Question about Mitsubishi WS-55513 55" Rear Projection HDTV
Fuses Are these fuse the three items with white porcelain centers? Check continuity?
  • Stevo94510 Apr 27, 2008
    I have check these fuses out and they all read good, but that reading was taken it place. After looking at the capacitors again, I do notice a bit of a "bulge on top. If these are supposed to be flat on top, mine aren't. Also checking these capacitors in place shows a different reading from one to another, making me think they might be suspect. Thanks for the help, Stevo
You guys are awsome. Just received the new capacitors and installed yesterday. The TV fired right up and works perfectly. Thank you so very much. Steve
Posted on May 08, 2008
    Genius:
  • 1,694 Answers
What are the location # 's on cicuit board?
Posted on Apr 25, 2008
  • Vista Electronics Apr 25, 2008
    Yes....white porcelain 4 amp....should check shorted,if good.
  • Vista Electronics Apr 28, 2008
    Change all four caps with 25v 1000mf 105 degree replacements.
Center high stop lamp works, two lowers don't. All fuses good
With a test lamp, have you got power on the fuses and then have you got power to the brake lamp cluster or brake switch?
Feb 28, 2014 | GMC Cars & Trucks
Push button is not working on Kenmore I'm trying to troubleshoot the promblem
There are three common problems to cause this . One check the fuses two check that the belt is not broken and three if it is a whirlpool built dryer there is a small thermal fuse on the back of the air housing. It looks like a small white bullet. Short out the wires if you have no meter. Make sure they are not touching the case and try. If the dryer starts replace the fuses and make sure the vent is clear.
Sep 23, 2012 | Kenmore Dryers
My Kenmore 400series 6942 electric dryer works, but doesn't get hot. Pulled the heating element had it tested. It shows good. Had three other relay/fuses tested. They show good. It has to be easy enough...
This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. seth765.jpg if there is no heat then one of the thermal fuses is bad you will need to check the continuity on them and replace the one that does not have any continuity
Jan 20, 2011 | Kenmore 400 6942 Dryer
KENMORE GAS DRYER NOT HEATING UP
Hi
Thanks for using FixYa. No Heat issue in dryer is usually caused due to three things mainly: Thermal Fuse, Wiring Harness and/or Heating Element. Start with checking the Thermal Fuse which ismounted inside the back cover panel to the exhaust duct and is mounted in white plastic housing. If thats fine then the Heating Element should be checked. Please do revert for further assistance.
Thanks
Rylee
Apr 17, 2010 | Zanussi TC180W Electric Portable Dryer
Having applied WD40 into the fuse box to clean it, now the indicators, heating fan and MAIN COOling Fan do not work on my 1985 Escort XR3i Cabriolet ! I have changed the fuses but the three items still do...
a bad thing to do. The oil will stop continuity to your circuits. Disconnect the ground cable to the battery and flush the oil out with solvent and let dry thoroughly overnight or blow dry with an air hose till dry and let stand for an hour. Now you can start at square one again to see what your problem may be if so
Feb 06, 2010 | 1985 Ford Escort 1985 4 Door
Maytag Dryer model number PYE2300AYW will not start.
check your fuses in the dryer their is only one fuse that could shut down the whole dryer like that. Open back panel and get a volt meter and check for continuity on the fuses. HOW? first un plug it then open back then you will see the heating element their are 2 fuses on the heating element take off wires and check those.Then if those are ok look down thier is another fuses its long white with 2 wires comming out of it with a black center that should be your problem check it repair it run it . GOOD LUCK
Oct 12, 2009 | Maytag Dryers
All three passanger tail lights went out on 2002 Avalon
check the bulbs first they may be burnt out, once you confrim the bulbs are good turn the lights on and check for power at the green wire and the green/white wire. and check the white/black wire it is the ground wire.
Apr 19, 2009 | 2002 Toyota Avalon
Blows bothe fuses on power supply bd. b- shorted
The transistors you need are 2SD2560 and 2SB1647. (either you miss-read the D for a B or it was a typo) You can get them at: www.mcmelectronic.com
2S is a prefix on all Japanese transistors.
The 010 is a date code
Also check for open resistors from the base of those transistors and the dual emitter resistor (large white three leg resistor .22ohm)
Feb 28, 2009 | Sony STR-DE945 Receiver
Dryer operates but doesn't heat
If the power to the machine is OK then check these items.......
Before you begin, UNPLUG DRYER.
Remove bottom access panel by using a putty knife to depress panel clips (item 46).
Check the High limit fuse and heater for continuity. Heater (item 14) <20 ohms and HI-limit (item 47) <0.3 ohms.
If the heater or HI-Limit has failed it may be that the exhaust air flow has become blocked or restricted. Check the hose in the back of the machine for crushed hose. If OK, the vent pipe may need cleaning... check out www.linteater.com for vent cleaning info.
If you need further assistance please let me know..
Regards
reg501
The FixYa Team
Jun 22, 2008 | Dryers
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
44 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
