Question about Seville Classics MSC10166 Tower Fan
My seville classic tower fan stopped working suddenly. i belive it's some sort of internal switch probem. becuase it's the can that operates when turnning the tower on the base. please help
4 Suggested Answers
SOURCE: Seville Classics MSC10166 Tower Fan
Possible Solution :
Taken From :
http://www.fixya.com/support/t193631-am_trying_fix_oscillating_tower_fan
"Most fan motors for fan over running have an internal overload. once it trips, it will not reset. it is a solid state device. it looks like a flat device or a small bullet device. if you've figured out how to take the fan apart, you could just remove the device and connect the two wires together and the fan will run. you won't have any protection on the motor however. the windings run warm, but if the bearings run dry the motor will slow down and the windings will get hot. this is the reason for the overlaod device - protection. its your call what you want to have."
Posted on Aug 22, 2008
videotransmi
  • 105 Answers
SOURCE: how to open tower fan to clean it
Use compressed air to blow the dust etc. out of the unit.  You can purchase a  can of compressed air from Home Depot or Lowes, or Google "compressed air in a can."  Just make sure you clean the unit outside to keep the dust etc. out of your home.
Posted on Mar 22, 2009
SOURCE: I have a seville classics
Good Luck!! I too have one and although I was able to take off a bottom panel and clean it- the important area (fan) proves quite inaccessable. I am very mechanically adept too. Either way felt it was a lot of trouble for nothing- so I used a powerful vacuum blower to blow out all the dust instead. When these fans can be purchased for 50 bucks, new, at Cost Co, it sort of eliminates the need to get real carried away with maintenance.
Posted on Dec 01, 2010
Cannot find fuze in Seville Classics tower fan Model 10187
If there is a "Fuse" it will be at the connection point to the fans control board.
Aug 31, 2017 | Tower Dryers
My seville classics tower fan no longer oscillates - how can that be fixed?
Throw it away and buy a new one for 20 box at Wal-Mart. It's as simple as that cause to fix it, it'll take a new machine which cost twice the price. I think they made it to last one summer max. Friendly yours
Jul 01, 2014 | Seville Classics MSC10166 Tower Fan
Why blades are not rotating or throwing air?
some of these have a expansion pin that holds the fan blade assembly onto the shaft, this may have fallen out or ? broke,,,
May 13, 2014 | Seville Classics MSC10166 Tower Fan
I have a seville classics tower fan. How do I take it apart to clean it?
Nov 12, 2010 | Dryers
The fan has power and will rotate, but no air is being blown out. any troubleshooting tips or is it a goner?
Try to free up top fan bearing, it is under switch cover. Pry cover with small screw driver, insert screw driver blade in access hole and pry, top fan bearing is held by two screws, remove, clean and lubricate with oil or grease. It works!
Sep 29, 2010 | Seville Classics MSC10166 Tower Fan
To take apart: see solution #1 (not a complete disassemble but helps)
Aug 15, 2008 | Seville Classics MSC10166 Tower Fan
Possible Solution :
Taken From :
Aug 14, 2008 | Seville Classics MSC10166 Tower Fan
Seville classics model 10166
bottom stand was broken. how to get new bottom part.
Dec 06, 2007 | Seville Classics MSC10166 Tower Fan
Seville Classics MSC10166 Tower Fan Logo
200 people viewed this question
Top Seville Classics Dryers Experts
Marvin
Marvin
Are you a Seville Classics Dryer Expert? Answer questions, earn points and help others
