Question about Ryobi Cultivator
I can get my 4 cycle started but idle is not that good and sometimes when i go to till it dies wondering if fuel lines are hooked up correct
2 Suggested Answers
AndrexT
  • 21585 Answers
SOURCE:
Symptoms are indicative of either air entering between carburetor and cylinder or a return spring missing in the carb or throttle linkage.
Posted on Jul 24, 2017
I have a Troy Bilt trimmer model TB675EC...4 cycle engine. Problem that has arisen is that it dies at high speed and under load. Starts up and runs at idle well.
Fuel starved, carb should have an idle adjustment which sounds like it is fine. Look for the second adjustment
Jul 17, 2017 | Troy Garden
2001 explorer sport , fuel pump? vacuum leak? 619 scan tool data provided, any suggestions/solutions
The fuel pump is suspect but I believe there's also a fuel filter inline on the underside of the drivers side chassis. Fuel works off pressure so if the filter is clogged, the pressure remains between the fuel tank and the filter. Once the fuel has siphoned off between the filter and injectors, it dies but because there's positive pressure at the fuel pump, it won't come on until the pressure slowly seeps past the clog after hours. It's worth a look!
Apr 08, 2017 | 2001 Ford Explorer Sport Trac
Vf750 honda idles but dies when throttle opened
Hi, Anonymous and the usual suspects are:
1. Idle port, transfer ports, slow air jet clogged.
2. Idle adjusting screw set too low.
3. Air fuel mixture adjustment too lean.
4. Pilot/slow fuel jet clogged.
5. Faulty accelerator pump.
6. Float level too low.
7. Float bowl contaminated old fuel, water, dirt, rust, etc.
8. Carburetor bowl vent line clogged/blocked/pinched.
9. Fuel line to carburetor kinked or pinched.
10. Fuel filter clogged.
11. Intake manifold leak.
12. The gas cap is not venting properly or fuel tank venting system blocked.
13. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
14. Needle and seat stuck closed in the float bowl.
15. Multi carburetors not in sync.
16. Faulty fuel pump.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Starts choke but dies with little throttle
1984 VF700 Magna starts but won take throttle
Honda Magna VF750C Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda 1995 VF750C Magna Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jun 14, 2014 | 1995 Honda VF 750 C Magna
I have an echo PB265L it died the other day in the middle of use, it soaked the air filter with fuel. I started looking into it more this week and it has good spark but it doesnt seem to be getting fuel. I...
Put a new plug in it, don't prime it, and use quick start (a little bit), hold it wide open and give it good yank. If you haven't screwed with the needles and put everything back together correct (like hooking the fuel lines up correctly). it should have a short burst running. If that works, check your fuel line inside the tank to see if it is in tact and hooked to the fuel filter. The needles will be okay at 2 turns out. If it starts, you will need ot adjust them in for max tunning. Turn the one in closest to teh motor first (probably no more than a half turn), then holding it wide open "running" screw the next one in until it stips 4 cycling adn runs at peak.
Jun 06, 2014 | Garden
1987 Kawasaki GPz 1000 RX dies with throttle
Hi, Steven and the usual suspects are:
16. Faulty fuel pump or internal fuel line has pinholes.
17. Fuel injectors clogged or faulty.
18. Faulty throttle position sensor.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
96 Ninja 250 Dies once Throttle given Sportbikes net
http://www.kawasakimotorcycle.org/forum/vintage-motorcyle-info/146804-1986-gpz600-ninja-wont-rev-past-5000-dies-when-giving-full-throttle-please-help.html
Kawasaki GPZ1100 KZ1100R 1988 Service Repair Manual Download Manuals... $15
OEM Parts for Kawasaki
http://mybikemanuals.com/kawasaki
Mar 06, 2013 | 1987 kawasaki GPz 1000 RX
1998 Kawasaki KDX 200 dies with throttle
Hi, Hamiltont1 and the usual suspects are:
Bike idles perfect but dies when given the slightest amount of throttle 93...
Idles good dies when throttle is applied
Kawasaki KDX200 Service Manual
1998 Kawasaki KDX200 Owner Manual
Sep 07, 2012 | 1998 kawasaki KDX 200
I have a 1982 yamaha vision 550 i have it runnin but hard to find a smooth idle choke to high idle real fast choke to low it dies
Hi, Renee and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting screw set too low.
8. Air/fuel mixture screw set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on blue links below. Good luck and have a wonderful day.
Owning Vision FAQ
Hard starting can open choke
Yamaha XZ550 XZ 550 1982 1985 Factory Service Repair Manual Download...
OEM parts for Yamaha
Yamaha XZ550 Vision Carburetor Overhaul Pt 1 Getting Started
Jul 15, 2012 | 1982 Yamaha XZ 550
2000 Honda VTR 250 idles but dies on acceleration.
Hi, Gazza and the usual suspects are:
Idles fine but dies upon throttle
Idles but won accelerate
Honda VTR 250 Workshop Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda VTR250 Owner Manual
Apr 14, 2012 | 2000 Honda VTR 250
Yamaha 2005 TTR250 carburetor problems
4. Vacuum line from the petcock to intake manifold cracked.
5. Float needle and seat sticking.
7. Carburetor bowl vent line clogged/blocked/pinched.
8. Idle adjusting screw set too low.
9. Air/fuel mixture screw set too lean.
10. Idle port, transfer ports, slow air jet clogged.
11. Slow fuel jet clogged.
12. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the blue links below. Good luck and have a wonderful day.
Carb issues
2006 Yamaha Bruin 350 Starts idles dies won restart
Yamaha TTR250L Service Manual
Yamaha TT Owner Manual
Feb 26, 2012 | 2005 Yamaha TT-R 250
2004 Ford F250,6.0 Deisel .When starting cold,won't turn above1500 RPM,without choking out black smoke,hacks and coughs till back to idle then idles fine ,not drivable till idles for half an hour,will not...
Ford 2004 6.0, Driving down road seams like when it starts warming up it starts Missing or accelerating,jerking,as long as you keep the acceleration it seems to work as soon as you level it out it starts missing,even dies at stoping sometimes...Changed fuel filter, put fuel additive in tank still missing,HELP
Jan 02, 2010 | 2004 Ford F250
Ryobi Cultivator Logo
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Phil Walker
Phil Walker
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
