Question about Dryers
We have a commerical speed queen LP dryer it was converted to LP a long time ago (>5 yrs) I have noticed a change in the color of the burner flame. Does the ring around the gas inlet just before the burner head change this (it has a small allen screw and is not loose at the time)or is there another issue I should be concerned with? The LP kit # was M4703P3
  • Jeffery Crow Aug 04, 2010
    I will try that also, I did clean the air entrance area and the burner itself.
    President:
  • 1,554 Answers
You should be concerned with the cleaning of that ring around the gas "inlet". Burnt lint blocks the smooth flow of gas and cause the flame to change from non-luminous to luminous.
Posted on Aug 03, 2010
Whirlpool WFG510S0AS2 range - stove burners work just fine, but both the oven and broiler does not stay lit. NOTE - this unit has been converted from natural gas to LP
when the lp conversion is done , it is normally just a jet size change that is done
however the air shroud has to also be adjusted to get a clean blue burn of the flame
The just jet change results in a slightly yellow flame which is incomplete burn of the gas and that creates carbon build up at the jet and burners causing partial blockage
I would suggest that you call in an accredited gas fitter to check the problem and if necessary , clean the jets and adjust the air shroud
Dec 30, 2015 | Whirlpool WFG510S0AS
Ho to convert a frigidaire natural gas dryer to a lp gas dryer?
Kits should be available at Sears.com, need to be a certified technician to change it. Involves changing igniter, burner scoop, and adjusting air shutters.
Feb 22, 2014 | Frigidaire GLGQ2152ES Gas Dryer
I have a comercial style six burner kitchenaid duel fuel stove. I have converted it the LP gas with no problems. I have noticed some of the burners are not prducing sufficient flame to cook with. What...
You should make sure the range matches the correct gas, if you have to change orifice you must get the correct ones from manufacture do not use any other orifice
always unplug electricity before attempting to repair on any electrical appliance
Aug 19, 2017 | KitchenAid 30 in. KGCS105GSS Gas Cooktop
Speed Queen gas dryer model #AGM499W. Replaced the igniter but did not fix the problem. Dryer will not heat.
burner may need to be vacuum out or blown out, also could be the thermo coupler. Hope this helps tim
Sep 02, 2010 | Speed Queen AGS28AWF Gas Dryer
Sounds like something is loose inside the dry drum
Unplug dryer!!
There should be 2 5/16th screws on the bottom panel in front. Then there are 2 more on bottom of top panel. Take off wires to door switch. Take off 4 screws to front bulkhead. Pull it off. Note how belt goes on. Take it off and pull drum.
I would first rotate drum by hand and see where noise is coming from. If inside one of the baffles in drum, you can easily lossen up screws to remove baffle to get things out.
Jan 10, 2010 | Speed Queen AES28AWF Electric Dryer
Need instructions for Natural Gas to LP Gas for GE Dryer
You can get the conversion kit. It will tell you how to convert the dryer. I recommend that you get a technician to do it though.
This gas dryer is equipped with a Valve & Burner Assembly
for use only with natural gas. Using conversion kit
WE25X0217, your local service organization can convert
this dryer for use with propane (LP) gas. ALL CONVERSIONS
MUST BE MADE BY PROPERLY TRAINED
AND QUALIFIED PERSONNEL AND IN ACCORDANCE
WITH LOCAL CODES AND ORDINANCE
REQUIREMENTS.
Good Luck and Please Rate FixYa!
Jan 19, 2009 | Dryers
Black residue inside gas dryer
r u on lp gas or nat gas if u r lp gas u need to convert the burner from nat gas to lp gas u need to call your gas co. to do the convertion
Dec 13, 2008 | Maytag Performa PAV2200
Speed queen commerical dryer
try replacing the gas valve coils. they are cheap
Jul 25, 2008 | Speed Queen CGS68AWF Gas Dryer
Speed Queen gas dryer won't heat
probably not most likely bad coils on gas valve the 2 black dohickys with wires
Jul 23, 2008 | Dryers
Lg gas dryer lp conversion
On the regulator on the burner you remove cap and turn upside-down and reinstall.
Nov 18, 2007 | LG DLG5988 Stainless Steel Gas Dryer
Dryers Logo
26 people viewed this question
Top Dryers Experts
Marvin
Marvin
