When the hard drive is plugged in it installs on the computer but yet nothing apears in my computer so i cant access it. Is there any way i can fix this problem
    President:
  • 2,571 Answers
You may be getting a drive letter conflict.
Right click on computer(or My Computer in xp)/ Manage / Disk management.
Is your drive showing there? If it is, right click and choose change drive letter, choose any unused drive letter
Posted on Aug 03, 2010
I am not able to access files saved on my buffalo hard drive
Figure out whether you need a hardware or software fix. Look for grinding sounds from your drive or humming that starts or stops. These are signs that the actuator arm and discs are no longer in alignment and your drive is timing out. If it seems as though nothing is wrong with your hard drive, it's probably time for a software fix. Run one of the many software fixes, if you think the problem is related to software. These programs feature on-screen directions, making it easy for you to progress through them. If this works, you don't need to fix a physical problem. Remove the many tiny screws that holds the drive together. Eventually, you'll get to the innards of your drive. Be very careful not to bend or force a piece to go where it doesn't want to. Determine if you've set things straight. Look to see whether anything was loose inside your external hard drive. If you have recently dropped it or traveled with it, it is possible that something came loose. Also check that all the arms and platters are straight and do not appear bent in any way. If they are bent, straighten them with your hands or pliers. Put everything back together and check that everything in your external hard drive is working properly. Try using the external hard drive on another computer. click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb but its not working ports(com&lpt)right click update driver sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts if it still cant be detected or If the hard drive that has failed is the same one that you are trying to recover from might the reason that you are getting this error. This could be an issue where the part of the hard drive you are trying to access is corrupt and not accessible which would explain the reason that it would let you access the other partition. Now I have seen cases where Malware can break the link of a Hard Drive. So let's try a couple of steps. Let's go back in to "Disk Management" Lets right click on the partition that you are not able to access and select "Change Drive Letter and Paths" Now try selecting a new Drive Letter. This will restore the path if it has been broken. There are also Data Recovery programs that might be very helpful to recover your important information. Downloads to Recover Your Files and Save Your Bacon and 10 Best Free Hard Drive Utilities. Some addition links found on Google
http://www.datarecoveryreview.net/
http://www.easeus.com/resource/hard-disk-data-recovery.htm or if its a usb external drive you might need a usb 3 card installed on your computer your computer might not have enough usb output power USB 3 card will provide more power when needed to the device to gain maximum throughput and conserve power when the device is connected but is idling http://blog.premiumusb.com/2010/09/usb-2-0-vs-usb-3-0/ these can be purchased on Ebay cheap and easy to install http://www.ebay.com.au/itm/PCI-e-PCI-Express-USB3-0-Card-new-NEC-720200AF1-chipset-/330608109325?pt=LH_DefaultDomain_0&hash=item4cf9c7670d for roughly $9 or $10free postage hope this helps b>
Dec 08, 2012 | Buffalo Tools HD-CE500U2 500 GB USB 2.0...
Seagate 500GB FreeAgent GoFlex Hard Drive it didn't appear on my computer
RESOLVED!
Just because this starts with the same steps as other solutions does not mean it ends with the same fix.
1. Click Start
2. Right Click Computer: Select Manage.
3. The Computer Management Dialog box will appear.
4. Select the Disk Management Icon located in the right pane of the Computer Management Dialog box.
NOTE: Under volume you will NOT see the Seagate Drive.
5. underneath the volume pane you will see Disk 0, Disk1 and so forth. look for the Seagate drive ... mine was Disk 2.
6. Right Click on the Drive: Select Properties.
7. The "Seagate FreeAgent GoFlex USB Device Properties" will apear. Select the Driver tab.
8. Select the Uninstall Button.
9. Unplug your Seagate external hard drive and plug it back in. This should re-install the Drivers and it should work like it use to.
P.S. Sorry for the bad grammar\spelling.
May 09, 2012 | Seagate 500GB FreeAgent GoFlex Hard Drive
I have asus motherboard product number m4n68t-m. The computer randomly goes black with all my lights running and my fans still working, but nothing else. I've recently put a new hard drive in to see if...
its hard to tell what your computer has.. but i think it might be the monitor and not the computer.. i had a similar problem and it apeared the monitor was broken aswell check your videocard adaptor and the cable witch connects the pc and monitor
Sep 06, 2011 | ASUS Computers & Internet
Hard Drive not accessible, now not recognised by computer
Do you have another computer you can plug it into? The problem could be with your USB. If it is, see what updates you installed and then removed that may have affected that. You can also go to the manufacturers web site and download the original firmware or updated firmware files.
Dec 12, 2009 | Maxtor Hard Drive
Cant access the external hard drive, heck I cant even find it now. I have all my music and photos on it so it did work.
Hello
A few questions that may confirm problem.
Does your computer seem to know that something is plugged in?
Or does it say that it does not recognize the device?
Well, if the computer actually knows that a device has been plugged in, but you just cannot see the device in my computer, here is how you fix that. Just follow these steps:
Control panel
Administrative tools
Computer management
Storage
Disc management
Now you should see your device presented in the schematic below.
Right click on the device and assign a new drive letter.
If your computer states that it does not recognize the device, try plugging it in one of the back USB ports of the computer. Please rate this.
Best regards
Sep 30, 2009 | Western Digital My Book Home Edition 500...
Acer M1100 Desktop w/ a different HDD and Optical will not boot
Disconnect the hard drive and dvd from the motherboard
Power on
If you get video and cmos access power off and connect dvd
repeat and connect hard drive
getting video and cmos access has nothing to do with the hard drive...with no hard drive or optical drive you still would have access to cmos
go 1 step at a time to find bottle neck
Jul 02, 2009 | Computers & Internet
I plug my seagate into the computer. it turns on but then nothing
Plug one usb into your computer and the other end into the drive.
If the light comes on, all is good. The computer should install the device for you automatically. To access the drive, go to My Computer and double click on the Removable Drive. Now you can transfer files.
Hope this helps
Chris (ziraffa)
Dec 28, 2008 | Seagate Free Agent Go Small 12 GB USB...
HELP! My ps2 cant detect hard drive!
DGR8njct, Get a USB 2.0 to SATA/IDE/2.5/3.5 Hard Drive Adapter Cable . This will allow you to access the Hard Drive from a computer USB port. It doesn't sound good for you. If you do not want to get an adapter like I suggest, you can install the hard drive in a computer as a slave drive, and see if you can access the data. www.playstationclinic.com
Oct 01, 2007 | Sony PlayStation 2 (PS2) Console
Computers & Internet Logo
26 people viewed this question
Alun Cox
David Payne
David Payne
