Question about Northstar Pressure Washer 3000 PSI
Motor starts on first pull. Runs for one minute. Shuts itself off. By passed swich. Still doies it. Please help. We have tried all we can. Al Christenson 507-390-2724 -5
  • 10,865 Answers
Hello. Insufficient fuel supply, drain all fuel, disconnect and clean/replace fuel line and fuel filter. check fuel valve for blockage and clean. check as well tank for presence of rust, if any, clean it out as well.
if this did do not help, you have gunk in the carburator. Get a can of aerosol carb cleaner and spray it into the air intake as the engine runs. THis should clear up the problem but if not, the carb. will have to be disassembed and cleaned. J.
Posted on Aug 03, 2010
I have a 91 ford f150, cannot find the inertia switch, looked the 2 places another website said, but it is not there. Please help, my truck runs then shuts itself off and fuel pump is working.
Please help, my truck runs then shuts itself off and fuel pump is working. Well then ,it's not the fuel inertia switch . Your guessing because you have no clue . Probably ignition problem . When it shuts off does it start right back up ? Or do you have to wait a bit ? If you hear the fuel pump running the inertia switch is fine ,this switch shuts B+ voltage off to the fuel pump . So if you hear the pump running it's not the inertis switch . There is also an ignition system , check for spark , pull a plug wire off an hold near ground . Probably the ignition module .
Sep 13, 2017 | Ford Cars & Trucks
My dryer starts, runs a few minutes, doesn't heat up and shuts itself off
check your sensors on the heater unit, there are two or more, simply us a meter and make sure power is on both sides of the sensor, if not then that specific sensor is bad and you should replace it, pull the sensor and tie the two wire together to see if it will heat, if it does replace the sensor they are cheap and will keep you from burning down the house
Dec 31, 2012 | GE DWSR463EGWW Electric Dryer
The machine runs for brief periods, then shuts itself off. If it is allowed to sit for several minutes, it runs again, then shuts itself off.
the motor is heating up to much and the cut out switch is kicking in. You need to check the the motor filter, and worse case you may need to new motor..
Oct 04, 2010 | Dyson DC14 All floors Bagless Upright...
A/C starts up/Cools/Fan Slows, Unit Shuts down in 4 minutes
Ensure proper voltage to the unit. Check for overheated/damaged wires and/or connections in the control panel as well as at the fan motor and compressor.
Apr 03, 2010 | Dometic Rooftop RV Air Conditioner
Kenmore series 90 electric dryer does not heat and shuts off after several minutes of use. Heating element is at 9 ohms, spec is 7-11.5 , thermal limit switch was open. I replaced thermal switch and...
Make sure the vent is clear.
Does the motor humm when it starts?
If it humms then the motor is bad. Make sure the rollers are not stuck or that the blower has obstructions inside.
http://www.pdxappliance.com
Feb 27, 2010 | Dryers
Turns off after a few minutes
sounds like your motor is overheating or going bad. sometimes lint built up around the motor can cause it to overheat. or the motor is dying.
Aug 31, 2009 | Kenmore 73952 Gas Dryer
Kenmore electric dryer shuts off after 5 minutes and won't restar
when you try to start it again do you hear a humming comeing from the motor? can you jump start it by turning the drum while holding the start button? If you say yes to these questions you have a bad motor.
Jun 21, 2009 | Dryers
Kenmore Dryer model #66912690 The dryer stops
replace motor drive,,,defective motor...onthejob
Feb 08, 2009 | Kenmore 62602 Electric Dryer
Northstar Pressure Washer 3000 PSI Logo
Top Northstar Garden Experts
John Trevino
JOHN LAPIER
Are you a Northstar Garden Expert? Answer questions, earn points and help others
