Question about Acer Aspire 5610-4648 Notebook
Power went to 5% window plugged in mains adaptor, had screen for a few seconds then went off..cant power back up have checked different power source outlets & changed fuse in plug no blue power light
  • 1,557 Answers
Then i would say your transformer has burnt out. unless there is a break in the cord.
Posted on Aug 03, 2010
Vizio model M320SR has black screen but has sound. V logo appears when tv is first turned on then goes away.
If there is no video but you have audio or you have intermittent video:
  1. Press and hold the mute button on the VIZIO remote for 3 to 5 seconds. Some VIZIO TV's have a "Mute Screen" feature that turns the screen off if you are streaming an audio application (Pandora, Spotify, etc) and don't want the screen on. To activate/deactivate this feature, hold the mute button for 3-5 seconds.
  2. Turn the TV off and unplug it. Press the power button on the side of the TV for 30 seconds. Let go of the power button and plug the TV back in.
  3. Check the connections between the TV and device. Ensure the cord is connected securely to the TV and the source device.
  4. Try a second device. (Example: If the issue happens on a Cable/Satellite box, try using a DVD player or gaming system to see if the issue occurs there.)
    1. If the issue occurs on multiple devices there is an issue with your TV. Please contact Support by Clicking Contact at the bottom of the page or give us a call Monday - Friday from 7am - 11pm Central Time or Sat. & Sun. from 9am to 6pm Central Time at 855-833-3221.
    2. If the issue only occurs on one device the issue is not with the TV but with the device or the cables used to connect it to the TV.
Jan 26, 2017 | Vizio Televison & Video
Westinghouse sk32h240s. the screen goes black after a few seconds.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Nov 23, 2016 | Westinghouse Televison & Video
Not getting power at all
check AC - DC adapter could be faulty
Check surge protection if plugged into a surge protected powerboard
Could have a crook powerboard
May 27, 2015 | Computers & Internet
Dell Studio 1558 - No post/boot
maybe is the hard disk... u must try to log in with a live usb linux (or windows or hirens boot cd ) and watch if it logs.. if u want to check fan if its covered of dust ill let u a link of how to open it http://www.youtube.com/watch?v=Hn_RX56oGqI
Feb 28, 2013 | Dell Studio 1558 Notebook
Cant get on line?
Turn off PS3 system..
1: Reset your modem by unplugging it from the main power source.
2: After a few minutes, plug modem power back into modem. Allow all connections to configure
3: Turn on PS3 system.
4: Go to "Settings" then scroll all the way down to "Network Settings"
5: Make sure that the "internet connection" (the second menu) is "Enabled"
6: Go to "Internet Connection Settings" and go through the motions again.
Good luck.
Jan 20, 2011 | Sony Playstation 3 (PS3) Console
I had my Dell Inspiron 1525 laptop running. The battery was running down so I plugged the power pack into the electrical outlet first and then into the laptop. The screen went blank and I have not been...
Which ever way round you plugged in should not have resulted in what happened.
You should have a green light on the adaptors case when plugged into the mains weather it's plugged into the laptop or not, if not check the plug fuse.
Is it the correct adaptor for the Laptop? TO CHECK look at the underside of the adaptor the output voltage and amps should be the same as on the base of the Laptop.
Hold the power button down for longer than 5 seconds to ensure the Laptop is off.
Remove the battery and try with just the adaptor plugged in ONLY if its the same output voltage as the laptop.
Remove the memory stick and replace then try and boot again this can sometimes reset the computer.
Leave the adaptor plugged in with the Laptop off to try and put some power in the battery and then try with just the battery.
I have a feeling the adaptor is faulty and it was coincidental that the laptop switched off as you plugged it in, I think you just ran out of battery power.
If in doubt get an electrical shop to test the adaptors output.
I have several 19.5V, 3.34A LAPTOP AC ADAPTER FOR DELL PA-12 KA04A
Sep 12, 2010 | Dell Inspiron 1525 Laptop Jet Black (15.4"...
Lcd monitor power light flashing with no img. seems 2 be frozen
The display is in safe mode and you will need to reset the display to get the display out of the safe mode. There are 2 different model revisions. Please choose the method that will match your revision. Depending on the revision of the monitor, one of the following 2 methods should reset it to a normal state. This reset generally requires both hands and it is sometimes easier with another person.
If the serial number begins with an A and/or your power button on the far right (5th button from left):
Method #1
1. Unplug the VGA cable.
2. Remove the power cable from the back of the monitor.
3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 3 down at the same time (see picture above) and while continuing to hold the buttons, plug the power cable back in.
4. Keep holding the buttons for 5 seconds after the power has been plugged in and then let go. The green light should be steady when you release the buttons.
5. If the procedure worked, the green light will go to amber and you should see a "No Signal" message on the screen for a few seconds.
Method #2
4. Keep holding the buttons until the 4th green LED blink; then, let go. The green light should be steady when you release the buttons.
If the serial number begins with a B and/or your power button is in the middle (3rd button from left):
Method #1
3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 4 down at the same time (see attached picture) and while continuing to hold the buttons, plug the power cable back in.4. Keep holding the buttons for 5 seconds after the power has been plugged in and then let go. The green light should be steady when you release the buttons.
Method #2
3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 4 down at the same time (see picture above) and while continuing to hold the buttons, plug the power cable back in.
If you have tried the reset a few times and it does not solve your issue, please Ask a Question to submit a request through the system or call 1-866-752-6271 Option 1 to contact technical support.
Mar 02, 2009 | Planar PL1910M (Black) 19 in. Flat Panel...
Screen works for awhile but then goes blank.
if u have a problem wih your Westinghouse Monitor LCM-17V8 email me for solution or if you want to dispose of it; email me at
ekwhoward@yahoo.com.
Thanks
Ekow
Nov 04, 2008 | Westinghouse 19" Widescreen Flat Panel LCD...
Had a Acer al2017
If your picture was okay when it was running and the screen was not pinkish then the power board inside the monitor is in need of an overhaul.
Your unplugging it and plugging it back in just did a temporary reset by discharging the capaciotrs for a bit.
It more than likely needs new capacitors installed.
I have done a few of these and do a lot of inverter power board repairs through ebay id bammbammfran
Fran
bammbamm@ptd.net
Dec 12, 2007 | Acer AL2017 20" LCD Monitor
Compaq n800c pp2130
When you connect the power adaptor to the mains and to the laptop and when you turn on the main s the power light should normally glow or else the adaptor id faulty. Try removing the laptop battery and plug it again as sometimes due to jerks there is a loose connection .
Sep 24, 2007 | Compaq Evo N800c Notebook
Acer Aspire 5610-4648 Notebook Logo
20 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
