Question about PNY 8GB USB 2.0 Flash Drive - Blue/Black
I need step by step directions to tranfer pictures to my flash drive
  • 6,826 Answers
First, get the pictures on to your desktop or locate the directory where the pictures you want copied are under 'pictures' off of the Windows 7 directory.
Then you can drag and drop the directories with the mouse to the USB 2.0 Flash Drive icon under the 'computer' choice on the start menu.
Posted on Aug 03, 2010
How to tranfer picture from camera to flash drive
Connect the camera to the computer with the supplied USB cable. the computer will see the camera as an external storage device. You can then copy the photo from the camera to the computer's hard disk and or your flash memory stick.
If you camera has the photos stored on a SD memory card you can remove the SD card and insert it into an USB memory card reader. Then connect the card reader into the USB port of your computer to download the photos from the SD card to the computer's hard disk and or your flash memory stick.
Aug 21, 2011 | Computers & Internet
I don't know if its working there is no window to fallow,I need steb by step how to put pictures on my sandisk.
I found you and excellent article that gives you a step by step on how to load files or pictures on a flash drive . Click the link or copy and paste it into your web browser. Here is the article:
http://www.ehow.co.uk/how_6462561_load-files-flash-drive.html
I hope this helps you out and if it does please give me a YES that I did assist you. Thank you
Apr 09, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
My Grandma was given a Coby dp700 with pictures already on it for a gift. She would like more pictures. I can get different pictures from a usb flash drive to play as long as the flash drive is plugged...
Most digital frames come with a USB cable to hook the frame directly up to a computer. When you plug in the frame, a drive should show up in your "My Computer" section (for Windows) or on your desktop (for Mac). In most cases, you just need to drag and drop the photos onto the drive.
Mar 05, 2011 | Coby DP-772 Digital Picture Frame
How can I tranfer video from my camera DMCTZ10
Once you connect the Camera to the computer, you will get the Camera as a removable drive under My Computer. You can open the removable drive to see the pictures stored in the Camera/Memory Card.
If the Operating System installed in your Computer still needs a driver, you may use the Memory Card slot on the Computer to transfer the pictures. Please follow the steps to transfer pictures using Memory Card Reader in the Computer:
  • Remove the Memory Card from the Camera.
  • Insert it in the Memory Card slot in the Computer.
  • Open the pop up window or find out the removable drive under My Computer.
  • Copy the required files to a folder in the Computer.
Note : Most of the Notebooks comes with its own Memory Card Slot. If it does not, you may get one from the market without much spending.
Thanks for understanding.
Please let me know if you need further assistance
Mar 05, 2011 | Panasonic LUMIX DMCZS7 DMCTZ10 Digital...
I was gifted accura digital photo frame but I am totally illerate about its function ,please guide me
U have a digital camera?Use the Digital camera take pictures with the menory stick.Take out the menory stick,plug it in the Digital photo frame to tranfer pictures.Or no menory stick,plug direct in to the digital camera to tranfer pictures.
Jun 14, 2010 | Westinghouse 7" LCD Digital Photo Frame
Slimtype Combo LSC-24082K
Firmware Here http://support.gateway.com/support/drivers/getFile.asp?id=19715&dscr=Firmware%20Flash%20Update%20PGS3%20for%20Lite-On%2048x%2024x%2048x%20Recordable/Rewritable%20CD-RW%20Drive&uid=222228034&site=emachines
After you have downloaded the firmware update above,the Firmware flash utility,and the FlashFix and saved them all to the desk top.Run the firmware flash utility in step 1.(and follow the directions) (after you run it and make your back up,move on to step 2), Run flashfix in step 2 (and follow the directions)After you have completed steps 1 and 2 move onto the flash,(just click on the update firware file on you desktop and run it.(follow the directions n the screen)
Note: Firmware flash utility =LtnFw (use it for the backUp)
Step 1: Make a backup copy of your current firmware. You can do so using LtnFW. you should make this backup incase you decide that you want to undo the firmware flash, you will need a backed up firmware.
Note: FlashFix=flash fix
Step 2:The firmware flasher is checking your drive and seeingthat you have an OEM model and is thus refusing to flash it. FlashFix will patch the firmware flasher so that it will agree to flash your drive.
Note: Flash=The firmware file you downloaded
Step 3: After using FlashFix, run the flasher, make sure that you select the correct drive from the drop-down list, and flash
I hope this better explains the steps
Jan 31, 2009 | Computers & Internet
Transfer pictures
Plug the frame into the usb slot on your computer. Open up the folder with your pictures on it. Then open up my computer and look for the drive that is the frame. Drag your pictures right to the frame,s drive.,
Dec 13, 2008 | PANDIGITAL 7-Inch Digital Photo Frame with...
PNY 8GB USB 2.0 Flash Drive - Blue/Black Logo
Top PNY Electronics - Others Experts
john milligan
Marvin
Marvin
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
