Toshiba laptop A130/A135
I was watching a dvd on my laptop while charging my latop. I fell asleep and the electric was taking by NEPA an electricity supply in nigeria which is frequent problem. the problem was that DVD freezed up when I was asleep please help me.
  • 19,396 Answers
Try this disconnect laptop from power, remove latop battery. Wait ten mins and connect everything back.
If the problem is that dvd is stuck inside use a pin or a staple , stick it into the emergency opening hole until it opens the door on dvd drive on laptop.
Posted on Apr 25, 2008
Replacing the dvd room drive? any ideas
Toshiba Satellite A130, or A135 series of Notebook PC, I do,
Removal guide,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a135/remove-mainboard-1.htm
Remove the one Philips head screw in the Ram Memory Compartment, Step 4 and 5.
http://www.getpartsonline.com/k000045560.html
(Also have seen a lot of listings on Ebay)
Regards,
joecoolvette
Jul 30, 2011 | Toshiba Computers>Laptops Satellite A13 PC...
How to recovery toshiba satellite A130/A135 of your recovery dont wark
tu sabse pahle apni maa chuda ...fir apni bahan ki chut ko chat..............fir usme mera lund daal de......fir main teri bahan ki chut ko jor-jor se chodunga.....uske bad hi bata paunga main teri problm ka ans.....samjhe re maa ke loude.............
Nov 14, 2010 | Toshiba Satellite A130 A135 Notebook
Cant find CD key for toshiba satellite A130 /A135 . how do i get key?
I think you mean the key to access windows vista home basic. The key should be located on the back of you laptop near some bar codes it should be 25 caracters long like XXXXX-XXXXX-XXXXX-XXXXX-XXXXX.
OR
You can be sneaky:
Download a nifty program called the "ProductKeyFinder" it should be free. Run it on your friend's computer with the EXACT SAME operating system and and copy down his key. If you get in trouble that's too bad.
Aug 14, 2010 | Toshiba Satellite A130 A135 Notebook
Charge isn't consistent. Orange light flashes instead of remaining on when charging.
Are you using the original ac power adapter, or one that is designed for use with your model to ensure that it is fitting tightly where it plugs into the laptop at the dc jack?
If so, the dc jack could be broken, which could prevent the battery from charging properly, resulting in the flashing amber light, which is indicating that the battery is still low and needs recharging.
Another possibility is that the battery is defective, but the more likely problem is the dc jack since it is such a common problem.
You can find a replacement dc jack here.
http://www.laptoppartsexpert.com/c-49361-toshiba-satellite-a130-a135-series-a135-s2276.html
Good luck, please let me know if it helps.
Thanks
May 08, 2010 | Toshiba Satellite A135-S2276 Notebook
Toshiba satellite a130/a135 series. I connect to
check the power cord to the laptop in the back wiggle it. check the lights. if they come on and go off with you giggling the power cord. the ac input socket may be broken. you may have to wedge it in one spot to get the two lights to come on let it sit there a while 20 min to charge battery some then turn on laptop.
Jun 23, 2009 | Toshiba Satellite A135-S2276 Notebook
The recovery on my Toashiba Satellite A130/A135 doesn't work
Try to boot the machine in safe mode by pressing F8 as the computer starts up, if will let you boot into safe mode as it sounds like there could be some bad sectors on the drive causing it to hang on boot.
To check this right click on the C drive and select "properties", then select "tools" tab, in the tools option check the volume for errors.
This can take some time to perform so please be patient.
If you can't get the machine to boot into safe mode please post back
Jun 22, 2009 | Toshiba Satellite A130 A135 Notebook
Computers & Internet Logo
149 people viewed this question
David Payne
David Payne
