Question about Freezers
Frigidare upright model MFU14M2GWO quit freezing and outsides are hot to touch on top, and sides. Unloaded box and went back and seems to be refreezing somewhat. About 10 years old. Time to rebuy?
  • 883 Answers
SOURCE: freezer problem
if you don't hear it running for extended periods of time (more than 15 minutes) without stopping, and if it does not immediately re-start once it does stop, and if it is extremely hot climate outside (85 F and above), then yes, this is acceptable.
Posted on Jun 08, 2007
  • 1314 Answers
SOURCE: Freezer is running constantly and sides and top are hot.
first whirlpool makes a good product as far as the sides being hot good sign the condensing coils are in the sides are supposed to be hot worry if its running and they are cold then not working right ok as far as running modern units useing 134a do have long run times but are not using but same enegry as 100watt light bulb otay
Posted on Dec 30, 2007
SOURCE: My freezer is hot!
It is normal for the freezer or fridge walls to be hot sometimes, some important points are to make sure that there is enough ventillation around the fridge/freezer, especcially the back, so that air can circulate around it freely. Also maybe just check that there hasn't been anything fallen down the back blocking the vent, and that there isn't a dust collection or anything. Otherwise as far as I know this is normal.
Posted on Aug 26, 2008
kachbibi1
  • 979 Answers
SOURCE: problem with upright freezer not freezing
It sounds like the unit is low on freon or the compressor is going bad. You have several other components that could be affecting this as well. Make sure the coils are free from dust and clean underneath. This is a bit premature for you to have problems now, especially since it is a Sears product.
Posted on Feb 17, 2009
SOURCE: whirlpool upright freezer making buzzing noise and not working
I had a similar problem yesterday. I woke up and the freezer was not working anymore. It would make a buzzing noise and then it would click and shut off. I looked online for some possible solutions. Here is what I did:
I unplugged the fridge. I pulled it out and took off the cardboard backing. I used an air compressor to blow out all of the dust and dirt that had accumulated on the condenser coils. A shop-vac just wasn't powerful enough to pull out all of the dust/dirt. After that, I plugged it back in....and the same thing was happening. It would buzz, and then it would click off. I figured out that the "click" was coming from a starter relay (a small plastic piece attached to the big black compressor). I detached the plug from the relay and then detached the relay from the compressor. The relay was burned out. It turns out this is a common problem with the relay. I replaced the relay for $50 (from an appliance parts store) and put the whole thing back together in about 10 minutes.
I plugged the fridge back in and the compressor started, and now the freezer works better than other. I saved about $400 doing it myself, all in about one hour. And better yet, my wife was very impressed. Not bad for a doctor.
Posted on Jul 04, 2009
Kenmore upright freezer hot on the sides, stop freezing
Without the model number I'm not sure how to answer your question. Does your model have fans that blow warm air on the outside bottom or a front kick plate? What is your model number? Kenmore has model numbers like this example=> 123.3214567 If the fan has a restriction that causes a lack of airflow it can cause the hot Freon liquid that normally flows around the Yoder Loop inside edges of the freezer door to prevent frost buildup to become very hot because the condenser fan is defective or coils are dirty with dust restricting airflow. If the outside is hot you may have a defective condenser fan motor. That will cause the freezer to ger hot. I am here should you want my assistance....Sea Breeze
Kenmore Freezer Parts
Aug 31, 2013 | Kenmore 14.1 cu. ft. / 399 liter Upright...
The outside of the freezer sides are extremely hot to the touch? Why? Freezing fine on the inside.
the coil normally on b ack of fridges is on sides of freezers under skin it is normal to be warm. The hotter the weather the hotter the skin.
Sep 02, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
After defrosting the freezer it will not cool
Don't panic about the hot sides of the freezer. It is quite common on all the freezer (make/model).
After defrosting, your removing the full temerature out of the system. It will take atleast 30 ~ 60 mins to come back to set temperature. This again depends on the load inside.
Jun 06, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
My Kenmore 9 upright freezer feels warm on the outside, what could be the cause. I have defrosted and cleaned it already and seems to work fine. however i am concerned with the outside temperature. Please...
This is normal. The condenser coils on freezers are typically located in the walls.
The refrigerator in your kitchen has condenser coils that are hot either under the frig or on the back. Freezers do not need as much heat transfer on the coils with the air so they put them in the walls, it is called a warm wall condenser. It may even feel hot to the touch if you happen to feel it near the end of a cooling cycle. It will be the warmest close to the compressor and cool off at it makes it around the cabinet down to the other side.
Apr 25, 2010 | Kenmore Freezers
The sides of my freezer are very hot while the top, front and back are cool to the touch. The freezer still is freezing items fine.
In the newer freezers and refrigerators they are mounting the condenser coil in the side panels of the freezer or refrigerator eliminating the large usually black frame work of tubing that used to be mounted on the back. This saves room but causes the sides to be warm as the heat is now dissipated by the side panels. You should have about an inch of clearance on both sides to let air flow over the side panels to cool them. I have a newer side by side and it also is feels quite warm when you put your hand on the side.
Oct 07, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Freezer @ +28 deg/appears common problem B 1st 2 answer right....
Model numbers of Kenmore , starting with 253. are made by Frigidare . The compressor probably has a valve out , either the high-side , or low-side . Probably the low-side valve is bad , therefore , the high-side will pump but not get the freezer as cold as it should be . Both sides have to work . Low-side helps pull the refrigerant thru the system , while the high-side pumps pressure thru the system .
Aug 26, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Chest freezer repair
I had the same problem with an upright and so I bought a piercing valve and charged the compressor with 134R and has been working great since.
Jul 05, 2009 | Freezers
Top shelf of frigidare manual defrost freezer only freezing, other shelves are not cooling.
Is the condenser clean? If it is you may have a refrigerant leak or an inefficient compressor.
Jun 28, 2009 | Frigidaire Freezer Refrigeration White...
Freezer alarm
Upright freezer door was ajar, alarm went off. Where is the reset button? Product is Frigidare.
Jun 02, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Freezers Logo
110 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
