Question about Logitech Quickcam Chat Webcam
I have skype and my brother has a logitech quickcam, can he call me on my skype? are they compatitable
  • Logitech Master
  • 3,015 Answers
You both need to download Skype and configure your webcams to that program
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
Not working ? - troubleshoot your drivers and software - get your cam working before moving on
Working OK ?
CONFIGURE TO SKYPE
Connect webcam
Its good practice to disconnect and re-connect your webcam before you start (To reboot the webcam software) - if you have been using it elsewhere the SKYPE software may have difficulty in locating it, even if you exited the previous program correctly.
The reason being, the webcam software can remain hooked-up to a program and needs to be rebooted.
Mine, I just unplug it from the USB and plug it back in to reboot the software.
If yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Start Skype.
On the 'Tools' menu, click 'Options'.
In the navigation pane of the Skype 'Options' window, click 'Audio Settings'
Run down the list setting your defaults
Select your webcam as the default microphone.
Make a free test call
Click 'Save'
In the navigation pane of the Skype Options window, click Video Settings.
This will launch your webcam
Adjust quality of picture in 'Settings'
Check the correct webcam is shown as default
Click Save
Test your webcam by making a Skype test call.
For more information about how to configure Skype Messenger, please visit the following Skype Web site:
http://support.skype.com (http://support.skype.com)
When he tries to install his webcam he will be notified if its not compatible - this usually means updating to the latest software
http://www.logitech.com/en-us/support-downloads/downloads/webcams
Posted on Aug 04, 2010
Hi, i tried using skype with logitech quickcam but pup-up told me this message: Another application (communications helper.exe) tries to access Skype but we are not able to respond. Try to restart the...
The easiest thing to try is just disabling "Communication_Helper.exe" in Skype. Go to Skype / Tools / Options / Advanced, and at the bottom you will see text that says "manage other programs' access to Skype". Click that and you'll get a window, which should list "Communication_Helper.exe". Deny access to that (don't remove it, because it will just come back), and try your call again.
Be aware, however, that this is only a quick fix and does not solve the problem. When Logitech and Skype have problems like this, they can be pretty big ones, and can cause performance problems as well as interface problems.
The Logitech QuickCam application software is not required for the Logitech Camera to function properly in Skype. If you are not using the QuickCam application for anything else, then you should seriously consider uninstalling it.
That will solve this problem, and various other potential problems and performance issues, permanently.
To uninstall it just go to Control Panel / Add or Remove Software (or Uninstall a Program in Vista/7), find "Logitech QuickCam" (NOT Logitech Camera drivers), and uninstall.
Then reboot to get rid of the background processes, and test Skype again.
May 05, 2011 | Logitech QuickCam Connect Webcam
I am not a computer person.I was wondering if logitech webcam C250h will work with skype?
Yes, I have a Logitech WEBcam (not the same model) and I use Skype.
After you installed Skype then :-
To test if the Logitech QuickCam is functioning, check the USB cable; make sure it is connected properly. Then click on Start - All Program - Logitech - Logitech QuickCam and see if you can get the camera to capture your image/video.
If this works then the fault is with the Skype configuration. Sometimes the WEBcam settings drop off and the WEBcam need to be selected again. Open Skype - Tools - Options - Video Settings and select the Logitech QuickCam
Also check the Audio Settings for the Microphone THEN click on Save.
Avoid connecting the WEBcam to an USB hub.
Mar 09, 2010 | Logitech Webcam
My camera quit working in skype, any suggestions in troubleshooting? the green light isnt coming on at all, it was working like 5 minutes ago
To test if the Logitech QuickCam is functioning, check the USB cable, make sure it is connected properly. Then click on Start - All Program - Logitech - Logitech QuickCam and see if you can get the camera to capture your image/video.
Dec 14, 2009 | Logitech QuickCam Connect Webcam
Logitech quickcam deluxe which freezes repeatedly with skype.
Saw this on the Logitech forum the guy went back to an earlier version of Skype to make it work
There was also an issue with some cams not working very well in a 2.0 USB socket.
