Question about RTO Construction Bobcat by Woody Click
Throttle cuts back, at the same time the hand primer pump is sucked in. Only by bleeding any air out and re-pressurizing the hand pump the bobcat runs fine for about 20 minutes then revs down again.
  • 4 Answers
I say start at the easiest problem which could be that your hand primer pump is bad. Then check the fuel tube inside your fuel tank, it has a screen at the end and could be clogged.
Posted on Sep 10, 2010
The primer bulb on my Husqvarna 235e chainsaw will not fill. Why?
Number of reasons for the primer not filling, But i'll go with this one as you say the tank is under pressure.
Faulty primer. The primer has a couple of one way valves in it, so it sucks up the fuel while expelling the air in the line. Id say that the valve in the primer has failed and instead of pumping up the fuel you're pumping air into the tank. The replacing the primer. part number 545 00 80-30
Apr 17, 2016 | Husqvarna Garden
2 fuel lines broke (1 from tank 1 from primer bulb). Line from back of tank to back of carb still there. Which lines go where?
Do not mix them up!! Doing so will bring debris into carburetor. Assuming the line from back of tank to carburetor is the fuel feed line then you should also plan to replace it if the other lines have failed..
The primer bulb sucks (pulls) the air fuel through the carburetor thus venting out any air. The process draws the fuel through the in tank filter through the impulse fuel pump. The fuel connects via an internal carburetor passage from the pump to the needle valve and during the prime passes the needle valve into the pressure diaphragm chamber. From there the fuel is drawn(sucked) into the inlet side of the purge/prime valve and returns the air fuel into the tank.
The center hose on the primer is the return into the fuel tank. The hose from the center of the primer bulb goes directly to the fuel tank and is the return. The outer diameter hose connection to the primer is the connection made to the carburetor. By closing off the end of the hose you can test with your finger the function of each hose. You do not want to pass fuel into the carburetor by reversing the primer hoses.
Dec 06, 2015 | Garden
60 horse Work Master New Holland wont start blead lines but looses fuel to filter seems like hand pump dont work will run if you spray ether then dies when you stop spraying it. Can someone help
Earl You have to be able to bleed all of the air out of the fuel filter and lines for your engine to run. If the fuel is leaking back to the tank there is a problem with the valves in the hand primer pump.You might have to replace the pump. Remove or loosen the bleed screw on the top of the filter and pump out all of the air so there is no more bubbles then loosen the fuel lines at the injectors and turn the engine over with the starter to bleed the lines. Only crank over with the starter for 30 seconds per try and give the starter time to cool down
Oct 31, 2015 | Cars & Trucks
1995 international flat six diesel 466 wont run changed fuel filter losend lines bleed out air wont run squirt eathier starts dies
Make sure you pre fill the filters with clean fuel. Locate the hand primer usually near the fuel lift pump. Unscrew the top till it pops up. Pump repeatedly until it gets hard to pump. You can crack the injector lines while pumping till fuel comes out or have someone crank the engine with the starter while you continue to pump the hand primer. Make sure after it's running the pump is pushed all the way down and tightened back up
Nov 27, 2014 | Cars & Trucks
I have a 1988 30 hp.evinrude that starts and runs fine till i reach 3/4 throttle,then it will die.ant suggestions?
Fuel line could be sucking air.check breather not blocked on fuel tank.if fuel bulb sucks flat,means blockage btwn bulb and tank.have you tried priming motor while running at full throttle.could also be dirty carb
Jul 15, 2014 | Boating
Bobcat 773 wont restart after dying out where do i start?
if the bobcat starts and then runs for a short time then dies the first place to look is the fuel system.fuel filters are the most common problems that i see replace those first.i have also found some junk inside the pickup tube inside the tank.there is probably a ball type hand pump to prime the fuel system.give that a squeeze and see if its hard.if thats the case there shoud be a small screw on top of the fuel filter.loosen that screw and see if fuel comes out when you sqeeze the ball.if your changing fuel filters this is also where you blead air from the system,keep pumping untill there is only fuel and no air.if you still get air after pumping for a long time then your sucking air into the system between the tank and pump.after you get fuel there close the screw,loosen the injector lines going to the injectors,crank the engine,and tighten when fuel comes out (keep clear because that is high pressure fuel).after you get fuel at all injectors and they are all tightened it should start.
May 26, 2014 | Bobcat 773
How do you bleed the diesel fuel filter on a 1986 Toyota diesel Land Crusier?
I don't know a lot about these trucks but I can tell you that somewhere between the spin-on fuel filter and the I.P. (injection pump) is a 1.5" dia X 4" long steel primer. Just under the top of it is a spring. You will need to loosen or open the "Fuel supply line", at the I.P. (going from the filter, to the pump) and manually pump the fuel primer. Continue pumping the fuel primer until diesel flow from the opening. Quickly close off the drain-port or fuel-line, pump the primer a few more times (to increase line pressure and try to start your vehicle. After it starts, check for leaks. Let me know if I can help anymore. Good luck.
Mar 06, 2014 | Cars & Trucks
How do you prime the fuel system when its ran out of fuel cummins
LOCATE LOOSEN THE LOW PRESSURE BLEED BOLT.THEN OPERATE THE RUBBER PUSH BUTTON PRIMER ON THE TRANSFER PUMP.DO THIS UNTIL THE FUEL EXISTING THE BLEED SCREW IS FREE OF AIR.IF PRIMER BUTTON FEELS AS IF IT IS NOT PUMPING ROTATE CRANK THE ENGINE APPROXIMATELY 90 DEGREES THEN CONTINUE PUMPING AS DESCRIBE.THEN TIGHTEN THE LOW PRESSURE BLEED SCREW TO 72 INCH POUNDS.
Aug 20, 2009 | Dodge Ram 2500 Cars & Trucks
Engine won't run unless primer bulb is being pumped
I have the same problem and may have a solution. I looked at the primer pump and it was cracked letting air into the system. When I pumped it my finger was over the crack and it worked fine. When I stopped the crack was able to **** air again. Take a look.
Jun 20, 2009 | Boating
RTO Construction Bobcat by Woody Click Logo
368 people viewed this question
Top RTO Toys Experts
Timllfixit
The Scrivener
Pete Bruk
Are you a RTO Toy Expert? Answer questions, earn points and help others
