Question about Frigidaire 24 in. FDB635RF Built-in Dishwasher
Took it out while remodeling and when reconnected, it is leaking at the bottom of the door in front.
  • Frigidaire Master
  • 43,501 Answers
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
06-9698
Posted on Sep 29, 2010
Fridge constantly leaks water. The freezer has no issues at all, but the bottom half is always covered in water/ice, I can't keep anything on the top shelf or it freezes, and of course all the drawers...
i haven't worked on a roper but i'm sure it's the same as any other machine,first tilt the machine back by raising the front legs so the doors close with a gentle push,then remove the freezer inside wall,melt out any ice and under the evap coil check the drain hole,pour hot water into the hole to make sure it's draining,usually if water is leaking into the fridge section it's a blocked drain.let me know what you find and i'll help you as much as i can
May 14, 2011 | Roper RT18HDXKQ Top Freezer Refrigerator
Leaking from the front
I had same problem but different model #.
The part under the spray arm came lose and the gasket was hanging out. Causing it to squirt water right at the bottom of the door and leaking out. I took it apart put the gasket back in the groove, screwed it back down and is working great.
May 25, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
My GE dishwasher is leaking out the bottom of the front door. Everything seems to be sealed properly. I took the inside of the door off and couldn't find anything obvious. Is it possible to be overflowing...
You most likly need a new bottom door seal. Usually 3 screws down each side of the door and then two screws hold the bottom door seal in place. The bottm door seal can look fine but if its leaking out the bottom front this is the problem 99 % of the time, Unless someone is using dish soap to preclean the dishes or using regular in the dishwasher.
Mar 20, 2010 | GE 24 in. GSD3330C Built-in Dishwasher
I have a maytag neptune washer mah5500bww that has been leaking a little under the front end of the washer. I just had the door boot replaced and so I called the repair man back. He had no clue where it...
easly fixed in most cases .you can grip the door with both hands and tweak it so the bottom of the door is flexed inward it is a common problem with the habbit of leaning on the door while removing clothing also its common that the untrained repair guy forgot to connect the little drain found at 6 oclock on the door boot after you have removed the front panel
Aug 11, 2009 | Maytag Neptune MAH5500B Front Load Washer
Dishwasher is leaking out of the front right bottom corner. It spurts out while it is running. I took the front panel off and could see that where it is coming from but dont know why it is all of a sudden...
most of the time when it leaks from the front door it is going to be from a corner. most every time the front door gasket is replaced to solve the problem. I have found that the gasket on my dishwasher last about 2 years before needing replaced. I clean the white hard scale that builds up on gasket frequently
Jun 17, 2009 | Dishwashers
Leveling old refrigerator
you can adjust the front rollers by turning the screws at the bottom behind the toe kick
Jun 09, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Frigidaire 24 in. FDB635RF Built-in Dishwasher Logo
44 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
