Question about Mitsubishi WS-55807 TV
Mitsubishi WS 55807
Help!
When I turn the tv on the light stays on for s few seconds and then turns off.....the picture came on a couple of times but only for a couple of seconds and now the light goes out so quickly that the picture doesn't have time to come on......
Thanks
  • 4 more comments
  • jmon6631 Jun 25, 2008
    I have same problem
  • lljbean Jun 29, 2008
    I have the same problem also. Any suggestions of what to do??
  • drhahn_HAS Jun 29, 2008
    Same problem here. I just got the TV and watched it for about a week before this started happening.
  • ssethi74 Jul 05, 2008
    same problem here
  • Girl 1 Aug 09, 2008
    I was looking for a solution to my problem with a Mitsubishi Model# ws55807. I push the power button, to turn TV on a small click with the green light comes on, another click 1 sec. later turns it off(NO picture).
    I found you on Fixya~YOU Wrote to someone else, and I tried your suggestion and did the self-diagnosis feature to help with diagnosis of shutdown problems.  I got a 2-2 pulse .   2 - 2 = Short protect (short protect monitors low voltage supplies)
    Can you tell me what part that would be and it approximate location for example when you open the back of the TV would it be on the immediate right hand side or ....etc.
    I would appreciate any help
    Thank you.
    Girl
  • Anonymous Oct 09, 2008
    I have the very same thing going on with my TV. I didn't do anything with it for a long period of time and one day I turned it on just to see what it was doing and it worked. I am on Comcast On Demand cable and I thought that it was a cable problem. It just went into that black screen mode again. The little green light comes on for a couple of seconds and then... nothing! Whats up with that? My TV was purchased new in Nov 2000. Never had any trouble with it before! I bought it from Goods Guys out of Olympia WA and now they are out of business!
  • 927 Answers
Good Day, Y'all;
First check for fluid on the PCB's, if ok check the following:
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SELF- DIAGNOSIS INDICATE X-RAY. CHECK FOR A SHORTED IC5A03 PART # 270P704010 AND AN OPEN R5A73 82K ¼ WATT OFF PIN 2 OF IC5A02 ON THE MAIN PCB. 2. SELF DIAGNOSIS ERROR INDICATES SHORT PROTECT. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. 3. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB. Good Luck, big IRISH. PS If too much call an authorized service center and have them give an estimate on their repairs in writing.
Posted on Aug 07, 2008
Tv will not stay turned on
its a problem in your main board of the tv.
Oct 30, 2008 | Mitsubishi WS-55807 TV
TV won"t stay on turns off in 3 seconds WS 55807
Do the self check when power light goes off.
On front of set press and hold both the menu and input buttons for 5 seconds or longer and release both buttons.
Power light will blink a error code like: 2 blinks, 2 blinks, a pause and repeat about 4 more times.
Let me know what error code you find and I will tell you what it means.
If this information told you something rate this solution as very helpful as I do this here for free.
SD TECH
Aug 28, 2010 | Mitsubishi WS-55807 TV
Mitsubishi WS 55807 wont turn on
SECONDARY POWER SUPPLY IS OUT
Dec 05, 2009 | Mitsubishi WS-55807 TV
I turn on the tv and it shuts off after a couple seconds
if you unlpug your tv and plug back is the green ligth blinks for one minute?
let me know so i csn help you
Jul 29, 2009 | Mitsubishi WS-55807 TV
My mitsubishi 1080 WS-55807 has lost the picture
Unplug the set, remove all other audio/video components, go open front door, and roll it out to the curb.
Nov 24, 2008 | Mitsubishi WS-55807 TV
Mitsubishi WS-55807 turns on but then powers back down after a few seconds
Good Day;
The fuses tell you that circuit has failed and was drawing too much current. No other test is needed.
Good Luck, big Irish.
Sep 04, 2008 | Mitsubishi WS-55807 TV
Mitsubishi WS-55807 TV won't turn on
It s a Power supply problem.If you are not familiar with electronic repairs take it to an authorized repair shop.
To get a service manual see link
Download Mitsubishi WS-55807, WS-65807, WT-46807, WS-55857, WS-65857, WS-55907, WS-65907, WS-73907 Service Manuallockmanualsdnw_en.gif
Login or Register to get access all drivers database.
Please be sure to enable cookies.
Feb 21, 2008 | Mitsubishi WS-55807 TV
Mitsubishi ws-55807 tv
call a repair man not much else  you can do, try and unplug for a few min
Oct 17, 2007 | Mitsubishi WS-55807 TV
Mitsubishi WS-55807 TV Logo
222 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
