Question about Kenmore 72102 / 72104
Ice maker does not work and water drips onto the top shelf of the refrigerator compartment (below drinking water assembly) on the left side of the unit. The water has a thin layer of ice on it towards the back of the shelf when this happens. We have turned off the water supply but would like to fix the problem. The unit is level, and both freezer and fridge settings are at the recommended postions.
tborn6
  • 700 Answers
SOURCE: water drips into refrigerator
sounds to me that maybe your draain lin is clogged up in your freezer compartment above your refrigerator. Look for a clear tube that should be runnig down either on thre outside or on the back wall and clear it out after you make sure that its not frozen. if it is then use either a light bulb or hair dryer to thaw out. Thanks for using FixYa.
Posted on Dec 25, 2008
Maytag317
  • 1136 Answers
SOURCE: water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
Hi, I can help you. The drain is plugged in the freezer section. Could I get the model #?
Some models need an after market drain heat strip added.
Please let me know and I can get you through tis.
Thanks
Vic
Posted on May 30, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
Posted on Jul 01, 2009
Controlfrk
  • 304 Answers
SOURCE: kitchenaid ice maker dripping and freezing down freezer shelfs
Tube sometimes freezes because of minerals in it hold one droplet at a time until buildup freezes solid. Replace tube first. Water valve allowing some droplets through can also cause this. Tube first-less expensive.
Posted on Aug 23, 2009
SOURCE: water dripping in the refrigerator
Removed everything from the freezes. Removed a false bottom from the freezer floor, 2 screws. There was an ice build up under this plastic bottom. I let the ice melt with the de-frost cycle (or frost free cycle). No more water dripping into the refrigerator compartment.
Posted on Dec 17, 2009
GS6SHEXNL Ice maker dripping water
Replace the water inlet valve assembly. It has a stuck solenoid. Here is the part to order.
Dec 03, 2012 | Whirlpool GS6SHEXNL Side by Side...
Ice machine fill tube keeps dripping
What is the model number?
Oct 28, 2012 | Refrigerators
GE Profile PSS26PSTA SS freezer problem
Forget the warranty - it is only for the compressor and that is usually five years. Did you check for freezer temp - wet cubes indicates too warm up there. Water dispenser lines may be clogged.
If low temps you may have low refrigerant or a defrost mechanism not working - if not working there should be ice buildup on line entering the evaporator in back of compartment.
Jun 16, 2017 | GE Profile PSS26NGS Side by Side...
No water going into ice maker on our roper side by side refrig
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Jan 05, 2010 | Roper RS22AQXKQ Side by Side Refrigerator
Kitchenaid ice maker dripping and freezing down freezer shelfs
Aug 22, 2009 | KitchenAid Superba Architect KSCS25INSS...
RS25AWXEW01 side x side refrigerator has leak at ice maker water drips into frozen ice chute and leaks onto floor and also in freezer compartment
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Aug 13, 2009 | Roper RS25AEXLQ Side by Side Refrigerator
Jul 01, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Thanks
Vic
May 30, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Kenmore 72102 / 72104 Logo
16 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
