Question about E-Machines eMachines Desktop PC
Screen on my desk top monitor says its going into sleep mode cannot access safe mode monitor screen wont stay on long enough to do or see if anything works....,,, my pc is an hp a6500f , i replaced the battery on motherboard still says same thing
    Sergeant:
  • 206 Answers
Try using a different monitor or use that monitor on a different computer to see if the monitor is bad. It shouldn't have anything to do with your CMOS battery. I'd check to make sure the monitor itself is good before I go tearing my computer apart. Let me know how it goes and maybe we can get it figured out.
Posted on Aug 03, 2010
Monitor stays in sleep mode?
when you disconnect the monitor from the PC do you see the self test appear on the screen? if you do then the monitor is working fine.
the issue is most likely that the computer's screen resolution is too high and your monitor cannot output that resolution , so it stays a blank screen or in 'sleep' mode as you described.
youd need to go into either Safe Mode when booting the system or find another monitor preferably a newer model to connect your computer to and decrease the resolution before connecting your monitor.
Apr 24, 2011 | Compaq Computers & Internet
My computer says its our of range to adjust settings.
right click on the desktop click on screen setup and click on sleep mode add 20 minutes to it, then right click on the desk top and go to properties choose 32 bit and 900 dpi and click ok see if that's better if it is click ok, need more info or that does not work just re-post a comment and I will get back to you..
Jun 26, 2009 | Sony SDM-HS73P 17" LCD Monitor
Monitor keep going into "sleep" mode
Check the power setting in control panel of windows. If you have a monitor from another computer swap them and see if the problem stays with the computer or monitor.
May 12, 2009 | Dell Dimension 3100 PC Desktop
Monitor willnot come out of sleep mode
turn off everything and restart computer in safe mode,do this by holding down f8 as you reboot,then go in your setting and remove time limit on sleep mode.
Apr 10, 2009 | HP w1907 LCD Monitor
Screen wont turn on with pc
check to see that your monitor cable is plugged in correctly and firmly.
If not boot into safe mode of windows and change your screen resolution to something compatible with your monitor.
try this and tell me what`s up.
Mar 22, 2009 | ASUS A7V600-X Motherboard
Sharp light turns green thern turns yellow screen goes black
it is going into sleep mode, good luck with this.... i am currently asking how to get my hard drive to quite putting my monitor into sleep mode.
although it hasn't worked for me because my screen stays black, one of the options given to me is to try to start in safe mode and then adjust your settings to "never" on the energy/sleep/hibernate mode
some one else suggested that i remove and reseat the video card
hopefully one of those will work for you
Feb 14, 2009 | Sharp LL 172A-B 17" LCD Monitor
When the computer is turned on the monitor goes to sleep mode
Go to safe mode,select boot in vga mode.
If this allows you to start,
Click start,Run type desk.cpl
Screen Saver tab | click on Energy
Under desk or office settings frame, set all values to "never".
Then click
Advanced Options, you'll see a frame asking you what to do.
Just select the options to turn off sleep mode.
check that out.
If you can't start this way,you need to try another monitor to change the setting above.
Please rate this a fixya
Feb 14, 2009 | Computers & Internet
When i turn on the pc as soon as the screen or desk top pops up it turns black.
try to boot in safe mode and reduce your screen resolution to 800x600
Apr 17, 2008 | Computers & Internet
E-Machines eMachines Desktop PC Logo
126 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
