Question about Philips 20PT6441 20" TV
How to unlock 25ht2212/69r phillips tv? how to return the High Security to Low Security settings?
DIGDB WON'T WORK!
I know the feeling! :( .
1. Check you have the correct copy for your version of Windows.
2. Check your Excel's 'Security Level', go to 'Excel->Tools->Macro->Security...' - If the setting is 'High' or 'Very High' then DigDB will fail silently. You should set Security to 'Medium' or 'Low' before you run the DigDB. Setting it to 'Low' will ensure that DigDB can run.
3. Failing that, uninstal, re-boot and re-instal
4. Failing that write to suppliers and ask to return and have your money back
May 15, 2014 | Excel Add-ins DigDB for Excel
How can i unlock Phillips 26" LCD TV 26HF5443/97
Using a universal remote with numeric keys, input this code->319753 and press mute. This has to be done quickly, and the channels will change, but ignore that.
Use navigation keys to change the settings.
If it's in High security mode, then you are pretty screwed, unless you can find the green Master remote which has a few more functions.
If in Standard mode, then a universal should be fine.
It took me DAYS to find all this out, since I just picked one up last week, and I had the same problem.
I had to use 2 remotes to do it though, since my universal is old and clunky, but I had an old Philips multi remote for a video player as well, which accepted the direction buttons ;)
Hope that helped. If it's been solved for you, it's ok, since there might be others out there with these model of ex-hospitality(hotel) TV's.
Cheers from New Zealand!
Aug 11, 2012 | Philips Televison & Video
Philips 37 TV smart sercurity unblock?
Either read the owner manual or CALL philips customer service with the model number to get help
May 28, 2012 | Philips TP2784C TV
Tv will not turn on, red led flashes 7 times ???
Could be a power issue. Contact Phillips and/ or contact a licensed Phillips repair shop.Have your warranty details ready if it is till valid.
Jun 24, 2011 | Philips 42PFL5332D 42 in. LCD Television
Has a lock code on it how can i unlock the code
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} : If you have a Garmin Lock on your nuvi series and you have forgotten your 4 digit PIN number you can unlock the device by returning to your Security Location. The Security Location is the location that you set when you first enabled the Garmin Lock on your device. Returning to the Security Location will unlock your device. (Approximately 150 feet from that location)
Nov 08, 2009 | Garmin nuvi 260W GPS Receiver
Can't remember pin for garmin nuvi 660 fm , it also won't unlock at secure location.
Either remember the PIN
OR
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If you have a Garmin Lock on your nuvi, zumo or StreetPilot c500 series and you have forgotten your 4 digit PIN number you can unlock the device by returning to your Security Location. The Security Location is the location that you set when you first enabled the Garmin Lock on your device. Returning to the Security Location will unlock your device. (Approximately 150 feet from that location)
If you have forgotten your PIN and Security Location please contact Product Support for assistance. Please note Garmin will require a copy of the receipt and there will be a charge to unlock the device as this issue is not covered by the warranty.
Oct 02, 2009 | Garmin StreetPilot i3 GPS Receiver
Unlocking Phillips PET722
I found this on a website devoted to unlocking DVD players.
You need an OneForAll6 remote (URC 7560)
  1. Press DVD device button (set remote to DVD)
  2. Press and hold MAGIC until it flashes 2x
  3. Enter Setup Code (0539)
  4. Press MAGIC again
  5. Enter 085
  6. Enter 222 222 005 255
  7. (should be displayed)
  8. Press PLAY
for the remote "SBC RU880":
  1. Press and hold 1 and 6 until SYNTH is displayed.
I hope you find this helpful
Dave
Nov 12, 2008 | Philips TV Tuner Video Capture PCI Card -...
How can i unlock philips hotel tv 21ht3302/41?
hey pls help me.. I have this Tv and igit buttons 3,1,9,7,5,3
and the mute button was worked.
but recently
above code doesn't work,as i remeber I put high security in menu.but What can i do now,please help me.
please...
raveendramax@gmail.com
Aug 14, 2008 | Philips 20PT6441 20" TV
Phillips 25 HT Television
If you have a Pronto you can get codes from Remote Central otherwise you might want to look for a higher-end universal remote that may have the Setup keys you're looking for.
There are also several JP-1 remotes out there that allow programming codes like Pronto, but not as simple.
Apr 05, 2008 | Televison & Video
Philips 20PT6441 20" TV Logo
272 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
