Question about Envision Computers & Internet
I own a 22"HD Flat Screen Envision Monitor. It is flashing "OSD LOCKED" constantly. How do I stop this?
  • rkh523
    rkh523 Aug 03, 2010
    The keys on the front of the console are [1] , [Up Arrow] , [Down Arrow] , [2], and the Power Button. Which ones do I hold down?
  • rkh523
    rkh523 Aug 03, 2010
    Thank you for your assistance
    President:
  • 1,566 Answers
To unlock (or lock) the OSD menu:
- If the monitor is on, press the power button to turn the monitor
off.
- Press and hold the brightness, contrast and menu keys
simultaneously.
- While holding these keys down, press Power to turn the monitor on.
- Let go of the keys.
Repeat the same procedure to lock/unlock again.
You can also try holding the Menu button for at least 10 seconds until a message pops out of your screen. "OSD Unlocked"
Posted on Aug 03, 2010
Osd display is locked on q22wb monitor
Please contact ViewSonic Customer Care to get support for this. There is a special set of macro keys to press to lock and unlock the OSD. But you need to call Customer Care to get this resolved.
Jun 29, 2014 | ViewSonic Q22WB 22" LCD Monitor
AOC monitor says OSD locked
OSD means on-screen display. As you make adjustments, they are displayed on the screen. You may have to press the OSD button to unlock it.
Sep 06, 2012 | AOC V22 22" Monitor
I keep pressing menu and it tell me OSD Locked? How do I unlock it?
This has most likely annoyed many of you at some point. You turn on your monitor one day and see a jeering message telling you something about an "OSD Lockout". It doesn't allow you to change any of your monitors settings, including the setting intended to turn off this message. While I've only seen this error on HP monitors I know that others have encountered it on other brands as well. The fixes I provide should work on those monitors too. (Note: OSD stands for On Screen Display.)
Fix One:Plug in the monitor and power it up. Hold down the Power button until you get a message saying "OSD Unlocked". If the problem persists after OSD is unlocked then unplug the monitor from the wall, wait 20 seconds and try again.
Fix Two:Turn on the monitor and hold down the Menu button for 10-20 seconds. This should unlock the OSD.
Fix Three:Turn off the monitor, press down the Menu button and then turn on the monitor. Wait 10-20 seconds. This should unlock the OSD.
Fix Four:The Menu button may be stuck in a pressed in position. To get it "unstuck" you'll usually need to open up the monitor. This could be tricky unless you know what you're doing. Unfortunately there are too many models of monitor for me to provide detailed instructions. If you have warranty this is where you want to contact the manufacturer.
If you think this solution helps you then your token of appreciation in the form of Rating and a testimonial will be esteemed.
Thank you and Keep Visiting FixYa!
Apr 12, 2011 | Envision 19" Widescreen Flat Panel LCD...
Why am I getting osd main controls locked flashing and then the same message saying unlocked and i am unable to clear it - posted in Monitors ... the attention osd locked is constantly flashing on and off...
Most of the monitors have a function to lock the OSD to prevent accidental changes in the configuration of the monitor.
If you are constantly getting the message about OSD being locked and unlocked then it means that the OSD locking button is constantly pressed.
Usually it is the "Menu" button on the monitor which is used to lock the OSD.
Check if the Menu button is constantly pressed.
Sep 11, 2010 | Compaq Presario 5000 PC Desktop
Osd locked
Unplug the monitor from under the screen. Leave it off for a min. If OSD returns, it's a bad monitor. Maybe a button is stuck ?
Jun 13, 2009 | Gateway FPD2275W LCD Monitor
OSD locked on ENVISION Monitor
turn of the monitor then press the menu
Mar 13, 2009 | Envision H191W Monitor
Hcl lcd monitor osd locked
my moniter was automatic restarted, and osd lock not open,where is is osd open option?
Dec 19, 2008 | Acer AL1916W 19" LCD Monitor
My computer screen has a blue box that pops up and say "Controls locked". I am assuming that the buttons on the bottom right hand corner of my moniter is what it is talking about because when I hit the...
This is from the user manual for the monitor. You can download a copy from hp here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=324216&os=228&lang=en&
Click on the "monitor user's guide" link to download.
There are four adjustable options on the OSD settings screen: Lock OSD settings, Timeout, H Position, and V Position.
To change OSD settings:
1 Open the OSD setting screen under the Advanced menu. See
“Using the On Screen Display” on page 25.
2 Press the Browse buttons to select the option you want to adjust.
3 Press the Select button to check the option.
To change OSD lock setting:
1 Press the Browse button to select yes (lock) or no (unlock). The
setting is automatically saved when you change the value.
2 Choose Exit sub-menu and press the Select button to return to
the OSD Main Menu or press the Menu button to exit OSD.
NOTE: Once OSD is locked, all OSD functions including the
shortcut buttons are disabled. If OSD is locked, pressing
any button on the monitor directly opens the Lock OSD
settings window so that you can unlock OSD.
Dec 02, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Computers & Internet Logo
224 people viewed this question
Top Envision Computers & Internet Experts
Steve
Dimitar Todorov
Paul Bade
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
