Question about IWC Spitfire Pilot Mark XVI Steel IW325505 Watch for Men
Watch running fast about 5 seconds per minute. it had stopped because didn't wear it for a few days. didn't wind it at all. just set time and it started but now running way too fast. any thoughts? benjamin.huneke@ms.com
    Genius:
  • 1,970 Answers
Mcdevito75 here, Depending on how new your IWC watch is, without running at all can be bad in the way that the oil in the movement can settle and more or less drain off the moveing parts, and without the oil distributed thru out the movement, your watch could run a bit fast. Re--starting your watch as you"ve done will help, re-distribute the oil, in the mean time switch your watches position on your wrist every couple of hours, crystal on top of wrist, then 2--3 hours later crystal turnned under the wrist, it may take a day or two for the condition to correct itself, if I'm right. Hopefully you have a warrantee with IWC on your watch. Hope this helps.
Posted on Aug 03, 2010
Testimonial: "good feedback. hopefully will work "
Watch stops after wearing for a few hours
Self winding watches need motion ( wrist twist) without they can stop. Sometimes just shake your wrist for a few seconds. I purchased a winder box for times I don't wear. ( Amazon)!
it is belt driven winder, rotates watch 5 minutes every hour.
Apr 21, 2015 | Rolex Submariner Oyster Watch for Men
Can the independent 12 hour hand be set and if so how?
You need to watch this video its given how to set time in Rolex watch's :
Sep 20, 2008 | Rolex Explorer II 16570 Wrist Watch
Tip
"Self-winding" Automatic mechanical watches that don't run.
Many questions are posted about watches that don't run or just run for a few seconds or minutes. If it's a quartz/digital watch you need to have the battery replaced. If it's a mechanical watch - even a high end "perpetual" watch like a Rolex, you'll need to manually wind it. Self-winding, or automatic, watches have a rotor in the case that spins as your arm/wrist moves throughout the day. The motion of the rotor winds the watch. When the watch is left unworn for a day or you spend your day just reading a book or otherwise remain inactive, the watch runs down. To restart it and provide a power reserve, simply wind the watch manually by turning the crown clockwise about 40 turns. It should run fine as long as you stay active. If you don't wear the watch everyday and don't want to have to wind and reset it every time you put it on, you can buy a watch winder to keep it moving. You can find them for under $100 on ebay for basic models and for more money you will see ones that wind multiple watches and have nice decorative cases.
on Apr 15, 2010 | Watches
Hi iv had my rolex watch for 2years now , not worn it for round just over 1year and its stopped working, any suggestions why? as i need to get it working because i am thinking of selling it and putting the...
This watch is self winding and will stop after 2-3 days if not worn.
To wind it up,shake it from side to side gently for a few minutes (about 100-200 times) and this should wind it up sufficient to make it run for some time.
These watches thrive on being used and if you wish to maintain its operation, wear it at least every other day.
Mar 06, 2011 | Rolex Day-Date President 118238 Wristwatch
It stops working it will not stay on the correct time
This watch is a self winder and thrives on being used. When fully wound, they should run for 2-3 days and if they run right down then they need to be wound up and used to maintain operation.
I am not sure if this watch can be manually wound but try turning the crown in a clockwise direction. If this is not possible, to wind it up, wave it from side to side for a few minutes (200-300 times) and his should wind it sufficiently to run for a day or so.
Wearing the watch daily is sufficient to keep it going.
Feb 18, 2011 | Rolex Daytona 116520 Wrist Watch
WILL RUN A SHORT TIME THEN STOP
mcdevito75 here, I would imagine your Rolex is an automatic, not all Rolexes are. After 2 days not running at all your Rolex needs a very good start not just putting it on and that"s it. Sorry to say!, I would ask you to do this, With your watch close to your ear I would like you to wind the watch, listen closely, if you haer a clicking or a drag sound you know you have to give about 20 winds to your watch before you put it on, after the 20 winds the automatic takes over. If the stem just spins and no sound, Click or drag, then your rolex is fully automatic, after you put it on you"ll have to ttwist your wrist back and forth to get the automatic moveing to wind your watch somewhat. Twist your wrist back and forth maybe 20--30 times, this way your watch has an initial wind and as you wear it the winding continues with the motion of your wrist, after it"s wound pretty good if it stops and goes, have the watch serviced.
Jul 01, 2010 | Rolex Day-Date President 118238 Wristwatch
Hi - took it off for 36 hrs - never had an issue - oyster submariner not moving now ... thanks for your help
This is a mechanical auto-wind watch. It self winds when worn. But if taken off for a couple of days it will have stopped and won't start running again unless it is wound.
Put it on and wear it for a few minutes. This will wind it enough to start it running again. Then set the time and wear it and you'll be fine.
Hope this helps.
Ken
Yellowstone Watch Inc.
www.yellowstonewatch.com
Oct 27, 2009 | Rolex Day-Date President 118238 Wristwatch
I just purchased my son a Seiko Divers Automatic 200M watch for graduation. For the first few days, the watch worked, but ran about 15-20 minutes fast. Now it won't move at all? Tried wearing it for 8...
Hi mtrahan99. My advice is to take it back and get it replaced, particularly if you have only had it a few days. If they won't exchange it or refund you, get a repair under the guarantee. Automatic watches (and Seiko actually make some very good ones) don't need to be worn all the time to wind them, and the fact that it ran so fast and has now stopped would indicate something major like problems with the mainspring. Return it! Hope this helps; Eagle58
May 19, 2009 | Seiko Divers Automatic watch
Keeping 2008 breitling cockpit watch running
You have to wind the watch till it is fully wound (significant resistance should be felt).
It doesn't matter how many times you wind it (1 or even 40) - what matters is the strength of the spring.
Do as follows:
At any time in the morning wind the watch up till you feel there is no more winding left (should be quite tough). Memorize the time you did it.
Leave the watch (or wear it) till it stops completely.
Count the hours your watch did work (from the time you wound it).
Now you know exact power reserve for your watch.
It is advised to wind the watch 2-3 hours before the power reserve is gone.
Rate me.
, please.
Apr 08, 2009 | Breitling Navitimer A2332212 G5 431A watch
Watch goes slow when wearing it but keeps time when not wearing it Because I started having a problem with an old reliable Acqua quartz analog watch running slow,  I replaced it with a new Timex quartz...
There is nothing wrong with your watch. Probably it's the one measuring heart rate and pulse (heart beats per second).
Use your users manual to set the watch.
By the way: Timex is one of the worst watch producers.
Jan 07, 2009 | Watches
IWC Spitfire Pilot Mark XVI Steel IW325505 Watch for Men Logo
524 people viewed this question
Top IWC Watches Experts
Ansel Alberto
Ansel Alberto
Marvin
Marvin
Are you an IWC Watch Expert? Answer questions, earn points and help others