Oct 07, 2009 | Logitech Webcam
Using Skype with my Logitech QuickCam Pro 9000
The advantage of having a logitech webcam is the support you have.
I just launched my logitech toolbar and clicked on the lowest panel to see what help you have with your webcam in Skype - check this out
http://logitech-en-emea.custhelp.com/cgi-bin/logitech_en_emea.cfg/php/enduser/std_adp.php?p_faqid=9266&p_created=1227724918&p_sid=PlhfBfJj&p_accessibility=&p_redirect=&p_lva=&p_sp=cF9zcmNoPSZwX3NvcnRfYnk9JnBfZ3JpZHNvcnQ9JnBfcm93X2NudD00NCw0NCZwX3Byb2RzPSZwX2NhdHM9JnBfcHY9JnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1Mb2dpdGVjaMKuIFdlYmNhbSBQcm8gOTAwMA**&p_li=&p_topview=1
Also there is a good logitech forum from other users as logitech tends to have teflon shoulders when it comes to chat programs
Sep 29, 2009 | Logitech QuickCam Pro 9000 Web Cam
I can't video call on skype with my quickcam communicate Mp s5500
Have you tried to add your camera in Skype's video settings? If yes, try to exit your Logitech software and then check if it's working. Hope you'll fix it. Good Luck!
Jun 07, 2009 | Logitech QuickCam Communicate STX Webcam
Quickcam for SKYPE
Hopefully you have not loaded the quickcam software yet. If you have, hopefully you only loaded the drivers for the cam and not the logitech control panel for the camera. If you loaded the control panel, it loads everytime you start your computer and runs minimized in the bottom status bar. When you start Skype, it activates the camera and so does the logitech control panel. Thus you have two programs trying to control the cam at the same time and you have nothing but problems thying to get it to work. You will need to right click on the logitech control icon and exit the program before starting Skype. After you start Skype got to tools, options and set your camera and mic. settings from the drop down menu. You can then go to Skype test call and see if the settings are correct. Skype allows you to turn on the video or off when you make calls to others. This is so they can't see you, but you can see them during the call unless they have theirs turned off also. Good Luck, RAC
Mar 03, 2009 | Logitech QuickCam Connect Webcam
Quick cam chat to skype hookup?
Skype usually recognizes the web cam. If not try reinstalling Skype if your cam works
Feb 10, 2009 | Logitech QuickCam Express Web Camera
Hi, i would like to take live picturs and/or video while i am chating with skype and dont know how to do it. will you help me ? thanks, eddie
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>- --> Skype issues with your QuickCam Communicate STX trnsp.gif Detailed Description 1754.1.0.jpg This article explains what to do if you have problems using Skype with your QuickCam Communicate STX.
Model Number: V-UBK45
trnsp.gif Answer If you are experiencing difficulties using the QuickCam Communicate STX with Skype, check the following:
Verify the QuickCam Communicate STX is functional:
  1. Launch QuickCam software (Start > Programs > Logitech > Logitech QuickCam)
  2. Verify that you can see yourself in the QuickCam window as shown below:
  3. Close the QuickCam window.
Verify that the QuickCam Communicate STX is selected in the Skype Settings:
  1. Launch Skype (Start > Programs > Skype > Skype)
  2. Click Options from the Tools menu as shown below:
  3. Select the Video Settings option from the Skype sidebar as shown below:
  4. Check the Enable Skype Video checkbox as shown below:
  5. Check the "Start my video automatically when I am in a call" checkbox as shown below:
  6. Verify that your QuickCam Communicate STX is selected from the Camera drop-down menu as shown below:
  7. Verify that your QuickCam Communicate STX is selected from the Microphone drop-down menu as shown below:
  8. Verify that the "Let Skype adjust my audio settings" option is checked in Audio Settings as shown below:
If you still cannot see or hear the other person, it can be due to a variety of possible issues, including:
  • Windows or third-party firewalls
  • Your internet service provider (AT&T, Comcast, etc) could be blocking certain services.
  • Missing Windows system components.
Jan 10, 2009 | Logitech Quickcam Chat Webcam
Logitech Quickcam Chat Webcam Logo
62 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
