a dell dimension PC running XP home
Ethernet controllers click here
Check for drivers on that site, however much better that you know the brand of your LAN adapter.
Posted on Mar 15, 2009
I have a Dell Dimension 4500 and want to connect it to the Internet with an Ethernet card. Which card should I use?
I would say any card that gives you the speed you require and importantly is compaitble with your OS.
Jan 31, 2011 | Dell Dimension 4500 PC Desktop
Hello im troubleshooting a error on a dell dimension 2400, windows xp error when testing or querying the modem the error reads cannot connect or check to see if hardware is powered on or connected...
Wireless zero configuration is the feature of Windows XP that allows Windows to detect the available wireless networks and automatically connect to the most preferred wireless network.
It is enabled by the Wireless Zero Configuration service in Windows XP. It provides auto wireless network detection when you switch on the computer.
Follow the steps below to verify that the service is running:
1. Go to Start and right click My Computer. Select and click Manage.
2. Computer Management window will appear. Under Services and Applications, select Services.
3. Check for the service Wireless Zero Configuration. Make sure that it is started and that the startup type is set to automatic.
computer-management.jpg4. If it isn't, double-click the service. If the startup type is not set to automatic, click on the dropdown arrow and and change it to automatic. Click OK at last.
autostart-wireless-zero.jpgIf your wireless adapter driver does not support wireless auto onfiguration, you will notice the following:
- The network adapter does not appear as a wireless network adapter in Network Connections. It appears as a LAN adapter, similar to an Ethernet connection.
- The properties of the wireless connection do not have a Wireless Networks tab.
- You do not receive a Windows XP notification bar message indicating that wireless networks are available.
To get the most out of your Windows XP wireless experience, you should contact wireless adapter manufacturer to obtain the latest version of the drivers that support this XP feature.
If not, you must manually configure wireless network settings using the configuration software supplied with the wireless network adapter.
Jan 05, 2011 | Dell Dimension 4500 PC Desktop
Hi everyone, my dell 4500 wont connect to the internet. says it cannot find a network drive card. what should I check?
1. check and make sure your network cable is connected.
2. check to make sure the network card shows up in the device manager.
3. If it does not, remove and replace it and try again.
4. check and make sure that the drivers for the nic are installed.
5. Of course, always check for viruses/spyware etc.
good luck and let me know.
Aug 13, 2010 | Dell Dimension 4500 PC Desktop
Need to hook up to a home network
http://www.fixya.com/support/p348980-dell_dimension_4500_45009f88p11_pc/manual-14422#
click the link above to download the manual. Pay attention to page 62. You network connector is the bottom most one.
May 12, 2010 | Dell Dimension 4500 PC Desktop
Network Adapter Connector does not work.
It is a driver issue... especially if your Device Manager has a question mark, and you recently re-installed windows.
This could be hardware failure as well, but looks a lot more like a simple driver problem. Find the latest driver, install it, restart, you should be good.
Sep 08, 2009 | Dell Ethernet Card Network Adapter
I have a wireless card in my Dell Dimension
The first thing I would try would be to reset the card, by removing the cover (if you are comfortable), removing the card from the slot and reinserting in the slot or moving the card to another slot (if there is an identical slot). If that doesn't work, replace the wireless card either with another wireless card or a USB wireless network adapter (external adapter that connects to a USB port). Good luck.
Jun 15, 2009 | Dell Dimension 4500 PC Desktop
The network adapter in a dell dimension PC running XP home
Mar 15, 2009 | Dell Dimension 8250 PC Desktop
Install memory
No. Your Dell Dimension uses PC-2100 type memory. Your Dell Dimension can support up to 1GB of memory. For optimal performance install the maximum amount of memory in each socket. Your Dell Dimension 4500 has 2 banks of 1 socket each for a total of 2 memory sockets.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Jan 25, 2009 | Dell Dimension 4500 PC Desktop
NETWORK ADAPTER
Reinstall the network adapter from the dell driver cd and reboot the system with the nic pluged in.
Jul 21, 2008 | Dell Dimension 4600 PC Desktop
Ethernet controller
Dec 08, 2007 | Dell Dimension 4500 PC Desktop
Dell Dimension 4500 PC Desktop Logo
69 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
