I know power is getting to it as we get the external power LED comes on and after 2/3 seconds the caps lock LED and one other flash and thats all the thing does.I know power is getting to it as we get the external power LED comes on and after 2/3 seconds the caps lock LED and one other flash and thats all the thing does.
You can't post conmments that contain an email address.
check with the place you purchased to see if you still got warrenty, also you can find the exact same model here or a new model at discount prices>>www.discountbargainprices.com
The fault could be the cpu, wrong type of ram, a faulty ram module
or a fault in the mainboard.
Check all the settings in the manual and the bios aswell.
Here is a list of beep codes: Basic Beep Codes for ABIT AWARD BIOS Motherboards
No beep at all - this means your motherboard is dead, either due to a defective or underpowered power supply, poorly seated CPU or RAM, or a dead-on-arrival board
One beep - board is working fine
One long beep then machine shuts down - faulty, improperly installed or missing CPU
1 short(Beep) System booting is normally
2 short(Beep) CMOS setting error
1 long - 1 short(Beep) DRAM ERROR
1 long - 2 short(Beep) Display card or monitor connected error
1 long - 3 short(Beep) Keyboard Error
1 long - 9 short(Beep) ROM Error
Long(Beep) continuous DRAM isn't inserted correctly
Short(Beep) continuous POWER supply has a problem
A two-tone siren, generally caused by overheating or out of specification voltages
Four beeps then machine shuts down. This is because this version of the BIOS will shut down your machine if no fan tachometer signal is detected on the fan header. Make sure you attach a fan to the FAN1 or FAN4 header or clear CMOS to reset to default (no checking).
Sounds like you have some type of hardware failure. If you are comfortable taking apart the system, start by removing the memory. If this system beeps then you know that your motherboard is still OK. But right now I am thinking that you may have a faulty motherboard.
if i read this right, when you power up the laptop you get fan spin but no display ?, if you just get fan spin and the green power light and nothing else the you have a motherboard failure, if you get LED activity and it seems to be working but you only have no display the its more likely LCD failure, if you DO get activity try this : power off the system, press power button while holding down the D key, this will run the LCD BIST SELF TEST which will run through full colour screens if fails this test you will et a beep code, please bear in mind you will only be able to run that test if you get LED activity, if you dont have activity then the motherboard needs replacing
try powering the laptop on, and open/closing the lid.
this is to ensure, the closed lid catch is activating/de-activating.
you should get a beep or tone, when the lid is closed.
Or the laptop, will go into Sleep/hibernation Mode.
Also try pressing and holding the power on Button for more Than 5 seconds, This will eliminate that the laptop hasn,t gone Into sleep/hibernate Mode.
If none of this Works for You. Try removing and replacing The memory modules ( RAM ) and use 1 stick of memory in each slot individually. failing any of this. i,d suspect. Screen Inverter/tft Panel Or Motherboard Fault. Or possible graphics driver Corrupt/missing.
One long and two short beeps indicate the problem with the display card on most of the laptops.
Graphic card is integrated to the motherboard.
Therefore the motherboard needs to be repaired.
I think you may mean the Hard Disk light not floppy, although, if you have a floppy disc drive, check there's no floppy disc in it as it will stop the boot up.
But if it's not the floppy, and the hard disc drive light stays on, possibly the hard drive is faulty, maybe damaged sectors.
The other maybe is a possible memory fault, although the beep codes can only be identified if you know the motherboard make.
Your rating are important.
