Question about Panasonic PT-LB10SVU Multimedia Projector
After a few seconds the lamp light began to blink red, its a panasonic pt-lb10svu, show no pic at all has a new lamp
    President:
  • 567 Answers
Hi, Replacing the lamp in a Sharp LCD projector requires the lamp indicator to be reset. When the lamp needs to be replaced, the indicator becomes red. Resetting the counter for the lamp hours to zero will also reset the indicator to green.
  • Attach the power cord to the projector and plug it into an electrical outlet.
  • Step 2Locate the buttons on the top of the projector and simultaneously hold down the "Enter", "Menu" and "down arrow" buttons, then press the "Standby/On" button.
  • Step 3Continue holding all four buttons depressed until the lamp indicator light begins flashing green.The counter is now reset. Zero hours will now be displayed on the screen.
  • Posted on Aug 03, 2010
    Panasonic pt-50lc13 won't show picture. Blinks green when turned on can hear lamp clicking then goes off to red blinking for a few miniutes then shuts down to just red . Can u help me out please?
    sound like your lamp is bad ...Panasonic TY-LA1000 Lamp Replacement...Ballast Repair Kit for Panasonic PT-50LC13 some time the ballast go bad as well to hear bouth part number one lamp and 2 ballast I hope this help you..
    Nov 19, 2013 | Televison & Video
    Panasonic PT-52LCX66 blinks green then red lamp light comes on
    Replace the lamp cartridge. You can get the replacement DLP lamp from www.tvrepairworld.com and the lamps come with installation instructions
    Oct 27, 2012 | Panasonic PT-52LCX66 Projection Television
    The projector would not turn on and had a flashing red light for the lamp. Knowing it was an older projector when we rented the building I purchased a new bulb for this projector. When I put the new bulb...
    PROBLEM :-The power supply of the projector is faulty there is a transistor witch is switch 15 volts for the lamp drive board.
    SOLUTION: Remove the upper cover with 6 screws back side of the projector.
    remove main board and lamp cover with 7 screws.(show in the picture)
    remove upper cover of the power supply and lamp drive unit with 3 screws.
    remove power supply unit with 4 screws and 3 connectors and put face down on the table.
    now you find the transistor no Q107 and replace with the transistor no 2SB710 is and surface mounted compunent(show in the picture)
    fix it all as you open.
    power ON the projector and enjoy
    (doing very carefully This is a technical job)
    Feb 05, 2011 | Panasonic PT-LB10SVU Multimedia Projector
    My PT-D5500U will show the red light when the power is plugged in, when I turn on the other power the power light will go green for a moment and then start blinking red. No lamp comes on and the fan gets...
    How many hours are on the projector? I would say that you need to change lamps first. Unfortuantely, this series of Panasonic is known for lamp and lamp circuit issues. There are runs of bad lamps...try 2 new lamps if possible or consult an authorized service center.
    Good Luck
    Aug 11, 2010 | Panasonic PT-D5500U Multimedia Projector
    The green light blink for a while and then shuts off and the lamp light blinks once red???
    The green blinking lamp means that the TV is getting ready to start the lamp, and then one red LAMP blink means the lamp will not start. You may need a new lamp (Part TYLA1001.)
    If a tech confirms this, and you can source the part, you can find TYLA1001 installation instructions here to save a few dollars, and PT-52LCX66 lamp timer reset steps here.
    I hope that helps.
    Mar 20, 2010 | Panasonic PT-52LCX66 Projection Television
    Panason PT-50LC13 TV won't come on, light blinks green then red
    Ballast failure is more that likley the problem. Is the lamp light blinking,...once every 5 seconds? Discontinued part and can only be purchased used or rebuilt. Rebuilt units are available, check Ebay. Have a service type person confirm problem before throwing good money after bad!
    Jan 03, 2010 | Panasonic PT-50LC13 50" Rear Projection...
    Panasonic PT-LB10SVU green light flashing,then orange,lamp light
    i just replace the lamp, and don't have any light coming from lens,starting green (after a few seconds,green become to flash2_bing.gif), then turning on orange and lamp light flashing...please i need help, fan working perfect...i don't have a remote,is a problem, or not
    Feb 25, 2009 | Panasonic PT-LB10SVU Multimedia Projector
    Flashing Green Power on light not picture
    Last Saturday evening, I experienced the exact same behavior on my Panasonic PT-52LCX65; it shut itself off without warning. I turned it back on, and it shut itself back off after about a minute, and the red "Lamp" LED on the TV began blinking.
    I never got any warning message that the lamp was about to go out, but I've just replaced the lamp and now the TV is working just fine. We had to mail-order the new lamp, because neither H. H. Gregg (where I bought the TV on "Black Friday" 3 years ago), Fry's Electronics, nor Best Buy carries the part locally.
    My wife found the new bulb WITH its holding apparatus for something like $120 online, roughly half what other sites were charging. We paid roughly $55 for UPS Next Day Air. The first bulb that was sent arrived broken (some UPS rep apparently thought "Fragile" meant "Shake and Drop"), but the company we ordered from cheerfully rushed us another one, and the second one was in much better shape. (Panasonic doesn't pack these replacement bulbs very well; there's a heavy bulb with a lot of air around it that Panasonic doesn't fill.)
    More details available if anyone wants 'em. Hope this helps. -- ChuckE
    Nov 03, 2008 | Panasonic PT-52LCX65 44" HDTV
    Red power button & "lamp" indicator blinks
    Having similar issue with my PT-44LCX65. Lamp blew and replaced it (last month), never figured out how to reset timer. Now red indicator light blinks once every 5 seconds and after about 4 minutes TV goes black.... Any ideas?
    Dec 26, 2007 | Panasonic PT-50LC13 50" Rear Projection...
    PT-60LC13
    there are fans inside tv need to make sure they are clean and free of dust
    Nov 27, 2007 | Panasonic PT-50LC13 50" Rear Projection...
    Panasonic PT-LB10SVU Multimedia Projector Logo
    476 people viewed this question
    Top Panasonic Office Equipment & Supplies Experts
    Norman  J Weimar Jr
    Norman J Weimar Jr
    Mitch S
    Mitch S
    Level 1 Expert
    jasbo
    jasbo
    Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
