Question about RCA RT2770 Theater System
RCA RT2770: Problem: I power the unit on, it shows the "WELCOME" text, and get stuck there. No volume control, no input selection control, no sound, nothing. Checked internal fuses/boards for anything burnt, bad contacts, etc. and nothing.
Yea,I hate to tell you this but this unit does this to alot of people.Mine did this I called,and they said send it in,and they would fix,I got it back after a little over a month,pluged in the fixed one,and it worked for a short time,and started doing the same thing.My unit is 10 months old,and has been broke or in their possesion for about 3 months.I wouldnt recomend buynig another one!!!!
Posted on Dec 31, 2010
  • skulivan Jul 13, 2011
    I whole-heartedly agree with you 'rodale'! For the amount of money investment and working time of this unit its a disgrace to the electronics business. RCA should be able to fix it for free within a reasonable time or replace the unit entirely. If they can fix it, then they obviously know what the problem is (or maybe not considering yours quit on you after they so-called fixed it). I feel that RCA should acknowledge the problem(s) with this unit and recall all of them from the stores, especially Walmart which is where most saving-conscience people shop. A deal is only a deal if the product lives up to the standards of the manufacturer.
    New Friend:
Mine does the same thing. I found that if I plug an ipod or another unit into the USB port in the front and send input signal that way it seems to jump start it but I then still have to tap the on button or push many of the input selection buttons then it will work. No my problem is the unit "faulting" itself off after 15 minutes. I have removed most of the speaker wires and it may seem to work with less speakers or there is a problem with a one of the speakers causing the fault to occur.
Posted on Nov 24, 2012
I have this same issue. Just started tonight. Any answers yet?
Posted on Dec 17, 2010
RCA RT2770 Sub-woofer sound doesn't come
The sub should generally have its own power supply, is it plugged in ???
Feb 16, 2016 | RCA RT2770 Theater System
My RCA RT2770 has two problems. 1: The volume lowers itself. 2: Surrond sound is echoeing.
You wanna try changing the mode of sound. And for the volume, try contacting RCA to figure that out. Could be interfeiring remote signals. Also, you can post a question, just like this, on their support website. Click Here for that website.
Jan 14, 2008 | Audio Players & Recorders
Receiver is stuck on welcome screen...can this be fixed?
Yes. It can be repaired. You may have an amplifier or microprocessor(computer inside your RCA) bad. Please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
Aug 30, 2015 | RCA RT2770 Theater System
RT2770 cuts out above a volume setting of 30.
Bass and other settings may be set too high and are overdriving the unit.
If all else fails try the old unplug it for a while and then plug back to see if that helps.
What if anything else is hooked up at the same time to this system?
Jun 14, 2012 | RCA RT2770 Theater System
Have an RCA RT2770 unit and it will not turn on either by remote or unit itself. have all components plugged in and still nothing. any suggestion?
Possible this is a shut down due to a protection cut off.
Need to check the outputs and the power supply to confirm,
Sep 30, 2011 | RCA RT2770 Theater System
Owners Manual for Kenwood Car radio Model KDC-M4527
KDC-M4527
CD Receiver with WMA/MP3 decoder Built-in
Audio Features
- 4 x 50 watt maximum output power by MOSFET Power IC
- 1 RCA preout, 2 Volt
- Separated tone control: Bass/Mid/Treble
- Source tone memory
- Balance/Fader/Loudness control
- System Q: Sound control with pre-programmed tone curves
- Auxiliary input with optional unit (CA-C1AX or KCA-S210A)
- Attenuator (-20dB) with smooth volume return
Tuner Features
- 24 presets: 18 FM, 6 MW/LW
- K3I clean reception Tuner
- Radio Data System (RDS) with Radio text
- Auto memory entry (AME)
- Up/Down seek tuning
- Local Seek
- FM Stereo/Mono selector
- Tuning mode : Auto1/Auto2/Manual
- DAB reception with optional unit KTC-9090DAB
CD Features
- CD-R/RW compatible
- 8 times over-sampling
- 1 bit D/A converter
- S/N ratio: 105 dB
- Dynamic range: 93 dB
- Channel separation: 85 dB
- MP3 decoder with ID-3 Tag display
- MP3 decoder MPEG-1/2 Audio layer-3
- WMA decoder: windows media audio
- CD-text
- Random/Repeat/Scan Play
Changer Features
- Dual changer control capability (CH1/CH2 & AUX)
- CD-Text with compatible units
- Disc Name Preset System with compatible units
- Disc & Track repeat
- Disc & Track scan
- Disc & Magazine random play
General Features
- Removable faceplate
- Protection case for faceplate
- Disabled System Indicator (DSI)
- Mono Colour LCD display
- 14 segments x 8 characters
- White LED display backlight
- Selectable key illumination (red or green)
- 24 hours clock
- Auto Dimmer
- 2 way telephone mute
- All off select (20/40/60 min.)
- Built-in fuse/coil
- ISO A/B connector
- Remote sensor for optional remote control unit
- OEM steeringwheel remote hardwired connection
thats the most i could get go here http://kenwoodusa.com/Contact/ and have them send u one hopw that helps.
Oct 01, 2009 | Kenwood Car Audio & Video
RCA RT2770 receiver won't turn on
it is a high power switch to get it fixed it will cost about 100 $
Jul 08, 2008 | RCA RT2360 System
Connecting RCA RT2770 to PC
Yes. Take the output from the sound card and connect it to one of the tape inputs. Note: you should use the "line out" jack for this.
Dan
Mar 27, 2008 | RCA RTD300 DVD/VCR Home Theatre System...
Auxilary RCA inputs have no volume control
Your problem stems from the fact that the CDA-7892 is not equipped with an RCA aux-input jack. If you're plugged into RCA connectors at the back of the head unit, they're outputs, not inputs. The sound you hear is just feeding back through the outputs and into the head unit's amplifier. If you want to play your iPod through this head unit, you need to purchase either the auxiliary input adapter (KCA-121B) or iPod adapter (KCA-420i).
Mar 15, 2007 | Alpine CDA-7892 CD Player
RCA RT2770 Theater System Logo
946 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
