Question about DeLonghi DN25G Dehumidifier
DeLonghi DN25G unit - is running, however, not removing moisture from the air. Temperature is about 86 deg. & humidity approximately 76%. Any suggestions?
2 Suggested Answers
  • 340 Answers
SOURCE: Moisture not collected
low on freon is the compressor running?
Posted on Jun 18, 2009
Dehumidifier runs but collects no water.
There are 5 basic, yet solvable reasons for what you described. Please pay particular attention to numbers 1 & 2..
1. The humidity extraction level is set to HIGH. Lower it to 32-35%.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor (aka Humid-i-stat) has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
I hope this helps you to troubleshoot & solve the problem. Thanks for choosing FixYa.
Aug 23, 2011 | DeLonghi DE500P Dehumidifier
My dehumidifier no longer takes moisture out of the air can it be repaired to work again
Maryann, your uinit may not need to be repaired. As, there are 5 basic, yet solvable reason for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you have an analog unit
set the humidity extraction level on Maximum.
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
I really hope the above information will help you to troubleshoot & solve the problem without having to make repairs. Thanks for choosing FixYa.
Aug 14, 2011 | DeLonghi DE40P Dehumidifier
DE' Longhi Dehumidifier - Model: DH=25 - Water does not empty into bucket.
If you're saying the dehumidifier is not extracting moisture from the air?
There are 5 basic, yet solvable reason for this. Please pay particular attention to numbers 1 & 2..
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If yours is a manual unit, turn
the control knob to Maximum.
problem.
I hope this helped you to troubleshoot and solve the problem.
Jul 14, 2011 | DeLonghi DH-25G Dehumidifier
Does not collect water in bucket but runs all the time
Does it have a filter?
http://whirlpool.custhelp.com/app/answers/detail/a_id/953
also:
It may be that the humidity level or temperature in the room where your dehumidifier is located is too low.
When the outdoor temperature is below 50 F, the indoor air will be dry even when the air inside is warm, therefore when it's cold outside the dehumidifier may collect little or no water.
Air conditioners will also remove moisture from the room, even if it's hot and humid outside, resulting in little or no moisture collecting in the dehumidifier bucket.
Some dehumidifiers have a deicer which turns off the compressor but keeps the fan running. When the compressor is off, moisture is not removed from the air. The deicer turns off the compressor when the room temperature is cold.
Some dehumidifiers do not have a deicer. If the room temperature is low enough, ice may form on the evaporator coil. The ice prevents the dehumidifier from removing and collecting water. If ice forms on coils, unplug dehumidifier until ice melts and room temperature rises."
Jun 21, 2011 | Whirlpool AD25BBK Dehumidifier
My Kenmore dehumidifier has stopped drawing water from the air to the collection receptical. Fan still runs at high and low speeds.
A couple of things may be happening: The humidity extraction level may be set to high and it can't extract any humidity at that level. Reset/Lower it to 35%. The fans on most dehumidifiers run almost constantly (designed that way) so that it keeps moving the air around. If the sensor picks up a higher humidity level than what it's set to maintain, the compressor will turn ON. This is particularly true, if you operate the unit in continual mode, rather than a timed mode. Also, a dirty or clogged air intake filter, hinders the units ability to remove humidity/moisture.
In addition, operating the unit is ambient air temperature of between 40 & 60 degrees F, causes the unit to struggle to dehumidify the air and the fan to run continuously. Obstructing the air flow around the unit, will also cause it to not function as it should. Maintain a minimum of 12" of free air space around all 4 sides of the unit.
Hope this helps you troubleshoot and solve the problem. Please let me know.
May 28, 2011 | Kenmore Dehumidifiers
The motor runs but no water collects in the bucket. olfi've had it running for hours.. please help. it's only 13 mod p
mempandora, the humidity level that you set on the unit may be to high. In which case the unit will only maintain that level, rather than remove any moisture/humidity. Lower the setting to 35% or minimal, if your unit does not have an LED display. In addition, the air intake filter probably needs cleaning and the coolant coils need to be wiped down and cleaned. The latter is the only part that will require some partial dismantling of the dehumidifier's cabinet. Also, it is imperative, to maintain a minimum of 12" clear air space all around the unit. And finally, the ambient air temperature at floor level may be affecting the operation. If the temperature is between 40 & 60 degrees F, the unit struggles to sense humidity. This is particularly true in a basement. As, the air at the floor is colder than the air temperature.
I hope this helps you to troubleshoot and solve the problem.
May 26, 2011 | Haier 45-Pint Dehumidifier
Just wanna know how to set the temperature on it
dehumidifiers do not have a temperature control, rather, they have a humidity control. usually you set the humidity control to go off when the level of moisture in the room reaches normal (approx. 25-35% winter;38-55% summer). Best way is to run it at full on for 1 to 4 days (until you know the moisture level is how you want it), then turn the knob until the unit goes off . This will be the ideal setting. Goodluck<Macgivor
Jan 16, 2010 | DeLonghi DDE40E Dehumidifier
DeLonghi DEN500P Dehumidifier Humidistat
I have the delonghi DEN500P and the unit runs but does not condense any moisture? The appropriate buttons have been set to bring the unit humidity setting well below humidity in room
Aug 03, 2009 | DeLonghi Dehumidifiers
Jun 18, 2009 | DeLonghi DE400P Dehumidifier
Works well but
Yup, they eat energy.
An electric dehumidifier includes a refrigeration cycle that is very similar to a window AC units and refrigerators. They cool the air in the basement to condense and collect water and remove humidity, heat the air as a required consequence of the refrigeration cycle and dump it back to your basement.
Two sources of humidity in basements include warm outside air that naturally cools due to below grade earth contact and water passing from the ground though the floors and walls and evaporating into the basement. Dehumidifiers do most of the work in the summer when higher temperatures outside enable air to hold more water content.
In the winter, cooler outside air contains less moisture by weight eventhough it may be raining and the relative humidity in basement will be less because the air is warmed relative to the outside. The lower moisture content in the winter also absorbs the water passing through the walls and floor.
From an energy perspective, you may want the humidity set NOT below 50%. This will keep humidity below the level mold desires, but prevents the dehumidifier from doing more work and eating more energy than needed. A cheap battery powered temp/humidy meter left in your basement will help. Sources that include the "mold triangle" (temperature, water & food) often separate fact from expensive hype.
If the dehumidifier doesn't keep up, consider adding a moisture barrier to the basement walls and floors such as Dry-lock and floor paints to ****** moisture entry. Moisture barriers act very similar with water as insulation does with heat. They don't eliminate the need for a dehumidifier, but they reduce the work they do and energy they eat.
Oct 02, 2008 | DeLonghi DH40P Dehumidifier
DeLonghi DN25G Dehumidifier Logo
21 people viewed this question
Top DeLonghi Dehumidifiers Experts
dennis lewis
Level 1 Expert
Are you a DeLonghi Dehumidifier Expert? Answer questions, earn points and help others
