Question about Staples Arrow T2025 Staple Gun For Flat & Round Crown
Inserting staples how to - Staples Arrow T2025 Staple Gun For Flat & Round Crown
Put the staples in the staple gun before you put in the tool.
http://www.arrowfastener.com/sites/default/files/T2025_manual.pdf
Posted on Sep 29, 2010
Swingline Optima 45 Stapler - cannot slide tray back in stapler, no staples jamming
Sometimes the rectangular insert where the staples sit on, gets dislodged. On the underside of channel insert is a spring and when correctly seated is in between the tabs of the bottom piece. If the insert isn't in between the tabs, it sits too high and makes it difficult to open and close the staple tray. The staples will jam.
Jun 13, 2014 | Swingline Optima Electric Stapler 45 Sheet...
Staple is jammed
Open the area where more staples are inserted, remove the staples, then find the jammed staple. You'll probably have to wrench it out with pliers. Then insert the good staples and try again.
Dec 28, 2013 | Tools & Hardware - Others
How do I reload staples into my Xerox WorkCentre 7530?
You did not indicate finisher? Xerox MFPs' come with the most finishing options of any manufacturer.... I included instructions for all of them below. Enjoy!
Solution : Load Staples in the Professional Finisher With Booklet Maker The stapler in the booklet maker uses two Staple Cartridges labeled R2 and R3. Booklet stapling requires that both Staple Cartridges be free of jammed staples.
WARNING: Do not perform this procedure when the printer is copying or printing.
  1. Make sure the printer has stopped copying or printing.
  2. Open the Finisher Front Door.
  3. Squeeze the orange R2 and R3 levers together and pull the Staple Cartridge unit out of the Finisher until it stops.
    NOTE: The Staple Cartridge unit does not detach from the Finisher.
  4. Grasp the orange tabs on both sides of the Staple Cartridge and lift the cartridge out of the Staple Cartridge Unit.
  5. Push the new cartridge into the Staple Cartridge Unit.
  6. If no jammed staples are found, repeat step 4 - 6 for the other Staple Cartridge.
  7. When finished, return the Staple Cartridge Unit to its original position.
  8. Close the Finisher Front Door.
Solution : Load Staples in the Main Stapler of the Professional Finisher NOTE: Using Staple Cartridges other than the recommended staples may impair quality and performance. Only use only Staple Cartridges recommended for this Finisher.
  1. Make sure the machine has stopped copying / printing.
  3. Grasp the orange R1 lever on the Staple Cartridge and push it to the right.
  4. Grasp the orange tabs and pull the cartridge out of the Finisher.
  5. Check inside the Finisher and remove any loose staples.
  6. Pinch both sides of the staple case and remove the staple case from the cartridge.
  7. Insert the front side of the new staple case into the Staple Cartridge, then push the rear side into the cartridge.
  8. Grasp the orange tabs on the cartridge, and then insert the cartridge into the Finisher until it click into position.
  9. Close the Finisher Front Door.
Solution : Load Staples in the Booklet Maker of the Optional Office Finisher LX NOTE: The Booklet Maker uses two staple cartridges. Booklet stapling requires that both staple cartridges contain staples.
  2. Open the Finisher Side Cover.
  3. If the Staple Cartridges are not visible, grasp the vertical panels to the left and right of the opening and slide them to the center.
  4. Hold the tabs on both sides of the cartridge and pull the cartridge out of the finisher.
  5. Hold the tabs on both sides of the new cartridge and insert it into the original position in the Finisher.
    NOTE: If you have trouble inserting the cartridge, make sure the staples are positioned correctly in the cartridge.
  6. Starting at step 3, repeat the procedure for the other cartridge.
  7. Close the Finisher Side Cover.
Solution : Load Staples in the Integrated Office Finisher WARNING: Do not perform this procedure when the printer is copying or printing.
  1. Make sure the machine has stopped printing or copying, then open the Front Cover on the Integrated Office Finisher located under the Scanner Assembly.
  2. Remove the Staple Cartridge by grasping the cartridge by the orange handle and pulling it straight out of the Finisher.
  3. Remove any loose staples inside the Finisher.
  4. Pinch both sides of the staple case and remove the staple case from the cartridge.
  5. Remove the new staple case from its packaging and insert the front side of the case into the staple cartridge. Push the rear side into the cartridge. The cartridge will click into place when it is installed correctly.
  6. Grasp the cartridge by the orange handle and insert the cartridge back into the stapler until it clicks into position.
  7. Close the Front Cover.
    NOTE: If the Front Cover is not completely closed a message will be displayed. The machine will not operate if the cover is even slightly open
Nov 18, 2013 | Xerox WorkCentre M-24 Color Copier
I cannot insert the retainer spring into the stapler 2025, with or without staples. What am I doing wrong? Arrow fastener model T2025. I played with the front piece for different sizes of staples; since...
make sure the rod inside the spring is not bent. the slightest bend can cause the retainer or push up loader to act goofy. Also make sure the u shaped(a square U) that makes contact with the staples isn't warped or out of shape. and if staple gun was ever dropped the whole track it slides down could be pinching down too much creating resistance. if so, pry open gently wherever you see that it might be getting tighter. If a visual inspection is not obvious try slowing sliding the spring loader into staple gun's staple track and once resistance is felt start to gently work open with a pair of needle nose pliers, insert closed the use two hands pull pliers open to spread the track apart. . Or any method you find easier that would create the same effect. be inventive and use commonsense always. before u know it you will be MacGyver. LOL Hope this helps, and good luck.
May 09, 2011 | Arrow T25 Staple Gun
Need help loading staples in my Stanley electric staple/nail gun
there should be a button / lever at the rear press it and it should open so as to insert the staples
Apr 05, 2010 | Stanley Staple/Nail Gun Elec
HOW DO I LOAD THE STAPLES IN MY STANLY TRE500
Unplug. Pull out shaft. Flip over. Insert staples into open slot (not on top of shaft).Make sure points are up.
Jul 15, 2009 | Electric Stanley Tre500 Staple Gun /...
Stapler is not dispensing staples after new cartridge is inserted. Can you help?
Remove the staple cartridge, look into the cartrige area, are there any stray staples in this area, if so remove them, cycle the unit a couple of times without the cartrige in place, check the output end, any stray staples here? re assemble making sure you pull the first row ow staples even with the nozzle of the cartrige.
Hope this helps
Ed
Apr 30, 2009 | Office Equipment & Supplies
Panosonic Electric Stapler does not staple paper!
It could be either jammed up with staples or the spring mechanism is shoddy.
Apr 14, 2009 | Office Equipment & Supplies
Replacing staples
1-Open door in finisher ( where paper is delivered and stapled)
or push finisher away from copier and look on the right rear
2- remove the old unit by lifting up and out ( should be a small white box
3-before inserting new staples remove the band surrounding it : Careful not to drop, if you do you must make sure they face the right way in the box !!!!!!
4-insert in stapler
Sep 08, 2008 | Canon imageRUNNER 400S Copier
Staples Arrow T2025 Staple Gun For Flat & Round Crown Logo
356 people viewed this question
Top Staples Tools & Hardware - Others Experts
Van Allen II
Van Allen II
john h
Andrew Taylor
Andrew Taylor
Are you a Staples Tool and Hardware - Other Expert? Answer questions, earn points and help others
