Question about Samsung Cell Phones
Samsung refreshcode (pantar keyguard lock) - Samsung Cell Phones
I have a nokia 1200 cellphone and i want keyguard lock by my personal password so how can i do?
Hello Ashish..!! its very easy to set the keyguard code. all u have to do is follow the following steps
  • go to menu
  • select "settings"
  • now select "Security settings"
  • open "change access codes"
  • now open "keyguard code"
  • open "change security code"
  • enter the default security code for Nokia i.e., 12345
  • now enter your desired 5 digit code n confirm it again. your code will be changed
to activate the keyguard code, open phone settings n then select keyguard settings. open "keyguard code". enter the code and select "on" Hope this info was useful to you.
Jun 24, 2011 | Computers & Internet
I put a lock code now I forgot. It and cantget in my phone.
Messages & Display Issues: The display on my phone reads "Locked" or "Keyguard"
  • If you see the word "Keyguard" on the display of your Kyocera phone, you may have activated the keyguard feature. Press button below "Keyguard," then press 123 or the "OK" key to unlock the Keyguard feature. The phone will display "Keyguard Disabled."
  • Some Kyocera phones also have the phone lock feature available. If the phone lock was activated, the default lock code is 0-0-0-0 (4 zeros). When your handset is programmed with a mobile number by your Mobile Service Provider, the default lock code will change to the last 4-digits of your mobile number. To change your handset lock code, you must go to the Security menu, then select Menu > Settings > Security > Current 4-digit lock code.
  • May 03, 2011 | Kyocera Jax Cell Phone
    FREE UNLOCK CODES FOR SAMSUNG
    I have a Samsung sgh-a887 and the phones key-lock is on and I dont have the code. I just bought the phone today at goodwill and now my keyguard is on. Can anyone help me.
    Desperate
    Aug 12, 2010 | Samsung SGH-A877 Impression Cell Phone
    How to unlock security keyguard on nokia 5310 xpressmusic
    Apr 22, 2009 | Cell Phones
    I had forgot my security keyguard code of Nokia 5220
    I had forgot my security keyguard code of Nokia 5220 xpm.
    imi no is356840020414727 plz tall me
    Mar 27, 2009 | Nokia 5220 XpressMusic Cellular Phone
    LG EnV Keypad lock
    while the phone is closed ! under settings and tools there is an option for keyguard timer. you can choose how long or turn it off all together! :-) took me forever to figure out the whole closed part! :-D
    Dec 03, 2008 | LG enV VX9900 Cellular Phone
    ENV2 Keyguard Lock problem
    When your phone is closed, hit OK for the menu, then hit 6 for Keyguard Settings. There, you can not only change the time it takes for the keyguard to automatically go on, but ALSO change the keyguard unlock options from One Step Unlock (just hitting ok) to Two Step Unlock (hitting ok then clr). It's not a 4 digit code, but it's a lot better than just hitting ok, and much more time efficient than locking your phone every time you put it in your pocket.
    Oct 21, 2008 | Verizon Communications enV2 Cellular Phone
    Keyguard
    if you just need to lock the phone temporarily just hold the pound button for about 3 seconds and it will turn on key guard without changing settings.
    Sep 19, 2008 | LG enV VX9900 Cellular Phone
    Reset Nokia Mobile 1100 keyguard securtiy ccode
    IMEI - 355398007170060
    Security Master Code - 7027122524
    Jul 25, 2008 | Nokia 1100
    EnV2 keyguard
    I just called Verizon about the keyguard being too easy to unlock and they were clueless. But here's a solution: As above, using the OUTSIDE keypad, click OK, go down to keyguard settings (number 6), then hit unlock options (number 2). This gives you the option of using a one step unlock process (hitting the OK key) or a two step (hitting the OK then the Clear). I think it is still too easy to accidently answer the phone but at least this will cut down on the dialing.
    Jun 22, 2008 | LG enV VX9900 Cellular Phone
    Cell Phones Logo
    22 people viewed this question
    Top Samsung Cell Phones Experts
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    Fotis Papastamatiou
    Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
