Question about Delta Machinery 1" Belt and 8" Disc Sander
Delta disc and 1" belt worled yesterday, not today. I turn the switch on and the disc "twitches" and the motor hums. I can turn the disc by hand so it's not jammed. Belts are good. Any ideas???
  • 1,557 Answers
The motor has lost its polarity it uses magnetic electric polarity to turn around. the fault is just as bad as a burned out motor you could have the motor rewound but it would cost more than the entire unit..
sorry
take care.
Posted on Aug 03, 2010
How to fix motor delta belt disc sander
What is it doing or not doing, when u turn on the switch, either the switch or motor is probably bad or you have too much tension on the belt.
Aug 22, 2014 | Delta 31 695 6" Belt/9" Disc Sander
1632 open end belt sander where should the platter bar be located in relationship to the belt rollers
I have a delta sander sa180 that won't turn when the switch is turn on. The motor hums but won't turn.
Feb 06, 2014 | Powermatic Model 1632 Open End Belt Sander
Delta 10 inch unisaw switch hums wont start motor
All of the above are correct. However, before you go nuts with motor stuff, unplug the saw and make sure the blade shaft turns freely, If it doesn't, look for something jammed in the belt and pulley mechanisms. Loosen the drive belt and check the motor shaft rotation and the blade shaft rotation separately. If you find nothing, remove the belt and try starting the motor. If it won't start like this (no load) there is a motor problem. If it does start, find the drive mechanism problem and fix it; not many possibilities. Good luck.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_f6ca18ca1db028ed
Sep 23, 2012 | Delta X5 3Hp Left Titl Unisaw with...
Drill press motor hums and barely turns
The motor has either got worn brushes or more likely the windings have been attacked by moisture and gotten the dreaded "green spot" (corrosion).
Worn brushes can be replaced if the commutator is still good. But failed motor windings require a new or reconditioned electric motor.
Mar 12, 2010 | Delta Drills
The dryer does not turn, but will turn by hand, how do you unlock heller cd55 dryer?
It won't tumble If your dryer doesn't tumble, check these: Belt Motor Door switch Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time. Click here for a belt installation diagram Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor: Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor. If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor. Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Dec 31, 2009 | Dryers
Planer Rattle
If it is belt driven then maby replace the belt. That may be the problem.
Jun 14, 2009 | Tools & Hardware - Others
10'' bench drill press model DP200 WON'T START
The belt has either come off the pulley or the belt is slipping. Open th top access hatch and check the belts . If belt is off replace and tighten , if it is just loose tighten the belt.If it is not the belt and the motor is humming but not turning you will need to replace the motor's starting capacitor.Good luck and please don't forget to rate this answer, Thanks
Apr 11, 2009 | Delta TS200LS Shopmaster 10 Inch Portable...
Maytag Neptune Dryer Model # MDE3000AYW
Motor malfunctions usually call for service by a professional. There are three main causes of motor failure: lack of lubrication, a defective motor switch, or worn or frozen bearings. A humming sound can be related to a burned-out motor or a defective switch. Check these trouble spots before you call a professional service person or take the motor to a repair shop. Here's how to check a dryer motor:
Step 1: Remove the back access panel. Then reach behind the drum, motor pulley, and idler arm pulley. If these areas are clogged with dirt and lint, undue strain on the motor may be causing the humming noise. Worn or broken belts can also cause a humming noise. Check the belts for wear and damage. If the belts look all right, you may be able to stop the noise by spraying them with fan belt dressing, available at automotive and hardware stores and home centers.
Step 2: Turn the dryer on. The noise you hear may be the whirl of the spinning drum, not the motor. Some noise is normal.
Step 3: Force a little 20-weight nondetergent motor oil (not all-purpose oil) around the ends of the motor shaft. This lubrication may stop the humming noise. If this doesn't solve the problem, remove the motor and take it to a professional service person.The centrifugal switch on the dryer motor may be located on top of the motor. Humming, no motor power, and no heat can be caused by a faulty centrifugal switch. If the switch is externally mounted, check the terminals of the switch to make sure they are tight and not burned. If you spot trouble, remove the switch and take it to a professional service person for testing. A faulty switch will probably have to be replaced. Some centrifugal switches are located inside the motor housing; you won't be able to remove the switch in this case. Remove the entire motor and take it to a professional for repairs.
If the motor hums, but won't run the pulley on the end of the motor shaft, try turning the pulley by hand.Caution: Before turning the pulley, make sure the power to the dryer is turned off.
Sep 12, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Delta Machinery 1" Belt and 8" Disc Sander Logo
144 people viewed this question
Top Delta Tools & Hardware - Others Experts
John Trevino
Craig Butler
Craig Butler
Andrew Taylor
Andrew Taylor
Are you a Delta Tool and Hardware - Other Expert? Answer questions, earn points and help others
