Question about Bamix Gastro 200 Handheld Blender
Stopped working after being half submerged in water
Rubber washer for Model TSK-9368AP Blender
I just fixed mine with a rubber hose washer. I had to cut the washer in half because it was too thick, but it stopped the leak!
Mar 29, 2010 | Blenders
I can no longer unscrew the plastic part that the glass container fits into on my old Waring 18BL28 blender. It is a simple 10 speed that works perfectly.
Something sticky is in the threads... Try very hot water in the sink as a start, while boiling some water on your stove. With the glass and plastic preheated, install them to the blender base which must be unplugged for the rest of this adventure. Pour the boiling water in, only to about 1/3 of capacity. Install the top cover to protect from the hot water. Hold the glass by the handle and with a rubber glove on the opposite corner or pour spout side. Hold high to avoid the heat from the water. Have a large burly man hold the blender base so that you may twist the glass container counter-clockwise. Stop as soon as it starts to turn the plastic ring off...and go the the sink... Continue after pouring out the hot water. Remember that his procedure is likely to cause broken glass or broken plastic and exposure to scalding hot water. If those risks are acceptable you should still take precautions to protect your flesh. Otherwise order a replacement ring and pitcher for the blender.
Dec 23, 2009 | Waring Blenders
Oster blender
Hiya - soak jug in very hot but not boiling water for half an hour then try again
Jul 10, 2008 | Blenders
Motor works and then gets sluggish and slow
WELL, WHEN YOU UNPLUUGED THE BLENDER, AND RESTARTED IT - DID IT WORK. iF IT DID THEN IT MEANS THAT IT HAPPENED MIGHT BECAUSE YOU HAVE NOT BEEN USINGTHE BLENDER OFTEN.
bUT IF ITIT MAKES THE SOUNG AFAIN THAT THE MOTO OR WHERE THE CORD IS- SOME WATER MUST HAVE GONE INSIDE. IT IS BEETER OF YOU TO CHANGE THE BLENDER BECAUSE IT IS ALWAYS WRITTEN IN THE HANDBOOK THAT IF IT MAKES ANY KIND OF AEEFUL SOUND OTHER THAN THE NORMAL SOUND- STOP USING IT IMMEDIATLY.
Feb 23, 2008 | KitchenAid KSB5 Professional Stainless...
Blender performes poorly, if at all
Hi, cauliflour is not compact no water mix, I have suggestion , cut it 1/2" long make it fine put in blender mix w/small amount of water then start. shut off mix with wooden mixer and start again then okey.
Jan 14, 2008 | KitchenAid KSB5 Professional Stainless...
5 speed ...steel
i had the same problem after only one month, took in back to walmart and they would do nothing. i love the big heavy glass jar on this model so i baught another on thinking i broke it some how and guess what, the second one stopped after one and a half months. called around and no one would do anything for me, company sucks, i took the bottom cover off the blender to expose the problem and there is a problem with the curcuit board and built in breaker. i ripped out all the speed buttons and curcuit board and just wired in a on/off switch to the motor. works great again. i still had a extra broken blender so i took a old chain saw i had and turned that one into a gas powered blender. problem solved, any questions please feel free to ask, strawsj1234@hotmail.com
Sep 11, 2007 | Black & Decker BL5000 ProBlend Work Top...
Stopped working
i had the same problem after only one month, took in back to walmart and they would do nothing. i love the big heavy glass jar on this model so i baught another on thinking i broke it some how and guess what, the second one stopped after one and a half months. called around and no one would do anything for me, company sucks, i took the bottom cover off the blender to expose the problem and there is a problem with the curcuit board and built in breaker. i ripped out all the speed buttons and curcuit board and just wired in a on/off switch to the motor. works great again. i still had a extra broken blender so i took a old chain saw i had and turned that one into a gas powered blender. problem solved, any questions please feel free to ask.
Sep 01, 2007 | Black & Decker BL5000 ProBlend Work Top...
My hand mixer stopped working.
Have you tried greasing it near the blade. I read in my instruction book that sometimes they seize if they aren't used often. They also suggest trying to soak the wand in a pot of hot water for a minute or two and then trying to use it in the water. Hope this helps
Aug 30, 2007 | Bamix Gastro 200 Handheld Blender
Bamix Gastro 200 Handheld Blender Logo
Top Bamix Blenders Experts
Marvin
Marvin
Ruth summersides
Mai Lor
Are you a Bamix Blender Expert? Answer questions, earn points and help others
