Question about Char-Broil CharBroil Master Flame Gas Barbecue Grill
What is the schematic for a gas grill ignitor, what completes the output (HV) circuit?
4 Suggested Answers
SOURCE: gas grill ignitors
I recently moved. When the grill arrived to the new home I had to purchase a new propane tank to replace the old one. The grill will not light. For some reason it isn't getting any gas. Any suggestions on what the problem might be?
I tried the obvious... tightening the connections, trying to light it manually etc.
Thanks,
K
Posted on Jul 13, 2008
ChefBarry
  • 4 Answers
SOURCE: Ignitor
Check out the product manual, if you need a new one you can download free at Char-Broil.com. Should be a simple fix. Any problems and you can contact the company, they are most helpful!
Posted on Jul 12, 2010
  • 4736 Answers
SOURCE: just bought a new Weber
1. Turn the tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the valve is fully open, light the burner farthest from the tank first & turn it to HIGH.
Did the burner light and the fa,e height look correct? If so, light the remaining burner exactly
the same way. Now, do all the flame heights look correct? If so, you solved the problem.
Always remember to turn the tank valve ON Very, Very Slowly.
If the above didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly, as the regulator is locked up. You can pick one up from any home center or hardware store that sell grills and accessories for about $30.00. Take your old one with you for comparison purposes.
I hope this helped you troubleshoot and solve the problem, Please let me know and Happy Grilling!!
Posted on Jul 04, 2011
How do I replace ignitor switch in thermos gas grill, if this is what is what I saw?
If that white is ceramic, I think it is the actual ignitor, not the switch.
Apr 29, 2017 | Thermos Stainless Steel Gas Grill
Westinghouse oven LPG 527 wont stay alight and grill wont start
Normally the grill is completely separate to the oven. Press the ignitor before you turn on the grill, as, to ignite, oxygen needs to be present (ie: not flooded with gas) . and you should be able to see the spark from the ignitor in the grill. if you can't, then you may have problems with your ignition pack or ignition leads.
Feb 16, 2012 | Ovens
My grill won't light when I turn it on. Have to use a lighter. Also light won't come on even though bulb is new and button lights up when I turn on.
Unlike most other high in gas grills, your Dacor requires 120 volts for everything that's electrical (i.e. ignitors, rotisserie, lights, etc) therefor, there are several connection blocks and transformers that may be causing the problem. The lights, for instance, use a low voltage 12 volt transformer. Nevertheless, before I say, that the transformer or circuit blocks and contact switches are bad, you need to trace all the wiring to make sure all the connections are intact. It won' t be an easy job, but it's one that is necessary. Having a multi-meter circuit tester will be a big benefit, as you can test where the power starts and where it ends and everything in between, .to see where the problem(s) lie.
To help you, I have included a link to Dacor's, Owners Manual page that has your model number listed. The Owners Manual has a schematic for everything electrical, which will be a benefit to you. You can download and print the manual, if you so desire.
http://www.dacor.com/Customer-Care/Manuals-And-Specs.aspx?TaxonomyId=155
Hope this help you solve the problem.
Mar 21, 2011 | Dacor Epicure EOG36 (LP) All-in-One Grill...
I installed a new 7509 ignitor on my 13 year old weber genesis gas grill and the gas does not ignite when pushing the ignitor button. I installed the ignitor with the box opening on the bottom and checked...
If the spark you see is in the ignitor box and not at the burner(s), then there's a wire loose somewhere or the ignitor is not grounded properly. Also check to see if the ignitor tips in the grill next to burner(s) are covered with grease. If so, clean them with a cotton ball dipped in alcohol. Check each ignitor wire at each ignitor , make sure they are secure,
Feb 20, 2011 | Weber Genesis Silver B Grill
Dometic RM3801. Propane ignition failure.
The older units has a 3 VDC glow coil the newer units have a 12VDC igniter.
Fromwhat your described above the next paragragh is your ignition system.
The igniter control voltages in the newer SPARK type igniters are (+) = 12VDC, (L)= high voltage lead (Spark plug voltage! I.e ruin your meter type voltage), (-)= Ground L is the lead that passes the HV spark from the control unit to the ignitor plate. The L lead should pass one heck of a hit if is workng correctly.
If not look at the HV lead to see if it is grounding out somewhere.
If the gas safety valve is not sensing gas pressure... you will not have 12VDC to the + terminal of the ignition moudule.
With the gas on and you have 12VDC at the ignition module + terminal then most likely the ignition module is bad.
Kelly
Apr 17, 2010 | Refrigerators
Replacing ignitor battery
Has it got a battery or has it got a Pitzo crystal? They eventually wear out, you may need to replace the ignitor button unit.
Jun 09, 2009 | Kenmore 555 sq. in. Cooking Area Gas Grill...
Ignitor not working is there a battery that needs
The electronic ignitor on our Charmglow SS Gas Grill (Model 810-6320-B from Home Depot) was not generating a spark. The battery beneath the ignitor button (cap) had to be replaced. At first, still no spark. Next I used a Dremel hobby drill with a small wire brush head to clean the negative contact within the battery chamber. Also brushed the spring surfaces (battery positive circuit), ensuring good contact when battery inserted & ignitor button re-installed.
Checked wire contacts & gap of electrode tip.
Ignitor is working again!
Apr 12, 2009 | Grilling
Gas grill ignitors
Check the electrode.  That is the end at the burner.  It may be corroded and no longer creating a spark.
Jun 05, 2008 | Weber Q300 Grill
Grilling Logo
531 people viewed this question
Top Char-Broil Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Jim Thurston
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
