Question about Freezers
I have a Caravell ice cream freezer (don't know the model number) but it has a 7 napoli display cabinet. The display cabinet seems to be running a bit warm although the freezer unit underneath is -25 c. There is a small control panel at the rear of the unit that displays the temperature and also has function and set buttons. I do have a manual and am not sure how to change the settings. Does anyone know if the top display cabinet temperature can be adjusted independently of the main freezer storeage unit.
icansurf
  • 72 Answers
SOURCE: Hotpoint FZA50 Freezer not cold enough
try it on max setting. lint clogging up stuff in the back? needs defrosting? low on refrigerant (freon)? call repairman for that last one
Posted on Jul 11, 2007
jaylex
  • 417 Answers
SOURCE: freezer temp display beeping and going through different temps rapidly!
Seems that you may have a faulty temp control switch or it is stuck in position. Check this also make sure that the air vents are clear.
Thanks J
Posted on Feb 16, 2008
tzweeb
  • 318 Answers
SOURCE: my freezer is not cold enough to keep food frozen...
the "e" usually means it has an error. it could be a bad temperature thermistor or a bad control board. the most likely is the board.
i hope you are less then 1 year old as the board can be quite pricey, about 150 bucks.
you could try to unplug the unit for a few minutes and then plug back in and see if the code goes away and returns to the cooling mode.
Posted on Dec 29, 2008
huuum
  • 750 Answers
SOURCE: Sears Kenmore Deep Freezer settings
It sounds like you have a circulation problem.
Spread out the packages so the freezing air can circulate.
  • Check that the condenser fan is on
  • Check that the coils are not covered with lint and dust especially if they are under the freezer.
  • you may need a tech to put freon in the system.
Posted on Apr 07, 2009
  • 358 Answers
SOURCE: I need to know what the numbers mean on the
The highest number is the coldest setting.When you fill it up with food to freeze , set the freezer to the coldest and after everything is frozen .set the control to the middle.
Posted on Oct 06, 2009
How do I hook up to my tv and by pass satellite
What are you looking to connect to the TV? If your TV has multiple inputs, you can connect a DVD player or game console to one of those.
If you only have one input, you can buy a switch that can allow you to change between the satellite feed and the other device.
Feb 02, 2015 | Caravell SFT-61 Ice Cream Flip-Up Lid Top...
Caravell CATF61 can not find temperature control
It's supposed to go to -20! Is there a panel in the side at the bottom? Stat is inside the panel
Mar 31, 2014 | Caravell Freezers
Whirlpool freezer display flashing 1
Hi Rachel
For your door to close properly take off the gasket from your fridge and wash it with hot water. It will be softer and stick to the fridge much easier.
Feb 15, 2014 | Whirlpool 10 cu. ft. Chest Freezer...
Can I tilt the caravell freezer? mod 105010, No 92707015
If you tilt it let it sit over night before plugging it up.
Apr 18, 2012 | Caravell Freezers
The freezer works fine, but it ices up on the inside.
If the ice is clear and hard, the issue is a leak during defrost (if it has such a cycle)
If the ice looks like snow, replace the door gasket(s).
Jun 15, 2011 | Master Bilt Freezer Single Door Ice Cream...
The ice cream gets to hard and we have to take the big cartons out for 2 hrs before we can scoop it. (How can we bring the tempreture up about 10 or 15 deg.?)We can't find any controls on it. We have no...
Hi, I think you have tell wrong model . Please try find out the temperature controller. Your freezer should able to adjust temperature from 0 - 18 Deg. F
Chest freezer of caravell has 2 model i.e :
1. Caravell SST-5213.7 cu ft Chest Freezer With Solid Sliding Doors
  • Durable white powder coated, baked on enamel finish
  • Solid sliding top doors
  • Cord and plug included
  • Self-contained refrigeration system
  • Temp. range 0 to -18 degrees F
  • 13.7 cu ft capacity
  • Heavy duty casters included
  • Dual drain plugs for easy cleaning
  • Environmentally friendly CFC-free R-134a refrigerant and insulation
  • 115V, 4.5 Amps
  • 51 1/2"W X 25 3/4"D x 34 3/4"H
  • One year parts, 90 days labor warranty plus 3 year compressor warranty
  • & 2. Caravell GST-5213.7 cu ft Chest Freezer With Glass Sliding Doors
  • 115V, 4.5 Amps
  • Regards, jay
    Nov 30, 2010 | Caravell 13.7 cu. ft. / 388 liter Chest...
    Ice Cream Server
    It is a dual thermostat unit. You could have a bad thermostat, giving you false readings.
    May 13, 2010 | Caravell 5.5 cu. ft. / 156 liter Chest...
    Freezers Logo
    104 people viewed this question
    Top Freezers Experts
    Dennis Boxerman
    Charles T Nevin
    Charles T Nevin
    AJMAL KHAN
    Are you a Freezer Expert? Answer questions, earn points and help others
