Question about Nokia Lands Phones
I hav a nokia 6234 and it shows internal memory of only 6 kb. I hav upgraded it but its the same. when i apply theme it says "not enough memory". Please show me a way to get its default memory which is 6 mb.
  • 118 Answers
You have to move items save on the internal memory to the memory card or external memory on the phone of u restore the factory settings of the phone to wipe every thing on the phone off. This will restore the main memory to the normal size. Thanks
Posted on Aug 06, 2010
My nokia 5130c-2 is showing not enough phone memory!!! when i check how much memory i have left on the phone memory it show's less memory.Basically nokia 5130 have about 32MB memory but it shows about...
Did you save music files on phone memory? If yes , it is time to move it to your memory card. Also check for other big files that still keep in phone memory. If able , just move also your theme files to memory card. Move / delete also old messages files, games (if any), etc in phone memory.
Like computer, your phone need enough space for caching.
Hope this helps.
Regards
Oct 10, 2011 | Nokia 5130 Cellular Phone
Not enough space to apply a theme which is only 450 kb and 90 MB free space on phone
it is not a problem with your phones free space . its regarding your phone's ram memory. its not capable of applying themes 450 kb and also its not support the flash type themes.
Jun 24, 2011 | Nokia 8800 Sirocco Cellular Phone
In nokia 3110 c, i am not able to apply themes. i...
Try the settings and select back to factory settings with code 12345.But first try backing up some important files such as contact numbers dll.Good luck.
May 19, 2010 | Nokia 3110 Cellular Phone
Nokia 6300 themes not applying
its virus attack. use only authorized themes
May 09, 2010 | Nokia 6300 Cellular Phone
Nokia 6233,themes are not getting applied
The theme which you have downloaded might not support your phone. Also please check that your phone has enough space.
Regards, Kesav
Mar 01, 2010 | Nokia 6233 Cellular Phone
I have a problem with switching my nokia 3110 classic answer pls!
The Problem with Nokia 3110c – Switching off and automatically restarting This is what happens. Nokia 3110 hangs, gets switched off and restarts randomly. More often, it restarts around 3 times or so and then gets switched off.
Possible Causes and Solutions Cause 1 – Phone Memory Full – Nokia 3110c mobile phone has got 9MB of internal memory.
Solution – Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent Nokia 3110c from restarting.
Cause 2 – Changing Themes – Some people have reported that the phone restarts automatically when they try changing display themes on the phone.
Solution – Don’t get your phone loaded with too many themes downloaded from the internet or atleast, don’t switch themes frequently. These themes, mind you, also load up things into your already falling Nokia 3110c phone memory.
Cause 3 – Memory Cards – Some people have reported that Nokia 3110c restarts due to some issues with the memory card.
Solution – Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 – Transferring data via Blueooth / USB data cable (or) Updating Music Library – A few people have reported that their Nokia 3110c mobile phone restarts when updating the music library.
Solution – Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone.
Cause 5 – MP3 files
Solution – This may seem dumb, but consider converting all your MP3 music files to WMA and then store them on the memory card. Some users suggested this.
Also try this:-----
It ll work . you dont need to go 4 the firmware v5.05
If ur phone restarted 3 or 4 times and switched off automatically. Try this
method
1] Remove the battery and Micro SD card
2] wait about 5 minutes
3] Then switch On the phone WITHOUT the memory card
Now ur phone working well without restarting
4] Then you must restore Factory settings frm the Settings Menu
[default security code:12345]
{i know most of people have done this thing,but remember u have 2 go
with the correct order.Unless it will not work.OK}
5] Now apply a theme. The theme's size should be below 100kb
6] Now ur phone working fine without the Micro SD
7] Then wait about 5 minutes and Switch off ur phone
8] Remove the battery and insert the Micro SD
{Don t Format the memory card}
9] Switch On ur Nokia 3110c phone.
10] Now Keep ur free Phone memory space [Not the memory card's free space]
between 470kb - 499kb.
Now surely ur 3110c working fine about 5
months.During these time u can
1] Send/receive any file via bluetooth.
2] Enjoy Music,video, GPRS,Yahoo Go .....etc
3] Also u can Update music library anytime.
but remember below DONTs
1] Don t try to change themes.{u have to stick with a theme}
2] Charge ur phone in ON mode
3] Dont fully discharge the battery
4] Start charging ur phone when there is only a bar on Battery indicator
5] Dont erase calender notes
Make sure about above 5 Donts
Dont worry if ur phone restarted once.{U know the problem is restarting several times
and automatically swiched off.}
After 4 or 5 month there is a possibility to occur the problem again.
if so Follow the above steps again.
Good luck
To be frank, This mobile has this as a generic problem. As I told, The problem can come back again.
Thank you Sir, Have a nice day.
Sep 21, 2009 | Nokia 3110 Cellular Phone
Full phone memory even though it's not full..
these problem needs a complete restore factory settings.i had these kind of prob with my 6085 phone and the phone memory corrupted..it occured when u removed ur mem card while using some files or application in it.
Jun 24, 2009 | Nokia 5130 Cellular Phone
NOKIA 3110 CLASSIC RESTART PROBLEM
salam
restore ur mobile factory settings
apply only builtin themes of nokia
do not fill ur mobile memory and always leave space of 500 kb
delete ur notes and celender notes
do not apply heavy wallpapers
hope the answer of question
Sep 09, 2008 | Nokia 3110 Cellular Phone
Lands Phones Logo
Top Nokia Lands Phones Experts
Faiz Mohammed
Faiz Mohammed
Are you a Nokia Lands Phone Expert? Answer questions, earn points and help others
