Question about Akai PTH5498 54" Rear Projection HDTV-Ready Television
PT5598HDI There is sound but not picture. There is no high voltage and the voltages around the IFT are way off.
  • kqqd9m Apr 25, 2008
    Akai PT5598HDI could it be the IFT and/or the horizontal out put transistor
  • 934 Answers
More likely Icz103 & Icz104 the convergence amps. Are they heating at all?
Bill
Posted on Apr 26, 2008
Hi my sansui tv sv29281 takes time to show pictures after i switch it on & when it becomes on, it produces weid sound...what could be the problem, pls help
If the sound is a high pitched, sizzling sound then it is most certainly a high voltage problem. If you feel capable, take the back of the set off and in a darkened room turn the set on. I would imagine you will see high voltage arcing somewhere around the transformer, trippler or lead that connects onto the back of the screen. (not the picture tube). If you do, this area will need to be investigated. Make sure the set is turned off and has been off for at least half an hour as there are very high voltages still present due to high voltage capacitors. Make sure that the plugs are right and insulate any earthing points around the area with simple elastoplast tape. Any holes in the trippler, ( a plastic box looking thingy), can be covered with a hot glue gun or silastic. Good luck and please take care._
Jul 11, 2014 | Televison & Video
Got sound but no picture
If the model number listed here is correct either no high voltage is present or filaments to the 3 picture tubes it uses are not lit.
If a different model let me know, this one here is prone to all sorts of bad solder connections around the high voltage transformer and sometimes resoldering those cures problems
12_14_2012_5_31_33_pm.jpgtypical high voltage transformer
Dec 14, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
My rca tv has a distorted picture and a really high pitched buzzing sound
Problem is in High voltage circuit and likely either the high voltage transformer or a connection right under or around it.
Jun 16, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
No light or picture. only sound and the screen is dark.
Two probable points; either the loss of the service voltage for the high voltage section or a failure in that section.
The circuit that produces the high voltage for electron beam acceleration also produces the sweep for the horizontal movement of the beam, in other words, if this circuit fails or the voltage it needs to operate is gone, no picture, but the audio still functions.
Because of its Chinese origins, there is a chance that critical specialized parts may still be available for it or, if you are lucky to have a tech competent to repair standard TVs, he may find a less critical part that has failed and readily available.
Dec 01, 2010 | Haier TN201AUV 20" TV
Hitachi 51f59a lost picture powers up and can hear sound amp come on when turned on and off but no picture
You may have a shorted horizontal output transistor. This transistor drives the high voltage transformer which in turn drives the picture tubes. High voltage can be dangerous so you may want to have a repair shop check it out for you. Also have them apply a bead of silicon around the anode caps on the picture tubes. This will prevent high voltage leaking out and causing the horizontal output to short again. Thanks
Oct 27, 2009 | Hitachi 51F59 51" HDTV Projection...
AKAI PT5598HDI 55 Where is fuse located
This problem is beyond a blown fuse most likely. The fuses for the unit are located on the circuit boards and the back will need to be removed to access them. This problem could be due to a missing voltage that is used to turn on the picture section of the electronics. I would search for a used unit on ebay or parts on ebay and swap out the boards. The board swap is not too complex but voltages are dangerous within the set and service by a qualified electronics technician is recommended on this unit. Thanks and good luck. Dan
May 31, 2009 | Akai PT5598HD 55" Rear Projection...
All of a sudden this TV has a problem of loosing voltage to the CRT and the screen suddenly goes black. After about 10 minutes the picture comes back. If you leave the set on for quite a while it seems...
You will have to tip the chassis up side down and look over most of the chassis close to the High Voltage Transformer (IFT) look for cold joints around there first, then locate the Vertical IC and look very closely at those pins, they usually have hair line stress ring cracks around them. If youv'e never done this type of work before I would take it in to a service co. It's not a major repair.
May 02, 2009 | Televison & Video
Black growing on screen
That is normally cold solder joints around the High Voltage transformer ( IFT) and also the video section. It should'nt be a major repair for a tech.
Apr 16, 2009 | Televison & Video
AKAI PT5598HDI 55" PROJECTION TV HAS POWER AND SOUND, NO PICTURE
Open the back of the tv and check Fuses, sound like the high volt over loaded
Jan 11, 2009 | Akai PT5598HD 55" Rear Projection...
Black screen with sound only no picture.
I have same problem,it appears to be the flyback
xfr.
Apr 18, 2008 | Hitachi 32UDX10S 32" TV
Akai PTH5498 54" Rear Projection HDTV-Ready Television Logo
73 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
