Question about GE J Series 18.2 cu. ft. Top Freezer No-Frost Refrigerator TBX18AABWW
My GE refrigerator Model TBX18SA is draining condenste water at the bottom and also inside.How to get rid of it ?Thanks.
    Problem Solver:
  • 15 Answers
That happened to us on our freezer side by side. Pull out whatever is in the bottom of your freezer, a shelf or a basket. Look on the floor of the freezer toward the back. You should see a small dime or nickle sized hole that may be covered in ice. It should have a cover on it with small holes. Check that nothing is blocking that hole. Something has probably fallen on top of it and has blocked its ability to drain thru the hole into the drain pan under the fridge when the defrost cycle comes on and the melted ice can't drain down properly. We used a hair dryer on low to carefully melt the ice that had formed on the bottom to find the drain. Sure enough a small piece of plastic wrap was blocking it. We removed the plastic and continued with the hair dryer til we could pour water in the hole and it flowed freely to the drain pan and didn't continue to back up into the freezer floor.. Be very careful with the hair dryer, put it on lowest setting and keep it moving back and forth, don't hold in one place, or it could melt or warp the plastic sides of the fridge. When the hair dryer is on low, put your hand about a foot in front of it and it should feel warm not hot. Move your hand forward til you feel the air is just warm, this is the distance you want to keep it from the ice you are melting. As the ice melts use a small towel to mop up the melted ice as you go. Good luck
Posted on Jan 21, 2011
  • john ortiz
    john ortiz Aug 19, 2014
    Look in the back of frigerator, you will see a black plug like with a tube going down. Turn the black plug like thing left or right to remove tube and plug. Take plug to sink and run hot water til its clear. Just did this to mine, and now it works with no more water mess.
Why would my GE (model # TBX18SA) just stop making ice?
Is there any ice remaining in the slots of the ice maker? If not then the water control valve will need to be replaced. If the ice maker still has ice in the cube slots and does nothing then it is the ice maker that needs to be replaced. Here is the=> WR30X10093 Ice Maker for your TBX18SA and the=> WR57X10033 Water Inlet Valve
APPLIANCE 911
Mar 15, 2016 | GE Refrigerators
Water collecting inside fridge, under meat drawer
Yes most responses are the freezer drain even if it is in the bottom freezer. If the drain is blocked water will build up anywhere inside your refrigerator only because it has no place to go during the defrost. Defective door seals can also can make the problem much worse. See Leaking Refrigerators I am here should you need me, Thanks John Tripp Appliance 911
Apr 21, 2014 | GE Profile 22.2 Cu. Ft. Side-by-Side...
Water is collecting outside the bottom right side of regrigerator - GE tbx18sa
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 06, 2011 | Refrigerators
Water comes out from the bottom of the Freezer side of the refrigerator....
the defrost drain tube is clogged, located at the bottom of the back wall inside freezer. Use a hair dryer and hot water to rid the tube of all ice.
Jul 05, 2010 | Hotpoint HSS25GFT 25.0 Cu. Ft....
GE refrigerator model # TBHW22R is leaking water into bottom bins
There are many reasons for this happening for example water leaking from a water supply line for the dispenser or ice maker, a crack in the defrost pan, water leaking inside and draining through the refrigerator cabinet, but most are cased by a defrost drain line blockage. Below is a link that may be helpful so try to take it all in and use the parts that most refer to your specific problem, Thanks Sea Breeze
click on link below
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
Aug 27, 2009 | GE Refrigerators
Leaking freezer
Self-defrosting refrigerators usually dispose of the water generated during the defrost cycle via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan. In some refrigerators, the defrost water is intentionally directed down the back wall of the refrigerator, where it then flows to the bottom of the refrigerator compartment and out to a small drain--usually located beneath one of the drawers at the bottom of the refrigerator. If the drain becomes clogged or blocked, the water may back up. To fix this problem, clear the obstruction. Another cause may be the following. The refrigerator may have doorframe heaters to evaporate any condensation on the cabinet frame. If your refrigerator is equipped with a switch inside that says ?energy saver? or something similar, while running in that mode the door heaters are disabled. Turn the switch to the opposite setting and wait 24 hours. If the condensation disappears the problem is solved. please do not forget to rate the solution.thanks.
Jun 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water on Floor Outside Freezer (Side by Side)
take a wire and run it through the drain until there is no resistance and then put hot water into it.
Mar 06, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Whineing noise\and leak on freezer side in the bottom of it
yes the water in the bottom is because your drain tubing is cloge thid is the small hole in the frezer area defrost your fridge use a wire to clear out the debri that clogs your tubing the water should drain in the pan where the compressor is thanks from gilles
Feb 10, 2009 | GE GSS20IEP Side by Side Refrigerator
Water problem
Sounds like the  drain for the defrost system is plugged....
Oct 10, 2007 | GE J Series 20.6 cu. ft. Top Freezer...
Refrigerators Logo
802 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
