Turbo Air 49 cu. ft. / 1388 liter Commercial Freezer TSF-49SD Logo
Posted on Aug 03, 2010
Looking for relay # UZ-2A-BT110 RHODE ISLAND AREA CELL 401487-5770 TGF-49 F
Turbo Air TGF-15SDW-N White Glass Door Merchandising Freezer. My turbo air freezer wont turn on tgf-15sdw-n
Question edited for greater clarity.
Question moved from 'Power Computers' to Freezers.
Disconnect the mains power for 5 minutes to reset the control board. If that doesn't fix it, call for service.
Jan 27, 2023 • Freezers
My frezeer can not star
You need a new regulator. get the manufacturer and make and numumbers and look it up and save hundreds putting it in yourself.
[email protected]
Hi - We've got a Turbo Air TGF-23F mrechandising freezer that freezes - down to -15 and then suddently begins to warm up about 1 degree per minute. In about 15 minutes its just over 0 degrees and...
Did they test the thermostat? I would think that the compressor would kick on before you got that much of a fluctuation, unless the thermostat is not sensing the change fast enough.
The run and start capactiors and relay, did they give you a reason for that? When the compressor kicks on does it surge the power? Light dim or something? It is hard to guess without being able to put an o'scope on your machine to be able to see what it is doing, but just based on what your write-up was, I can't see the parts you said they want to replace will fix the problem.
2helpful
I have a Turbo Air TGF-49F freezer and it is not cooling. The compressor unit seems to work but when I turn the unit on all I hear is the compressor running continuously but nothing gets cold.
Difficult for you to check this I'm afraid, if the fan on the cooling unit is working unless you have an experienced 'ear' you will not hear the compressor running or worse still occasionally clicking.
Possible faults are
1. Compressor not running (the fan will run even if the compressor does not) electrical fault
2. Compressor seized (consult your service guy) also true for the rest of these
3. Compressor not pumping
4. Refrigerant leak
Not much hope for a cheap repair
True 49f goes into defrost mode the contact opens for the compressor but the compressor keeps running
in many cases, these units have relays or contactors where the contact points actually weld together. this causes the unit to stay running even though power to the coil has been stopped. I'd start looking there first. don't over look the possibility that someone could have mistakenly miswired the unit.
I have a Woods model F16CVREC freezer that has formed ice within the freezer compartment and warmed to the point of defrosting the food within the unit. Any ideas what the problem may be? Thanks Islander
This freezer has a thermostat that adjusts the coldness of this fridge marked on different ranges from lower to highest, if digital it's adjusted according to coldness you need your consumables to be. so try to adjust it to colder values or it mayn't be faulty not responding either not switching on compressor, this is why it warms up or switches on the compressor with out switching it off for a long time.
It also has a defrost timer that may need to be checked,even the compressor should be checked to
see weather it's working perfectly,plus the compressor relay this is attacked to the compressor
it could be tripping due a malfunctioning.
Contact a service engineer let him/her visit the mentioned areas.
Hope it works for you.
May 18, 2010 • Freezers
2helpful
2answers
Do you know where I can get the defrost heat element for a True freezer T-49, in Dallas, Tx.
Try refrigeration hardware service out of Colorado. I'm not sure they sell to the end user, give them a try.
1helpful
Looking for true freezer defrost heat element for t-49f
Most commercial refrigeration supply houses should be able to help you with getting the heater or if not at least give you a steer
as to where to go or who to contact. Some are really helpful, others can be real jerks. Sorry but without knowing the area you are in I cannot give you more info than that. Did you Google the Brand name of the freezer ?????
1helpful
I wondered how long the defrost cycle was supposed to run on this Turbo Air TGF 49F freezer as I am not sure if a door was left ajar or if it is stuck on defrost if possible. I would like to manually over...
If it's frosted up, it's best to defrost manually with heat gun. Find the timer and advance until it goes back into defrost. The timer looks like a residential fridge. It cut the compressor off and the heaters on.
Please rate solution
6helpful
6answers
I have a True Freezer Model T-49. It works fine but every 3 or 4
This sounds like a stuck relay to me. I have seen this problem before. The defrost clock kills power to the compressor relay coil during defrost. If the contacts in the relay are welded together the compressor runs while unit is trying to defrost. On newer units this relay is mounted in base of unit on the side or back of the electrical box near center bottom of unit. The compressor relay is a small rectangular box with 4 wires attached. It can be replaced with a single pole 20 amp contactor with a 120 volt coil/ or 240 volt. Check the units name plate voltage rating and ratings on old relay! ;)
Top Turbo Air Freezers Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Turbo Air Freezer Expert? Answer questions, earn points and help others
