Question about E-Machines Bestec ATX-300-12E Rev. D 300w E-Machine GTW Power Supply Part 100929 (ATX30012E) Power Supply
No power no fan - E-Machines Bestec ATX-300-12E Rev. D 300w E-Machine GTW Power Supply Part 100929 (ATX30012E) Power Supply
    Problem Solver:
  • 29 Answers
Check the power outlet, try swapping power cord with the monitor power cable. if still no power, try disconnecting power to motherboard cd rom. leave the hdd connected and see if the power supply fan come on. if not the you have a blown power supply.
Posted on Apr 20, 2012
Have a dell tower and want to know how to fix the fan
buy a replacement power supply fan
or
buy a replacement power supply - dearer option but power supply may be faulty if fan is not running and you fix two problems however be careful with AC input voltage that it matched the power point voltage. or smoke and broken power supply ! take old power supply to computer shop to ensure correct power supply is purchased.
or
if it is the cpu fan
buy a replacement cpu fan and thermal paste.
Possible cheaper options if fan choked full of dust
get a can of compressed air and blow the dust out of the power supply and cpu fans outside your dwelling not inside your your office/ home.
Power supply fan may need a drop of machine oil if noisy or its bearings are worn out..
Oct 26, 2016 | Dell Computers & Internet
Fan not working and a/c not cooling properly
check for power at the fan, if no power at the fan check fan fuse and relay.If you have power at the fan and fan won't come on fan motor is bad.If you turn your A/C switch on and your key switch to the on position this should cut the fan on automaticly.
Apr 19, 2011 | Dodge Ram 1500 Cars & Trucks
Gettining error 57.03 in hp laserjet 5200 printer
57.x FAN FAILURE CALL SERVICE Control Panel Message 57.x FAN FAILURE CALL SERVICE Event Log Error Service Messages: 57.01.00 57.02.00 57.03.00 57.04.00 Required Action
  1. A fan motor failure occurred. All fans are enabled to low speed operation at printer power-on. Fans will go into high-speed operation during the print cycle. All fans are disabled during PowerSave Mode.
    • x = 1: FM1 (Laser/Scanner Fan)
    • x = 2: FM2 (Power Supply Cooling Fan)
    • x = 3: FM3 (Formatter Fan)
    • x = 4: FM4 (Face Down Deliver Fan)
  2. Cycle power. It the message continues, check and reseat cabling between the fan motor(s) and the DC Controller PCA.
    • Fan 1 J208
    • Fan 2 J216
    • Fan 3 J210
    • Fan 4 J225
  3. Replace the faulty fan motor.
Dec 22, 2010 | HP Office Equipment & Supplies
A fan is making a horrible noise
hello
if its the CPU fan is making loud screech noises, its time to replace it
if the power supply fan is making the noise, its time to replace power supply , 5188-2859 is HP part number $25-$40
CPU fan = 5188-3722 HP part number , costs about $40-50
please rate my service with 4 thumbs up
Dec 09, 2010 | HP Pavilion Elite m9510f PC Desktop
On startup my fan on my dx2200 run very loudly
Which of the fan? Is it Power fan or processor cooling fan?
POWER FAN: check if the casing of the power pack is touching the fan or wire if not then prepare to change power pack or the fan.
Processor Cooling Fan: If there is no wire in the system touching the fan then know that the ball bearings are getting bad. Then plan for replacement.
Oct 13, 2010 | HP Compaq dx2200 PC Desktop
Processor fan wont work.
Hi tenfive64,
Try another fan in the cpu power slot, to see if there is no power getting to that source. If the fan turns on, well! Something ain't right with the fan. If it doen't then you'll need a power extension connector to reach for another fan power source on the board. DON'T hook it up to a non-fan power source, you will fry the fan, if not the board.
Good Luck,
Mark
Dec 16, 2009 | Compaq Computers & Internet
Cooling fan doesnt come on at all
1 step cheack power to fan if no power
2 step cheack relay and fuses
3 step if there is power at fan then repalce waterheat sending to the computer
if non of that works and you have power to fan replace the fan motor
Jun 27, 2009 | 1995 Ford Escort
Power Supply fan is not working in ThinkCentre M50 8189 D6G
Thanks for asking ...simply check the power supply fan....remove the Power supply(SMPS) from your system 1st....then remove the fan in it....try to rotate it by hands.....if it is not rotating smothly then it needs lubrication & your power supply unit needs cleaning.....if it is working fine then check the fan power section in Power supply...
regards
Mar 14, 2009 | IBM ThinkCentre M50 PC Desktop
E-Machines Bestec ATX-300-12E Rev. D 300w E-Machine GTW Power Supply Part 100929 (ATX30012E) Power Supply Logo
98 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
