Question about Visonic INC Smarthome SecureLinc Wireless Home Security System SecureLinc
VISONIC WT201-A OFFICE DOOR REMOTE CONTROL CLICKER NO LONGER WILL UNLOCK THE DOOR, EVEN WITH NEW BATTERY. PERHAPS THE SWITCHES NEED RESETTING INSIDE?
If then battery has to be replaced in the CLICKER key pad made by Chamberlin do you have to reset the code?
You should not have to reset the code. Simply remove the old battery and insert the new one, being careful to observe the polarity when you replace the new battery, and you should be good to go. The batteries can be obtained at most Wal-Marts, Radio Shacks and even through eBay if you know the correct number. Thay are lithium and will last a few years under normal use.
Nov 16, 2014 | Chamberlain Clicker Universal Remote...
How do I reprogram a clicker?
Erase all remotes (usually similar procedure to programming, but hold the button longer) from the door you don't want (it's on the opener/receiver, not the clicker) then program only the one you want.
Sep 30, 2014 | Chamberlain Clicker Universal Remote...
Clicker klik2u stopped working
You may need to repeat the programming procedures in the manual to make the remote work again. Sometimes if the battery dies, they lose their programming. I've encountered this before. What brand of garage door opener do you have? There may be a better remote control for you than the universal remotes like your Clicker.
Sep 17, 2013 | Building Materials
Remote with new battery seems to have all functions except the lock door function. The armrest control has normal function and will lock and unlock. The remote will then unlock but will not lock. This is a...
possible bad button on key fob.unlock button good lock button bad .get a new clicker you can program it yourself ....put key in ignition turn back and forth 10 times while holding the unlock button on remote.that should work
Aug 05, 2011 | 1998 Ford Explorer
I need a new tv poloride flat screen remote control clicker
Howdy. To order a new remote control (clicker) you may call Polaroid at this number: 1-800-765-2763 (1-800-POLAROID)
If you prefer to write to them: Polaroid Corporate Office
4350 Baker Rd.
Minnetonka, MN 55343-8684
They should be able to get you one the fastest. Hope this helps:)
Aug 20, 2010 | SYMA Toys industrial RC Toys Village New...
The clicker will not lock or unlock the front
It sounds like your remote needs a new battery.
Your user manual should tell you what type... else, remove the old battery and find an equivalent.
Hope this helps... Good luck.
Oct 13, 2009 | 1999 Lexus RX 300
Remote control no longer opens the lock
Sounds like the button to unlock doors on the fob is worn out. You can purchase a new one or used from your local recycle yard.
Jun 01, 2009 | 2003 GMC Sierra 1500
Liftmaster Professional and Clicker Programming Problems
The Security+ system is a rolling code system and is digital, so it will work with the Homelink in vehicles and with the remote control units that come with the opener. Also with new remotes that are purchased specifically for that opener. Your "clickers" require specific instructions and you need to use the Smart Learn function in order to use them with this opener. In addition, check the Brand Switch settings to be sure they apply to your opener, and the correct Smart Button color on the opener. Read carefully to determine whether you need to set ANY dip switches at all or can you just set them all to off depending on your opener? Check the instructions carefully. Here's a link to the page where you can download a copy of the Clicker instructions if you don't already have it:
. Clicker Model CLT1D Remote Control Owner Manual
May 14, 2009 | liftmaster Chamberlain Garage Door Opener...
Have chamberlain security plus 950cb lost instructions.
http://www.chamberlain-diy.com/doityourself/pdfdocs/114A2184.pdf
This web address came from the Chamberlain site. I also needed to relearn my remotes due to a newer car that has a built in garage door opener that needed to be set. I also needed to reset my keypad remote, those instructions I was able to get from the same site. Good Luck
Apr 05, 2009 | Chamberlain 950CB Remote Control
Need to match DIP switchs on a universal garage door remote
I find Clicker products confusing. Might want to buy whole new replacement readio control set. how old is operator?
Jan 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Visonic INC Smarthome SecureLinc Wireless Home Security System SecureLinc Logo
138 people viewed this question
Top Visonic Home Security Experts
Gil Shultz
David Legender
David Legender
Are you a Visonic Home Security Expert? Answer questions, earn points and help others
