Question about Poulan Garden
PR1842STC lawn tractor Runs for over a min., then stops...replaced and cleaned fuel filter, line and tank...still won't run
  • Poulan Master
  • 7,482 Answers
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming the carburetor a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please do not forget to rate me,
Thanks
Good Luck,
I hope this helped
Posted on Aug 11, 2010
It runs for 10 seconds then stops
Sounds like fuel starvation try each of the following, test to see if it runs after each.
1. Check you have fuel.
2. Check/replace the fuel filter.
3. Check the fuel lines.
4 Clean the carburettor
Aug 04, 2013 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna YTH1842 stops running when hot
Try slackening the fuel filer cap, if the breather is blocked in the cap it will vacume and stop the fuel from flowing, if it runs ok with the cap loose replace the cap.
May 18, 2013 | Husqvarna Garden
Sears lawn tractor
Check fuel tank or cap vent to be sure it is not plugged.
May 03, 2013 | Garden
Stalls after 20 mins. of running fine. (Starving for gas)
From the rear of machine look at the top left of fuel tank for the fuel line.Where line comes out of tank see if it is pinched where it goes down between frame and tank,grab line and see if it moves freely.If that is OK loosen fuel cap after 10 minutes of run time to see if your vent hole in cap is working.These are 2 common problems for the L series mowers.
May 22, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Seems as though the fuel filter is getting stopped-lgt2554
Remove the gas tank and clean it out, look for signs of water and or dirt in the tank also look for a pinched fuel line between the tank and the carburetor
Sep 01, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
I have a Craftsman 917-272911 lawn tractor, and I believe it has a fuel problem. It starts fine and runs, but doesent keep the fuel filter full of fuel, so it spits and sputters. I replaced the fuel,...
You probably need to rinse the fuel tank out, To check if this will solve your problem disconnect the fuel line from fuel tank going to the fuel filter, remove gas cap and blow air thru line back into tank. This should clear any sediment impeding fuel flow temporarily. Reconnect line and start motor. If it runs longer than it has been then your fuel tank is in need of cleaning.
Aug 24, 2009 | Garden
Motor runs for 5-10 min. then starts missing and quits.
Check your spark first,if you do not have spark your problem is the coils-if you do have spark the problem probaly lies withone of your valves getting stuck after getting hot and soonas it cools down a little it closes and then you can restart it till it gets hot again.Hope this helps
Jul 04, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Lawn tractor only runs when i spray engine starter in carb, then it stops
Bypass the filter. If it runs with the gas tank hooked strait to the carb., you'll know you've a clogged fuel filter. If this doesn't work, try cleaning the carb. It's not that complicated and doesn't have that many parts.
Jun 23, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My tractor stalls like it is starved for gas although the gas tank is full. I,ve changed the fuel filter and the gas cap. I've cleaned out the gas tank, gas lines, and the carburetor bowl. The problem...
I had a similar problem with a sears tractor. close to the carbarator is a rectangle box with a rubber hose going to the engine block - remove the hose and spray carb cleaner in the hose wait a few mins and try again - its a vacuum for the carb
Jun 04, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
94 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
