Question about Avanti MO7180TW 700 Watts Microwave Oven
I have a m-07280tb 0.7cu ft microwave that starts beeping suddenly and the "clock enter time" prompt comes on but nothing happens when i press any keys. after unplugging and replugging after a while the same thing happens again. the unit is only 2 years old.
How to set up the clock?
No sweat, really easy. press clock button once for 12hr twice for military time, then enter time, press clock button again.
Magic Chef MCD1611ST Instruction Manual Controls Setting The Clock Time...
Mar 31, 2015 | Magic Chef MCD1611ST Stainless Steel...
Clock will not set time
Most microwaves just need to have the clock button pressed 1 time. Then you enter the time. Next some want to to pick am or pm. Then press clock again to set. Sometime last step is the start button instead of clock.
Mar 02, 2015 | Kenmore Elite White 1.5 Cu. Ft. Convection...
How to set clock
Press Clear (or Cancel). Press the CLOCK key (or the key that shows a picture or icon of a clock). Type in the time and press Enter/Start.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Aug 18, 2014 | Kenmore Elite Black 1.5 Cu. Ft. Convection...
How to use time on Lg Microwave
Press Stop/Clear
Press Clock
Enter time e.g. 1015
Press Start/ Enter
Jul 27, 2014 | LG LMV1683SB 1.6 Cu. Ft. Over-The-Range...
The problem is that when I press the 'Start' button, nothing happens. The clock is working, the fan is working, but I cannot cook anything even after I have entered the time and the power level
If when you press the start button the turntable starts but no heat then magnetron is faulty otherwise if nothing happens then the touchpad itself is faulty.
Oct 10, 2013 | Samsung 1.8 Cu. Ft. Over-the-Range...
Sylvania p70d20al-d5 microwave keeps beeping
I have the same problem with my microwave, the clock disappears and it says "enter" and "amt", I figured out it's the "beverage" button that is sticking. When I want to use it I just press "beverage" and then "reset" and just press them over and over until it stops. Usually it's on the first try, sometimes I have to press them a few times. Just don't do what I'm about to type though, I decided to get my razor knife and cut the button out carefully, I only cut the contacts on each side of the button, now no buttons work, I should have left it the way it was, at least I could use it that way.
Dec 29, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Emerson Microwave MW8115SS
there is a thermal fuse inside that is likely blown.
easy to replace just have to google bullet thermal fuse.
May 11, 2008 | Microwave Ovens
Farberware Microwave Oven
Try getting help via e-mail to farberware-electric@saltonusa.com or by calling 1-800-233-9054.
In most cases, you press Clock, then the numbers, then either Clock or Start.
Oct 26, 2007 | Microwave Ovens
Nothing happens when you press "Start"
PLEASE CHECK IF DOOR IS CLOSED PROPERLY THOSE HOOKS ON THE DOOR ACTIVATE SWITCHES ON THE INSIDE OF MWAVE OPEN COVER AND CHECK IF HOOKS ARE MAKING CONTACT WITH SWITCHES .COULD ALSO BE TOUCHPAD FAULT YOU WILNEED A TECH
May 09, 2007 | GE JE1540 Microwave Oven
Avanti MO7180TW 700 Watts Microwave Oven Logo
29 people viewed this question
Top Avanti Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you an Avanti Microwave Oven Expert? Answer questions, earn points and help others
