Question about Toshiba Satellite P35-S609 Notebook
P35 S6112 LAN WIRELESS IS NOT WORKING
I HAVE JUST LUBRICATED THIS COMPUTER'S HEAT SINK AND PROCESSOR, SO THAT WE CAN BET BETTER HEAT TRANSFERANCE.
NOW, IT IS REASSEMBLED, I DO NOT SEEM TO HAVE THE WIRELESS LIGHT GO ON?
Have you reconnected the black and white cable that connects to the wireless card located under the same cover as the memory.
Posted on Sep 22, 2009
    Problem Solver:
  • 17 Answers
STEVELAMBERT,
Double check your wifi switch position by taking a small flat head screw driver, and pop it loose and see if the post to the wifi switch is broken, if not properly reseat the wifi switch over the post. If that does not correct the issue, open the memory cover and reseat your wifi card.
PAeasop
Posted on Apr 30, 2008
Lan drivers for p35/g31/g33
I recommend that you state your motherboard make/model; usually drivers depend on that and on your operating system.
You may download drivers (usually) from either your System manufacturer's website or/and your motherboard manufacturer's website.
10.December.2014
Mar 03, 2014 | Intel Pentium Dual-core Processor E5200...
To much heat
If the processor is overheating, check the fan to make sure it is turning freely but does not have sloppy bearings. Make sure the fins are clean. If these are OK, replace the thermal transfer compound between the processor and the heat sink. If the compound is too thick or is dried up and hardened, it will not transfer heat efficiently. I get the best results with a thin layer of silver-based compound - just barely enough to cover the chip evenly. Be sure to clean both the heat sink and processor thoroughly before applying the new compound. Use isopropyl alcohol for cleaning if necessary.
Oct 03, 2012 | NEC Versa A2200 Cooling Heatsink P4
Motherboard processor is heating up even with fan and shuts down computer after 5 minutes
dear alton,
its common problem with your processor heat and its sensor in your motherboard.
the problem is at the cooling system witch is your fan.
cooling system can work properly only if
1. your fan is working.(I'm sure its)
2. the aluminium aloy (heat sink) is capable to transferring heat from your processor (i recommend the original one)
3. thermal paste to joining the surface processor to aluminium aloy (heat sink) is a good grade.
4. the surface of your aluminium aloy (heatsink) is smooth.
if you want read more you can go to. http://www.overclock.net/t/538551/how-to-modify-your-heatsink
hope help.
May 29, 2012 | Asrock Computers & Internet
I turn the compute on and last for 2 minutes and the it turns off itself, I want to know why
Theres not enough information to properly tell you. But I would start with looking to see if your fan turns on when you turn on the computer. If the fan does not turn on then your CPU overheats and the computer will shut itself off. To try and fix this, clean out the fan (hair or anything around the fan motor can prevent it from turning).
Mar 04, 2011 | Toshiba Satellite P35-S611 Notebook
Is there supposed to be any heat sink paste between the processor and fans
Yes, and this is to promote better thermal transfer between components.
According to studies:
Thermal grease is primarily used in the electronics and computer industries to assist a heat sink to draw heat away from a semiconductor component such as an integrated circuit or transistor.
!!!Warning!!!
Over time, some thermal greases may dry out, have reduced heat transferring capabilities, set like glue and make it difficult to remove the heat sink. If too much force is applied the processor may be damaged. Heating the grease by turning the processor on for a short period often softens the adhesion. It is recommended that thermal grease be re-applied with each removal of the heat sink.
I hope it helped you. Rate for this information will greatly be appreciated. Thank you!
Jan 20, 2011 | Packard Bell (181368) Motherboard
My p4 system getting hot
see do one thing check the cpu fan whether it is working properly and is not producing any noise if it is then probably you need to replace your cpu fan with a new one also makke sure that your power supply fan and chasis fan is working as excess heat gets generated in the system they remove it
to change the cpu fan 1.see it will depend on what kind of cpu socket you have pin or pinless for pin-open the plastic clamp on the fan for pinless -unscrew the heatsink
2.remove the heatsink and replace it it will be much better if you replace the full heat sink with a new one .also don't forget to put thermal grease compound for effivient heat transfer in between the cpu and the heat sink contact generally these days heat sinks come with pre-applied thermal componds but still it is recomended to apply it firmly over the cpu before installing the heat sink on it
3.if you wish to install the old heatsink by just replacing the top fan then replace the fan and rub the bottom of the heat sink with a sand paper to make it even and free from dust and oxide apply thermal compond and install it on the processor .plug bak the cpu fan header cable . start your system it will stop overheating..
Dec 05, 2010 | Intel Computers & Internet
Satellite P35-S611 (PSP30U20H001) PC Notebook: what causes the p 35/30 shut down as soon as you t...
The processor is over heating. I have a p-35 s6053 and it used to do the same thing until I fixed it.
Do the fans come on or anything when you first try to turn it on ??????
I'd bet the fans come on strong and then after about 5-60 seconds it just shuts off. let me know if i'm right and I can tell you how to fix it,
May 17, 2010 | Toshiba Satellite P35-S611 Notebook
GA-EP35-DS4 motherboard does not load
is it in warranty..?? if not..
do it if u r a professional..
check the following:
1) the cmos battery (above +3v)..replace with a standby n see..
2) remove/clean dust neatly..dust is non-uniform in nature n may cause jam/short circuitry/excess resistace n many more..resulting an increase in heat..
3) open the CPU Heat-Sink with fan out of the socket..put some "Heat Sink Compound" (available in local electronics chip level spare market) between the cpu/processor and the CPU Heat Sink *** fan..resit/fit it tightly in position..
4) the smps itself may b defective/faulty..check the outputs of smps viz. 0v (black~ground); +12v (yellow); +5v (red, green~ps-on, violet~pg & grey~sb); -12v (blue); -5v(white); +3.3v(orange)..
the 'oscillator and error amplifier ic', or pwm switching regulator circuit..look for defective protector-transformer/resistance(esp 4.7k)/mosfet..
5) ur main/mother board..see with a debug card for mb error..may b short..look for defective capacitors(esp above 1000mfd)/mosfets..go through the mb's south bridge n the circuit lie around atx connector....
..plz give higher priority to step3 & 4 (as listed above) CAREFULLY..
immediately contact ur system admin/vendor....
Nov 07, 2009 | Gigabyte GA-EP35-DS4, LGA775, Intel P35,...
Won't stay running
Update the Bios Driver for the computer off of toshibas website and it should fix it, I had the same exact problem!!! And if that doesnt solve the problem you have a bad battery...
Feel free to Email me with questions at newlook_inc@hotmail.com
hope this helps!! Good Luck
Jeremy
Sep 24, 2009 | Toshiba Satellite P35-S609 Notebook
Motherboard getting hot
check your thermal paste... buy thermal in the computer store, possible your thermal paste already dry and did not transfer heat at heat sink...
can you adjust your speed FSB jumper to reduce the processor speed.
Jan 26, 2009 | Intel Motherboard
Toshiba Satellite P35-S609 Notebook Logo
399 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
