Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Refrigerator My refrigerator's temp is not constant. The compressor does not go on and off properly. When I turn the control to off and then on again it workd fine for a while but then stops and frig gets warm. Makes ice and all works well for a while, then stops. I'm thinking iot is either the thermostat or the relay switch on the compressor. Any thopughts? Tom
    Genius:
  • 1,073 Answers
Is the fan running at the compresor, if not replace it if it is then the compressor is the issue
Posted on Apr 25, 2008
Compressor not working after performing maintenance ( vacuuming out condensor coil/ fan/compressor compartment )
If you have a start relay , remove and shake - if you hear anything it is toast. with a cap either use a cap tester or just replace it and cross your fingers.
Mar 30, 2017 | GE Refrigerators
Compressor not working after performing maintenance ( vacuuming out condenser coil )
probably a coincidence that problem started after the maintenance unless you knocked a wire of a terminal
more likely a problem thermostat
could be a start run capacitor but if that was the case I would expect not to start again at all to many variables to chase so get in a technician to check it out
Mar 25, 2017 | GE Refrigerators
Cannot adjust contol to freezer and no sound to the compreeor
May be faulty compressor or issue with compressor control capacitor.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Zanussi Z57 / 3 Bottom Freezer...
My Amana TX18QL is not working properly. The freezer temp is too high about 26 degrees and the refrigerator is about 60. The temp controls are set to max. For quite some time water would come out or the...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 04, 2011 | Amana Refrigerators
Upright Frigidaire freezer with warning buzzer on constantly
If your'e positive the temp is ok then your freezer cold control may be bad. Slowly turn it toward off. If the compressor doesn't cut off before it gets to off, the control is probably bad. Test it here>http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Jul 12, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Refrigerator and freezer running warm
Check and make sure fan in frezer section works properly.you should be able to hear fan slowing down when you open freezer, or find door switch and press and hold..hope it helps you..
Jul 07, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Ge fridge GSS25LFGww, fridge part freezing food
Hi, Change the controls back to normal settings. Make sure the freezer is getting 0 to 5 above. If the freezer is getting cold enough, try and turn the cold control to 1 and see if the refrigerator shuts off. It sounds like the cold control in not working properly and will need to be replaced. NOTE: The freezer temp has to be right temp or the fresh food side will not work proper.
I hope this helps. Please let me know if I can assist you further.
Vic
May 30, 2009 | GE GSS25JFM Side by Side Refrigerator
My refrigerator is a GE Monogram ZISS480NRGSS S/N SH031008. The temperature in both the freezer and the fresh food sides increased and did not go down. A technician came in and changed a valve (I do not...
We need to have a look at the main control board part number WRO2X11838 Tell me if the compressor is running while no cooling or if stopped. Unplug refrigerator and see if the top of compressor is too hot to keep you hand on. My drawing show the control bord in the area of the compressor and inside a box. Let me know if it has burn marks on both sides. Thanks, Let me know, Sea Breeze
http://servicepartstec.blogspot.com/
May 20, 2009 | GE Monogram ZISS480NRSS 48" Built-In...
Refrigerator stops cooling, but if I adjust the temp it restarts
temp control wire dodgy turn off take plug out of socket trace wire repair it switch back on i had one temp mate it was wire
Dec 17, 2008 | Frigidaire FRS23KF7AB Side by Side...
Kenmore Side by Side Refrigerator, freezer doesn't work, refrigerator works
Unless specifically made for use in a garage most units won't work properly. The owners manual should say what the temp range for proper operation is (usually 55F is the low range). This is because the refrigerator section doesn't need to be "cooling" to maintain 37F if the temps on the outside are below 55F. These things are made to work in a 70F room and will not work properly if under 55F. Stupid thing thinks it's cold enough so it will never turn on, the refer section will stay cold/cool due to outside temps but since the compressor never runs the freezer will just be the same temp as the refer section (at best). Sorry, but in order for a freezer or refrigerator to work in an unheated space it must have the temp control device controling the freezer section NOT the fresh food section. In other words, that model will not work in a garage unless the temps are above 55F always.
Feb 06, 2007 | Kenmore 50522 / 50524 Side by Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
