Question about Kodak EasyShare One Digital Camera
The internal memory is full; how do I correct this?
  • Kodak Master
  • 6,826 Answers
Delete pictures until it is empty. Use a higher capacity memory card and switch to it in the menus.
How many pictures can be stored on the internal memory of the KODAK EASYSHARE-ONE Zoom Digital Camera? Question : How many pictures can be stored on the internal memory of the KODAK EASYSHARE-ONE Zoom Digital Camera? Answer : The camera has 256 MB internal memory (185 MB available for image storage)*. The number of pictures that can be stored depends on the Picture Size (picture quality) setting selected on the camera as well as the level of detail of the subject. The following information can be used to approximate the average number of pictures that can be taken at each setting: 4.0 MP: 150 pictures 3.5 MP (3:2) : 167 pictures 2.1 MP: 270 pictures 1.1 MP: 451 pictures NOTE: Internal memory can store up to 1500 images, tagged as Favorites, optimized for viewing on the camera. Favorites as such are added to the camera through synchronization with EASYSHARE Software on your computer. See the camera user's guide, or click the Help button in EASYSHARE Software for more information.
*1 MB equals one million bytes, 1GB equals one billion bytes
Posted on Aug 03, 2010
Internal memory is full how do i correct the problem
You are going to have to get an sd card to expand your camera's memory
Oct 17, 2012 | Kodak EasyShare Z740 Digital Camera
Hi, I have a Kodak EasyShere canera, model # Z712 IS. I used to be able to take hundreds of pictures before the memory was full on this camera. Now it says it's full after 14! How do I correct this...
Somehow, you started using the camera's internal memory which is very small. With no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory. Then, insert your card and it should work properly.
Mar 23, 2011 | Kodak EasyShare Z712 Digital Camera
Kodak C160 camera says internal memory full. How do I correct it so it will take a pic? Have tried new memory card.
You need to get rid of the pics in the internal memory. With no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory. Then, insert the new card and do the format thing again to erase and initialize the card. Everything should work properly now.
Jan 26, 2011 | Kodak EasyShare C160 Digital Camera
C142 kODAK DIGITAL CAMERA. ADVISING INTERNAL MEMORY IS FULL. I HAVE PURCHASED A NEW MEMORY DISK BUT STILL GETTINGTHE SAME MESSAGE AND WILL NOT ALLOW ME TO TAKE PICTURES.
The internal memory is not the same as the memory card memory. The camera needs some elbowroom in the internal memory to work at all. It can't use the card memory while the internal memory is full. You need to delete some pictures from the internal memory, then insert the memory card, and it should work (assuming it is formatted correctly and is otherwise compatible).
Dec 20, 2010 | Cameras
I have a Kodak Easy Share C310. It keeps saying that the internal memory card is full. The card is the camera is 200 photos yet it is only showing the original 16! Thanks, Kathy D
"internal memory card is full" There is no more space in the camera's internal memory. Your camera has 16 MB of internal memory. The number of pictures you can store depends on the Picture Size setting you have selected on your camera.The following are approximate number of pictures you can take at each setting: 4.0 MP: 16 pictures 3.1 MP: 18 pictures 2.8 MP: 20 pictures 2.1 MP: 29 pictures 1.1 MP: 48 pictures Internal Memory?the camera always uses internal memory, even if a card is installed. Auto (default)?the camera uses the card if one is in the camera. If not, the camera uses internal memory Image Storage Choose a storage location for pictures and videos. To correct the issue your getting follow this steps: 1.Press the Menu button. 2.Press to highlight the setting you wish to change, then press the OK button. - The settings you need to look for is Image Storage 3.Choose an option, then press the OK button. - The option you need to choose is Auto the camera uses the card if one is in the camera. 4.Press the Menu button to exit.
Nov 15, 2009 | Cameras
Kodak EasyShare cx7300 says Internal memory full. How to fix?
Your picts go to the memory card correct ? How does the internal memory come into play here - can you select which it's storing on as this sounds like the issue. I would buy a 1gb or 2gb memory card for 30$ and you can take ~ thousand picts :-)
Aug 06, 2009 | Cameras
Internal memory card
Download all info and format memory. good luck
Jan 01, 2009 | Kodak EasyShare C330 Digital Camera
Micro card
When I bought the phone I wanted to use a bigger Memory card. I was told it will only recognize 2gb. The booklet that comes with phone says the same thing, so would assume that is why it says full. Assuming of course youre trying to use more than 2gb at the moment.
Jun 05, 2008 | LG KU990 Viewty
Memory full
You camera is running off of the internal memory the camera manufacture does not give you much to play with. If you have a memory card in the camera and are still having the same issue going to the setup menu and find memory and set it to auto this will allow the camera to use the memory chip and used the internal memory when it is out. some times you can do a camera reset and it will correct most of the issues.
Mar 24, 2008 | Cameras
Kodak EasyShare One Digital Camera Logo
219 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
