Question about Coleman Heating & Cooling
What year and size is my coleman central air unit model 6271e901
bobotfel
  • 236 Answers
SOURCE: 20 year old central a/c heater not working
Check your thermostat and mode selector setting, thermostat setting should be set at warmer and mode selector setting should be at low heat or hight this is applicable for manual unit.
If it is a remote control just set the remote to heat mode.
sample only
Posted on Jan 12, 2008
SOURCE: Central air unit wont turn on
check the fuses
Posted on Jun 07, 2008
SOURCE: the rv air conditioner unit
Here's a link to SERVIVE MANUAL FOR 6535 SERIES TWO TON HIGH EFFICIENCY PACKAGED HEAT PUMPS (http://www.rvcomfort.com/pdf_documents/1976323_copy8.pdf) on the RVP website.
Posted on May 28, 2009
panilling9
  • 284 Answers
SOURCE: air conditioning unit on rv lost refrigerant what type needed
should be a data plate located on the unit somewhere and tell you how much total charge is from empty and what kind to use.
Most likely it will be R-22 (green can)
Posted on Jun 15, 2009
  • 432 Answers
SOURCE: Hi have central air . Unit working ok but noticed
You need to have a pressure gauge the reads for R-22. (Freon) It sounds like the system might have a leak. Look for a wet place any place on the units pipe system. It has a little oil in with the freon that is forced out of any leak. If you see a wet place this is oil. It is also the location of your leak.
Posted on Jun 27, 2009
Coleman mach rv central air conditioner maintenance
maintaining rv a/c is just a matter of changing filters, cleaning coils and drain lines. visual inspection of wireing for heat damage.
Jun 18, 2014 | Coleman Heating & Cooling
Coleman Mach III RV AC
Sounds like possible fan capacitor failure. If your not familiar with capacitors, please find someone who is, as they can give a fatal electrical jolt if not handled properly.
Jan 26, 2013 | Coleman Mach III Air Conditioner
Hello. I would like to know how many ton my Coleman Central Air Unit is. The model number is 'ERCS0241BBB". The serial number is "WOD7699360". Thank you.
This is a 2 ton A/C I got that from the 24 in model number it means 24,000 btu which equals 2 tons cooling. If this helps please rate me and do a testimonial.
May 23, 2011 | Coleman Heating & Cooling
Where can I find a manual for my coleman cam II central air conditioner for a mobile home? I recently purchased the mobile home and would like to know what steps to ntake to make it work at its best. ...
Check the website for Coleman/Intertherm for a manual, you will need the model and serial numbers of the unit. The filters for these typically sit on top of the unit, some come with frames, some lay directly on the coil. If you can't find a manual on the website or by contacting the company, check the yellow pages some towns have a mobile home supply house that would be able to help.
Aug 30, 2010 | Coleman Heating & Cooling
There is not an air filter in the unit and we have just purchased the home with the unit in it. I need to know where the filter goes, Tjis a coleman evcon central air unit
You should be able to open the lower panel on the Central Furnance unit and the filter would go against the side where the main cold air return plenum is located. There is usually either a slot/edge for the filter to slide into, or a set of clips or a wire spring that holds the filter in place, preventing it from getting sucked into the squirel cage blower.
If you want to give Coleman a call at 1-877-726-5362, I'm sure they'd send you a owners manual for your unit so you can see what periodic cleaning and such is needed to keep it working properly.
Hope you found this info helpful. Best Regards!
Aug 05, 2009 | Coleman Heating & Cooling
I also need a wiring schematic for a Coleman 3500A816 furnace
What are you wiring? Possibly we can help.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Sep 24, 2017 | Coleman Heating & Cooling
I HAVE A COLEMAN AC CANNOT FIND FILTERS TO FIT
yOU CAN PURCHASE FILTER MATTING AT ANY HARDWARE store and cut to size. Its cheaper anyway.. It comes in rolls.
Jun 05, 2009 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
42 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
