Question about Sharp AL 1631 Copier
Sharp al 1631 h4 - Sharp AL 1631 Copier
    President:
  • 2,072 Answers
Press # * c * the machine will enter diagnostics. Then enter 14 and then press start, you may have to enter 1 then start.
Posted on Aug 03, 2010
  • Rick Kasper Aug 11, 2010
    if the button is a p on your machine then press P * C * then enter 14
  • Edwin Martens
    Edwin Martens Aug 11, 2010
    Your guessing. Please do not reply unless you KNOW the machine. It is C, exp mode key, C, exposure mode key on the 1631.
SOURCE: Sharp AL-1631
try this. Press C (cancel), Press Auto, Press C, press Auto
Enter 14 (code) e Press Print (green)
It´s a code to cancel H4, if it´s don´t work, send me e-mail to montgomery@brturbo.com.br
Posted on Feb 15, 2008
  • 29 Answers
SOURCE: Sharp AL-1631 coper - toner problem
the problem in your machine is on the drum unit there is a arching on the mc unit.located in the upper portion of the drum unit.if you have an old drum unit try to install it again just for testing.and check if ther is a dumping toner again.
Posted on Nov 05, 2008
007tech
  • 95 Answers
SOURCE: Sharp al-1631 misfeed light will not go out
This usually happens when a sensor that detected a paper jam has not reset itself after removing the paper. Make sure that when the jam was removed - all the paper came out and there is/was not a small piece missing that could have been left behind in the copier and is hiding somewhere. If you are sure the paper has all been removed then what could have happened is when the jam was being removed it could have caught on one of the paper sensors. This could pull the little flag that activates the sensor out of place - giving a false paper jam message. there are only a handfull of sensors in the paper path. remove the paper tray and make sure there is no paper stuck behind the tray or in the cavity where the tray goes. look and follow very closely the path the paper takes - look for any sensors/flags the paper would avtivate and make sure the flag moves freely and is not lopsided.
Make sure you also try unplugging and replugging the copier from the wall.
Hope this helps
Posted on May 20, 2009
xptareq2000
  • 1447 Answers
SOURCE: SHARP AL-1631 DIGITAL COPIER SHOWS ON THE SCREEN CODE H4
your copier is problem over temparature.h4 signal is blingking so it is over temparature or it fixed so heater lamp is burning program c photo c photo then press 14 press print key then machine is ready
Posted on Jul 20, 2009
xptareq2000
  • 1447 Answers
SOURCE: Sharp AL 1631 is flashing 1 L. What does that
Dear sir
if your copier scaner is loked then it sound if it no sound then open your copier desktop glass and clean cloth all serface and scaner sensor close your destop glass
  1. fhitting complite
  2. power on
  3. machine is ready
  4. L1 signal is scaner position problen
Posted on Aug 19, 2009
My sharp al 1631 did not make the copi the machine codig is h4
press # * C * the machine will enter diagnostics. Then enter 14 and follow the directions to clear an H4 code.
Feb 06, 2011 | Sharp AL 1631 Copier
I HAVE A SHARP AL 1631, IT SHOW ME A 4 CODE, HOW CAN I TO SOLVE THIS
their is no A4 code,if you mean H4 try to reset it by simulation 14
Dec 26, 2010 | Sharp AL 1631 Copier
My copier is flashing the code H4
I have a tip posted here on Fixya that resolves this problem easily.
Here is the link:
http://www.fixya.com/support/r4376849-sharp_al_series_copier_h3_h_3_code_reset
If it works for you then please return here and provide feedback for me that I was helpful.
Thanks
Jul 25, 2010 | Sharp AL 1631 Copier
Copier flashing "H4" code
Hello sir;Follow these steps within 4 seconds; press 'clear', "exposure" ,"clear" "exposure" then enter 14 hit print, should be OK.
Jan 30, 2010 | Sharp AL 1631 Copier
H4 code flashing. turned it off and back on...still flashing. anything else we could try?
See my tips and tricks solution for this problem on this site. Just search for Sharp AL series H4
Jan 25, 2010 | Sharp AL 1631 Copier
Sharp AL-1631 Fuser Unit
The fuser codes are only H2,H3 and H4. To reset , press C, Exposure, C, Exposure.Display goes off enter 14 press print.
Nov 05, 2009 | Sharp AL 1631 Copier
SHARP AL-1631 DIGITAL COPIER SHOWS ON THE SCREEN CODE H4 WHEN SWITCHED ON.
Hello sir; You do need following procedure to reset; once begun procedure must enter within four seconds; Press "clear", "exposue mode", "clear", "exposure mode" these 4 keys within 4 seconds, then enter 14, then press start, should take care the problem.
Jun 12, 2009 | Sharp AL 1631 Copier
Sharp al-1631 copier wont copy
It probably the toner cartrisge is empty or if there's an error code H4, the heater lamp is spoiled
Apr 02, 2009 | Sharp AL 1631 Copier
H4 problems
Try to reset the error code by pressing : C exp1 C exp1 14 start. if the problem still occur then you should change the heater lamp
Apr 01, 2009 | Sharp AL 1631 Copier
Sharp AL-1631 copier problem
press copy. clear, copy, clear.( you have to press it fast )
the machine will switch off and then press 14 then start.
the copier will reboot to its normal state.
Apr 28, 2008 | Sharp AL 1631 Copier
Sharp AL 1631 Copier Logo
256 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
