Having prob with a new compture laptop a compac connecting to my wireless router and cant get in to router to get nomber
    President:
  • 1,768 Answers
1.Log into router
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
Posted on Aug 03, 2010
Wifi not working
i had this fault on a compac just got one of those tiny usb dongles
Jan 26, 2014 | Computers & Internet
Cant connect to d-link DIR-615 wirelessly, can someone help me?
What is the operating system on your laptop?
Can you access the Internet if you connect the computer to the router with the Ethernet cable?
If the wired connection is working then it must be the problem with the wireless network.
If the wired connection is also not working then you may need to reset and reconfigure the router.
If only wireless is not working then you can try creating a new wireless network and then connect your laptop to the new wireless netwok.
I can suggest you a website which may help you for Home network connection.
May 20, 2012 | D-Link DIR-615 Wireless Router
Cant connect ,no light on wireless connection. was
you need to setup the wireless connection if you havent already and your router needs to be a "wireless" router in order to create that type of internet connection. Have you laptop then scan for one which would be the one you just made and input the correct information to connect. If that doesn't work I'd suggest getting a new wireless router
May 06, 2010 | Belkin F5D8236-4 Router
I tried to connect Netgear Wireless Router WPN824v3 to my Compac Presario CQ60 Notebook using the installation CD provided with router. After connecting all required cables and reapplying power to modem...
Try connecting a cable directly from your router to your laptop and using the actual IP address of your router instead of routerlogin.com, being a Netgear it should be 192.168.1.1 or 192.168.0.1.
Hope this helps.
Nov 13, 2009 | NetGear RangeMax WPN824 Wireless Router...
Cant get a wireless connection
hi,  its an common prob, .  first u need to know that everytin s jus perfect,. try connectin thro lan first,. if ur lappy achieved de connec, then its de prob of the settings of connectin thro wireless,,. so change ur settings accordingly and try set up an new clean connection,,. thank you,.
Mar 14, 2009 | Computers & Internet
Cant get my router to work
Connect the computer to LAN port one of the router using an Ethernet cable, access the configuration page (ie 192.168.1.254), configure the router as Dynamic IP, Configure the wireless network as (WEP or WPA), Check the IP address of the WAN section.
Note: If you have an IP address to the WAN section the Internet connection is working, Connect through the wireless network by finding the wireless network name was been created to the router.
Mar 09, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Cant switch my wireless on
do you have an Fn button(function) the letters Fn are usually a different colour.If so you need to hold it down and then press the wireless button.The wireless button should have the same coloured letters or symbol looks like an aerial
good luck
any prob let me know
Mar 08, 2009 | Fujitsu Siemens AMILO Pro V7010 Notebook
F5D7230-4 wired laptop wont connect
It is not a router configuration problem its a laptop problem in the configuration. Do you have the network card installed if so try a reinstall. if not go to your network wizard and set it back up .
Oct 07, 2008 | Belkin (F5D7230-4) Router (587009)
COMPAC LAPTOPS
  1. turn on the computer that has the printer attached.
  2. configure computer to share (start/settings/printer-faxes/right click on default printer/select sharing tab/ select share this printer/ apply settings/OK)(This computer must also be connected to the router so your laptop will see it as a network device)
  3. on wireless laptop, add printer
  4. when prompted select network printer.
For my wifes ease of use I purchased for $20.00 network magic which auto configured all my devices and monitored any access to my wireless router so I could choose who could access my open router.
Jun 04, 2008 | Compaq Presario 700 470024-192 Notebook
Netgeardg834g v3
find default gateway put into your web browser and log in
use rj45 cable to do this
any probs post it back here
Mar 20, 2008 | NetGear DG834G Router
Computers & Internet Logo
Alun Cox
David Payne
David Payne
